#15 |
Drives: 86 GTS
As said, HEL have a VERY poor record for 86 brake lines, they know exactly what the issue was and did not issue a recall when they should have. No one in Qld uses them now, well at least on track.
| The Following User Says Thank You to 86•BRZ For This Useful Post: | ysu (04-11-2017) |
#16 |
Drives: 2013 Subaru BRZ
#17 |
Custom User Title
Drives: Asphalt FR-S MT
I'll be the oddball and say that SS lines don't really add anything to the brake system. If it does, it's so miniscule that you can't tell. Now talk about ANY other part in the brake system, and yes you will notice it. Lines....nope. I do have SS lines installed on mine. They were given to me in good faith and I wanted to show appreciation.
#18 | |
http://www.autospeed.com/cms/article...e-Lines&A=2679 They tested the braided and rubber lines by pressurising them and the braided hose expanded less than 1%, and the rubber hose expanded 1.7%. TLDR: The difference is SFA. |
#19 |
Sorry to re-up, I have the same issue with Goodridge lines, how did you solve?
#20 |
Thanks
When installing lines i found it better to spin the line itself onto the hardline. Especially if rust is a concern. The stainless lines have the advantage of a hex on the end so you can hold the hard line and tighten the flexible line. Make sure you are not attached to the caliper while you do this.
Another useful thing I found is using a crowfoot line wrench, if that is what it's called. It's a set of 3/8 crowfeet line wrench ends fit on your 3/8 ratchet. They fit much snugger and higher quality that your harbor freight double end line wrenches and don't flex.
#21 |
It seems that Goodridge are not compatible with Brembos...
#22 | |
Depends on the vehicle, and the age of the OEM lines. I could barely feel the difference between stock lines and SS lines when I put my first set on this car (it was under a year old at that point), the MC brace also made a barely noticeable difference. Less compressible pads made by far the most difference in pedal feel. I still like the braided lines and MC brace, but if you were to put three cars in a lot and guess which mods each had, I bet most people would pick the one with stock lines and less compressible pads as the best feel vs stock pads and SS lines with MC brace.
| The Following User Says Thank You to wparsons For This Useful Post: | Ultramaroon (12-05-2018) |
#23 |
Drives: 2016 Subaru BRZ
I have SS lines and a MC brace, I couldn't tell a difference when I switched to SS lines at all, as for the MC brace I can feel a slight difference if I am hitting the brake pretty hard. Used to have a Mitsubishi with a cable clutch that ended up warping the firewall due to age.
| The Following User Says Thank You to Trueweltall For This Useful Post: | Ultramaroon (12-06-2018) |
#24 |
fabulous
I'm glad that I haven't messed with my brake lines. I bet the big difference I've felt in other owners' vehicles was, as @wparsons wrote, due to stiffer pads.
#25 |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Interesting post!
My car is 90% track, 10% drive to and from. From safety standpoint (car is 2015 with 37K miles, I'd say 3K track miles) was going to change the lines (no leak or such just precautionary as I build the stock calipers after 2 years, dust boots are shot). Why? In my previous car had the caliper freeze and OEM line get sweaty hence.... What is a good/realiable steel like should I look at as replacement? Have heard good things about Goodrich and there is Brembo as well. Thanks, Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
#26 | |
#27 | |
Drives: 2015 Firestorm 08/05/15
| Stainless Steel Brake Line Brands | Michael | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 03-13-2017 07:05 PM |
| FR-S/ SBRZ (2013 Al) -PTUNING Braided Stainless Steel Teflon Brake Line Kit!! | Freddy@PTUNING | Brakes, Suspension, Chassis | 33 | 12-07-2013 03:01 PM |
| 2005 STI Brembos Powder Coated, Hawk HPS Pads, Stoptech Rotors and Braided Brake Line | Jamifra | Brakes, Suspension, Chassis | 10 | 10-29-2013 11:31 AM |
| ~D3PE Stainless Braided Brake Line System~ | Evan@D3PE | Brakes, Suspension, Chassis | 6 | 06-12-2013 04:40 PM |
