Old 04-17-2017, 06:57 PM   #113
strat61caster
strat61caster's Avatar
Originally Posted by glamcem View Post
You're thinking of instant lateral G readings. MT, however, has different procedure to come up with those numbers. And no, it won't be with minimal effort 1.09g with street tires take a lot more to achieve. Those tires will definitely help (it did with my BRZ) but nowhere near close to those levels.
I understand what a skidpad test is, sustained g's are what's being measured, not peak, otherwise I would have pulled out the >1.3g peak that can be seen on just about every STX prepared 86 youtube video with data overlay, even with shitty drivers like me. Even the street prepared cars can peak 1.1g.
I'm sure yours peaked much higher on the slicks. I'll have to pay attention what my car can do next time I have access to a skidpad, I might be fooling myself after all.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
glamcem (04-17-2017), nikitopo (04-18-2017)
Old 04-17-2017, 07:28 PM   #114
DarkSunrise
DarkSunrise's Avatar
For a reference point with data, MT did a test a few years ago putting a stock suspension FR-S on Z2-SS's (anyone remember those lol?). It pulled 1.01 g and did a 25.0 second figure 8.
While RE71R's are a stickier tire than Z2-SS's, I don't think they'd make up the difference to the 1LE's 1.09 g. But I do think they'd close the gap a bit, probably around 1.03 g. A real alignment and some coilovers would probably add a bit more although probably not enough.
http://www.motortrend.com/cars/scion...-tires-384795/
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
Cole (04-17-2017), glamcem (04-17-2017), strat61caster (04-17-2017)
Old 04-17-2017, 07:38 PM   #115
strat61caster
Yeah, those were 245's to boot so I may be overestimating a bit. But you might be forgetting how grip challenged the front end is with the OE <1.0 degrees of camber.
It'd be close, and anybody who would actually use that performance and not bench race it would probably think 'close enough'
ineedyourdiddly
Cole (04-17-2017)
Old 04-17-2017, 08:22 PM   #116
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I remember seeing that test and a few others done with Tire Rack sponsored event just couldn't remember the numbers.
Keep in mind though, they also put some Volk TE37s in the mix which will definitely the car can definitely benefit from. A fair comparison IMO would be similar tires with OEM wheels. I personally shaved about 8-9 lbs per corner by going with aftermarket wheels and tires (and will probably save another 4 lbs on each corner by going some RB/ DBA 2 piece rotors) . That's the difference between the GT350 and GT350R which puts the GT350R in a different league.
glamcem is offline   Reply With Quote
Old 04-17-2017, 10:20 PM   #117
DarkSunrise
Yeah I agree on the alignment (and coils and LSD for that matter). Would be interesting to see what kind of numbers a full STX car would put down on skidpad, slalom, 60-0, etc. if tested. Not many tests like that though.
Yep good points. In addition to the lighter wheels, that car also benefited from wider wheels/tires too.
2022 BRZ Build
2013 FR-S Build
Old 04-17-2017, 11:44 PM   #118
ST185RC
Drives: White Out FR-S
Originally Posted by nikitopo View Post
Please read again my comments within the specific CONTEXT. I answered on a comparison of cars related with lateral g forces and brake performance. Thanks!
Same can be said if you change the tires on the camaro. What was the context when you start swapping stuff beyond stock?
Dumb comparison is dumb. Thanks for your time.
ST185RC is offline   Reply With Quote
Old 04-17-2017, 11:49 PM   #119
ST185RC
Have you ever driven an Alpha Camaro? It sounds like it does a great job at keeping the driver connected to the car. The steering, handling, throttle response, and pretty much everything else like that seem to be very on point (aside from visibility). But, it also has a LOT more usable torque than the 86.
I don't really think it's fair to judge the Camaro based on the Mustang. The Mustang seems like a nice grand tourer, whereas the Camaro sounds like a legitimate driver's car.
I agree, but it's also a 2 seat convertible. There haven't been many fun to drive, affordable 2+2 Rwd coupes that have been made available aside from the 86. If I had never bought my FRS and was in the market right now the v6 1LE would definitely be on my radar for a DD.
Wasn't trying to bring up the mustang because I wanted to compare it directly to the camaro. But the point was that the 86 simply instills a greater sense of stability and confidence in the driver.
Old 04-18-2017, 02:51 AM   #120
glamcem
glamcem's Avatar
that's a common misconception, it is most likely because twins in stock form do not have too much power to get many people in trouble and car is very well balanced because of that. I am not saying it's a bad thing or anything but I wish they offered a more powerful and track focused version. In reality, for the given speed Camaro gives me a lot more confidence.
Another confidence adder is the brakes, oh MY!! I can definitely feel that I can brake later than my previous cars even with the higher speed (v8 power) and weight disadvantage(3730lbs). I had Stoptech ST40s on my S2000 and custom ducting on my SC BRZ and race pads but none of them gave me the confidence that a stock 1LE did, none of the cars that I owned or drove had a brake system this good, period! It seems like the only better options out there are the new Z06 and Grandsport (and the Viper of course). .
