Old 03-28-2017, 01:06 PM   #1
Oahu86
Drives: Toyota 86 2017
Post Difference between FR-S and Toyota 86 Gauge/Instrument Cluster Warning Lights
I LOVE my U.S. version 2017 Toyota 86. Except the Gauge Cluster Face (white tachomenter). Therefore, I wish to swap out my Toyota FR-S/86 Gauge Cluster Face for one that has a black tachometer (like the BRZ). I can order a custom face (overlay) to do this, but I will need to update the current 2013-2015 available overlays to match any additions/deletions (changes in position) in warning lights that have been made between the 2013-2015 U.S. FR-S and the 2017 U.S. Toyota 86.
To this end, could some generous expert out there please enlighten ignorant me as to the differences in the 2013-2015 FR-S and the 2017 Toyota 86 Gauge Cluster warning lights including number, type and position of warning lights on the 2017 Toyota 86 Gauge Cluster?
Any information would be much appreciated.
Oahu86
Oahu86 is offline   Reply With Quote
Old 03-28-2017, 01:27 PM   #2
Oahu86
Take a look in the 13 manual (link attached) and compare to the locations of your lights.
Old 03-28-2017, 02:10 PM   #3
Oahu86
Thanks Racecar,
I took your advice and derived the following answer from the owners manuals:
I think that two warning lights have been added above the tachometer (one on the left and one on the right)? The one on the left is "Hill Start Assist Control ON Indicator" and the one on the right is "unknown" (that is, I don't know what it is and cannot find reference to it).
I would really appreciate it if someone with access to/first hand knowledge of, both the 2017 T86 and 2013 FR-S could confirm that these are (1) the only changes (additions/deletions) that have been made, and (2), what the "unknown" is (note that I have referenced the 2017 T86 Owners Manual and cannot find this "unknown" type on the right) warning light in it.
Best regards,
Oahu 86
Old 03-28-2017, 03:20 PM   #4
jcrAggie2020
jcrAggie2020's Avatar
Drives: 2013 firestorm frs
http://www.ft86speedfactory.com/magn...l#.WNq3CnpOnqA
This cluster at a joke of a price 😂😂😂 anyways it says it doesn't fit 17 86 special edition models
jcrAggie2020 is offline   Reply With Quote
Old 03-28-2017, 03:54 PM   #5
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
2017 Toyota 86 Gauge/Instrument Cluster Warning Lights.
Note the 860 model has a different gauge cluster.
Old 03-28-2017, 07:59 PM   #6
Oahu86
TRD-X,
Thank you very much. Extremely useful.
I believe that the illustration of the instrument cluster face (CTH22AW154) that you have helpfully provided above is from page 161 of the Toyota 86 owners manual: http://www.toyota.com/t3Portal/docum...f/OM18069U.pdf
The manual also provides the text "...the following illustration displays all indicators and warning lights illuminated..." on the same page as this illustration (p. 161).
I thought that this would provide all the information needed to order my custom instrument cluster overlay.
Unfortunately, the same manual provides a slightly different instrument cluster face illustration (CTHPIAW174) on page 426. The illustration on page 426 of this same manual has one additional indicator light above the right hand signal indicator. This "additional" indicator light looks like an "exclamation point inside a lighted light bulb". There is no other reference to the meaning of this "exclamation point inside a lighted light bulb" in the manual which further deepens the mystery.
Here is an enlarged photo of a 2017 Toyota 86 cluster face showing the same "additional" indicator light that looks like an "exclamation point inside a lighted light bulb" as indicated on page 426 of the manual.
This additional indicator light seems to be an "exterior light fault" indicator light (#23 below) assuming that it does actually exist on the 2017 Toyota 86 instrument cluster face:
http://i.dailymail.co.uk/i/pix/2013/...79_964x757.jpg
Could this additional indicator light be the result of options such as fog lights?
I have not taken possession of my ordered car yet, and will not do so for several months. I would really appreciate it if someone could help me clear up this mystery by telling me if this additional indicator light "exclamation point inside a lighted light bulb" actually exists on the 2017 Toyota 86 instrument cluster face (as on page 426 of the manual) or if this is an error in the manual itself.
I need to confirm this before ordering a custom instrument cluster overlay and I have not taken possession of my car yet so that I cannot do the same myself at this time.
Any help to solve this little mystery will be very much appreciated.
Sincerely,
Oahu 86
Old 03-29-2017, 11:03 PM   #7
Oahu86
All,
Thank you for your helpful hints and suggestions.
After a little research, it looks like the Toyota 86 Manual Gauge Cluster Panel can be confirmed as follows:
I only have one question left: what does the indicator in the red box (above) actually indicate? It does NOT appear to feature in the 2017 Toyota 86 Owners Manual(?). From other sources (http://i.dailymail.co.uk/i/pix/2013/...79_964x757.jpg) it appears to be an "exterior light fault" indicator(?).
Can someone who has already received shipment of their 2017 Toyota 86 confirm this indicator...and what it is?
Thanks in advance,
Oahu 86
Old 04-07-2017, 11:22 AM   #8
Rakshaa
Milton 86 Club
Rakshaa's Avatar
Drives: Lexus IS350, GT86, Mini Cooper, CBR
All,
Thanks in advance,
Oahu 86
I don't have a 2017, but I can confirm that the indicator is for an 'exterior light fault' as my wife's Mini has the same warning light for that reason.
Rakshaa is offline   Reply With Quote
Old 04-10-2017, 10:05 PM   #9
Zhangy
Drives: 2015 FRS
why are you so picky man? no one's gonna judge for a white gauge face... don't bother swapping, it's gonna cause more problem than it solves... do better things with your money
Zhangy is offline   Reply With Quote
brz, fr-s, gauge cluster, toyota 86, warning lights
# Lexus F-Sport Style Instrument Cluster Gauge Face (For 86, FRS, BRZ) # JW89225 Interior Parts (Incl. Lighting) 7 09-12-2016 03:44 PM
Changing Instrument cluster/HVAC lights? xFury Cosmetic Modification (Interior/Exterior/Lighting) 2 12-11-2015 01:26 PM
Replacing Gauge Cluster Lights Zan Southwest 2 04-15-2015 10:09 AM
WTB Instrument Gauge Cluster Dimmer Switch Wire Harness Arcadien Angel Want-To-Buy Requests 1 04-12-2015 09:58 PM
F/S: FR-S instrument cluster MissDeb Audio/Visual, Electronics, Infotainment, NAV 5 04-08-2014 04:02 PM
