#71 |
Drives: 2013 BRZ Limited
So far so good. Issue still solved. Don't fuck with window tension. It definitely is the seal.
| The Following User Says Thank You to xcelir8brz For This Useful Post: | alrashwa (11-30-2012) |
#72 |
Drives: BRZ DGM Limited
Quick suggestion...I have always used Turtle Wax Total Ice interior Care on the seals around my windows long before getting my BRZ. I have found that it allows the glass to move easier and quicker over the rubber seals. Have done it with the BRZ too and have no issues with the windows, even in sub-freezing temps:
http://www.turtlewax.com/product-detail.aspx?prodid=92 |
#73 |
would you be able to fix the problem by just adding adhesive to where the seal is getting pulled? or is it too late b/c the seal has already been deformed by getting pulled by the window too much?
#74 |
Mine has not pulled out yet but I did notice that on the passange side the molding was not firm up into the roof of the car as it should be. I added clear caulk between the moldings to keep the one in contact with the window from pulling out.(there is a gap between the molding in contact with the window and the next piece of molding..I applied the caulk high up between the two so it can't be seen). I also applied the Ice Total Care as I mentioned above. Has been cold and no issue so far.
#75 |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
Mine just started doing this today. The past week it's been rainy and cold. By cold, I mean about 55*F. In San Diego, that's pretty cold.
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
#76 |
Drives: '13 Argento MT FR-S
Ive had this problem since about a week or so after I got mine (June 18th). It hasn't bothered me too much because the window still seals. If for some reason it starts leaking then I'll have a major concern lol.
#77 |
Drives: 2013 Subaru BRZ
Just started with my BRZ, ~2500 Miles.
#78 |
Drives: 2013 SWP BRZ
I've noticed mine doing this for the last 6-7 weeks (only driver's side.) I thought it was temperature related but it's been 60 degrees the last two days and it's still happening just like when it was 30 degrees. It doesn't happen every time but more so than not.
I bought a product from The Chemical Guys for vinyl/rubber treating and that failed to do anything. The seals on both doors were extremely dirty which I'm sure wasn't helping anything. After cleaning them and applying two coats, it still happened. Annoys the shit out of me, since I received the email from Subaru about the reflash, I might try to kill two birds with one stone. |
#79 | |
Drives: AVO BRZ
![]() It's still happening. I'm going to ask them to change tension back to stock and replace the seal.
#80 |
Saving them pennies...
Well just noticed this on mine. Something I did notice is when I close the driver door, the window sits under the seal then goes up. Unlike passenger side window sits halfway up the seal then completely closes. I think it has to do with how far down the driver window opens when opening the door. I'll have it checked at my first oil change.
#81 |
Drives: Scion FR-s
Add mine to the list going in to check with them hopefully today.
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake |
#82 |
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
I went to the dealer yesterday to get the Recall ECU Flash and had my window seal checked also. So, my dealer tells me that I have to remove my tints before they install the new seals cuz they say it adds a level of thickness. They want to install it properly and check without the tints. I just laughed and said I would not remove my tints.
P.S. They ordered a new Fuel Pump, new right tail light, and the window seal also. Hopefully, they install the window seal with the tints still on. lol |
#83 | |
I don't lie.
Drives: AE86 Successor
#84 |
Funny my tints where installed by southeast toyota lol
| Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) | Moto-P | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 128 | 02-27-2019 08:25 PM |
| Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) | Moto-P | BRZ Photos, Videos, Wallpapers, Gallery Forum | 109 | 08-19-2014 11:56 PM |
| Driver side door handle | lordtakuban | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 06-19-2014 02:30 AM |
| Studying for Learner's Permit driver's knowledge test | PACMAN | Other Vehicles & General Automotive Discussions | 2 | 01-03-2012 12:17 AM |
| Little request: FR-S vs GT86 vs BRZ side by side photos! | EJ20 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 12-02-2011 01:53 AM |
