86WORX
Old 10-05-2018, 02:38 AM   #29
churchx
churchx's Avatar
Drives: 2014 GT86
It doesn't matter if bolts or lugnuts are used. What matters - shape of their seat, which can be eg. flat, ball shaped or conical.
So called "Tuners lugnuts" usually are 60deg taper conical seat ones, and aftermarket wheels most often are of such seats (but not always, worth checking out). Coincidentally our stock OE lug nuts ( & stock wheel seats) also are of such shape, so can be freely used on most aftermarket wheels too, unless there are some aesthetic reason or one changed wheel studs to longer ones, that won't allow to properly secure wheel with stock lugnuts due not being able to tighten them all way down because of closed end caps of nuts.
Old 10-08-2018, 12:43 PM   #30
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
I am using the OEM lug nuts on my new TS10s. they fit snug.
xenarc is offline   Reply With Quote
Old 10-09-2018, 08:49 PM   #31
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
Do the 17x9 TS-10's fit with the PP Brembos? I'm seeing the 18x8 and 18x8.5 confirmed, and I see that tire rack says the 17x8 fit the normal BRZ but not the PP. I'm not seeing any info on the 17x9, though.
Horrid_Funk is offline   Reply With Quote
Old 06-19-2019, 05:17 AM   #32
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by tfp View Post
Please confirm you've got 18x8.5 +45?
(context: http://www.ft86club.com/forums/showthread.php?t=135328 )
timurrrr is offline   Reply With Quote
Old 06-19-2019, 11:18 AM   #33
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
My enkei ts10 are 18x8 +45.
Sent from my SM-N950U using Tapatalk
tfp is offline   Reply With Quote
The Following User Says Thank You to tfp For This Useful Post:
timurrrr (06-19-2019)
Enkei 2016 Tuning Series! TS10, TY5, TSP5, T6S, TS9, TX5, KOJIN PM FOR FORUM PRICE! OAKOS Automotive Wheels and Tires 267 08-27-2018 05:46 PM
2017 with Perfromance Pack - What wheels? prattusa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-11-2017 03:32 PM
Performance Pack Brake Dust? Opie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-03-2017 12:47 PM
17inch enkei rims from brz s pack Ibanezboy21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-28-2014 07:51 AM
GT-86 optional performance-pack Ziptuning Scion FR-S / Toyota 86 GT86 General Forum 24 08-29-2012 04:00 AM
