Old 03-24-2017, 09:10 PM   #1
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
10 series/monogram/rs1 oem hid headlights
Anyone have experience with one of the LEDs going out on the drl strip? Hoping it doesn't need a full replacement
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 03-24-2017, 11:00 PM   #2
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Mine went out when I first bought the car. Check if your power adjusting mirrors work. Mine didn't and replacing that fuse fixed both the mirrors and the drl. Why they are connected i have no idea.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following User Says Thank You to Detroiter For This Useful Post:
mmmcambelsoup (03-26-2017)
Old 03-26-2017, 03:26 PM   #3
mmmcambelsoup
Thanks I'll check that out but were your entire drls out? Mine is just a single led out of the entire strip. So if still comes on, just looks like one of the leds are out on the drl strip.
IG: @Lucky_FatPat
Old 03-27-2017, 01:08 PM   #4
Detroiter
Detroiter's Avatar
Of shit, I must of missed that. Mine were completely out so I'm not sure if it'd be the same problem then. Good luck getting it fixed!
Raven
Old 03-27-2017, 01:43 PM   #5
KnightRyderx2
Drives: 2014 FR-S
If it is just that one LED out then that LED is bad. The circuit for the LEDs isnt all that complicated. I cant say what LEDs Toyota used but I'm sure that info is some place, just takes some research.
If you take the car to the dealer they will tell you they will have to replace the headlight, if the car is not under warranty that is a few hundred dollars. If it is still under the warranty, I would advise you to take it in as it should be free.
If its not under warranty anymore, its an easy fix. Although you will have to open the headlight to get to the LED to replace it. Do some research into what LEDs Toyota uses and see if you can get a hold of those. If not you can use something with similar specs. Open up the headlight, get to the LED, and remove and replace. Pretty easy. I would say the hardest part would be the research to find out the LED they use.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
mmmcambelsoup (03-27-2017)
Old 04-04-2017, 09:13 PM   #6
ENVJFRSH
Drives: 2013 Scion FRS
Anyone have a clue where i can get a pair of oem brz xenon headlights? Thanks for any help
ENVJFRSH is offline   Reply With Quote
Monogram series headlights on a FRS DCStorm Scion FR-S / Toyota 86 GT86 General Forum 15 12-07-2020 05:59 PM
Monogram/ Series 10 Headlights fitcious Cosmetic Modification (Interior/Exterior/Lighting) 130 06-10-2016 11:07 AM
DIY $5 reversible always-on for FRS 10 Series, Monogram, RS 1.0 or JDM headlights LXXXV1 DIY (Do-It-Yourself) Guides 15 02-29-2016 02:44 PM
Monogram Series Headlights. SOLD JDis3 Exterior Parts (Aero, Lighting, Etc.) 6 11-03-2014 01:16 AM
FS BNIB Series 10/ Monogram Headlights ecda Exterior Parts (Aero, Lighting, Etc.) 5 09-30-2014 07:28 AM