MRC Suspension, the gigantic brake booster that has a size about my head should all help . And of course These should help also "objects in picture are WAAY BIGGER than they appear"
[IMG]https://lh3.googleusercontent.com/W9QsraFyDZyk9W57KouZM4Afy53NRw905pGIOFaFeozFUIBBcc KYhOKHeKsnVaxI5F0bsxJQ2wlY1UqGs6HYMsqK6sUXXHp0N0yF-U-J-1KcfD53u08WHATs59tLOXSzV-0kxp64OhgK7mhiR9kVoXsirsl4vr2iC0GT2***L5ogWNKky2aB pE9PNns2exs2qBQJGvUdrIxHYOqwer09v5gujSJN8NWxox_elP FUznrBO5wpiKI-PPG_eDSaMJBrFbfHbyeM9-830kjHtMRr6plOifLnZyEszjSG0uW1DMZ4QVtnkpv1FAToVzj8 5puTXDI3NGYx-HIgCGa7hpbukxBZpFDuXdUj2ruDZcw1W6XZKj2tPFZhfiA5Rsu erIHELXmZPOxKERR6DWjVoMP7jKFVhcPY8r9aDw5wrTpgvR9b6-76erQq3Bv9bU7Y8hJYqxOgNxyw5p3tkFM84XNaRUC2UO0AKiq-LdZyVH_6MsvmxXtB_I_LuBi65FBEzsUA0-ewHKFsgj7XTe27xRQJ_bPKby7QVb3bR24ZZKYPnuGV2LONjYi6 hR8mTndIjCKgMGL7R3YFTXtmcQDwQqQoC5dUprYjfvg732hKfS IxdqKPtiG5OC_x6u2v0PWG2Zt6UGpEFfGFJ0hsLs89AZvCIH1s w_HQAXPbBbpM=w725-h966-no[/IMG]
The Following 3 Users Say Thank You to glamcem For This Useful Post:
Cole (04-18-2017), funwheeldrive (04-18-2017), LOLS2K (04-18-2017)
Old 04-18-2017, 03:25 AM   #121
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Stock tires were chosen on purpose to give a tail happy nature to our cars and keep the grip limits low. There are very few sport cars that come like this from the factory. The majority come with performance tires. Not with turing tires, not with low resistance tires. We should make comparisons on grip levels within the same context, otherwise we should not make comparisons!
The Following User Says Thank You to nikitopo For This Useful Post:
DAEMANO (04-18-2017)
Old 04-18-2017, 03:36 AM   #122
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
For the sake of the accurate data comparison, I think it's best to talk about the street legal cars
I just questioned if such high end technologies (magnetic, air type) can give any real performance advantage. For sure they can offer other advantages like to combine comfort with sport characteristics, but I think this was not the context of the discussion here. Also we should not think about race cars as something very distant from us. A lot of new technologies are tested first on such cars and then transferred to the street legal cars.
Anyway, it looks that you are very happy with your Camaro and I am not here to convince you that this is not the case. Drivers confidence is one of the most important aspects and it looks that you can work with the new car much better.
Old 04-18-2017, 12:33 PM   #123
funwheeldrive
The Nissan GTR is a pig, but I heard it makes you feel like a superstar when you're behind the wheel. Just because a car is bigger and heavier doesn't mean it's more difficult to control necessarily.
I need to start actually driving some of these cars.
The Following 2 Users Say Thank You to funwheeldrive For This Useful Post:
Lynxis (04-18-2017), Tcoat (04-18-2017)
Old 04-18-2017, 12:51 PM   #124
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
My BFF owns a GTR and you're absolutely right about feeling like a superstar when you're behind the wheel. Both on and off the track.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
Old 04-18-2017, 01:38 PM   #125
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
An SS
Originally Posted by Summerwolf View Post
Wow....and none of those are any version of a 1LE car.
Like stated the 1LE SS is a 1.1 lateral G vehicle. I'm actually impressed with a BASE MODEL SS being able to do .97G, still higher numerically than a twin on good tires (according to your two magazine sources).....
An SS is a V8...lol they were talking about a V6... so FAIL...
Jaden
Jaden is offline   Reply With Quote
Old 04-18-2017, 01:43 PM   #126
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
It's the "age of the micro-processor" computers allow the laws of physics to be stretched further than ever before. The Camaro E-Diff is a much bigger part of this conversation than most realize as well.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 3 Users Say Thank You to Deep Six For This Useful Post:
funwheeldrive (04-18-2017), strat61caster (04-18-2017), Tcoat (04-18-2017)
FRS then Camaro SS 1LE? stock Scion FR-S / Toyota 86 GT86 General Forum 25 05-26-2016 05:07 PM
Camaro for FR-S whamslam3 Other Vehicles & General Automotive Discussions 26 06-18-2014 09:53 AM
frs or camaro failingpig FR-S / BRZ vs.... 77 02-22-2014 01:58 PM
FR-S vs 312 hp Camaro? Gill FR-S / BRZ vs.... 32 03-31-2012 08:56 AM
