| FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
#29 |
Huge E85 fan!
Drives: 2016 Scion FRS
The big thing I read about on here a lot is the throw out bearing and clutch fork. I don't know if it's possible to get them checked out and inspected at a garage, but that should be in your pre-purchase inspection.
If it's been lowered on springs, check those shocks and struts out very carefully. If the car's exhaust looks a lot newer than the rest of the car, chances are it had an aftermarket exhaust- if it's header back, you really have to check for leaks in the header in case the former owner tried to re-use gaskets. The AC is pretty marginal in the really hot weather, but it works great in the cold! Have the AC system checked- don't rely on the "hey it's cold it must work" test in cooler spring temps. I shop for a car using the Torque app, an OBD2 port reader and my smart phone- you can check for things such as miles elapsed since last time the codes were cleared. Some CEL's don't pop up for a hundred miles or more (depends on how the car was driven and drive cycles). |
#30 | |
![]() ![]() Ya ya, stupid Americans.. :p |
| The Following User Says Thank You to fika84 For This Useful Post: | Tcoat (03-28-2017) |
