#57 |
Drives: 2005 Toyota Camry
in case anyone is interested in buying, I've set up a vendor account to sell some in stock items.
$380 shipped in CONTUS. https://www.ft86club.com/forums/show....php?p=3328165 |
#58 |
Drives: 2018 Subaru BRZ Premium, Blue
Springs arrived, great turnaround, everything arrived in great shape!
Just... now comes the 2-3 week wait for the TRD 86 Rally parts to arrive from Japan due to the the hastles of international post ATM before I wed the two together and get things bolted on. >_>; |
#59 |
Human
Drives: 2015 BRZ Black
I ordered a set too. Great customer service, quick arrival time. no issues and everything in order.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
| The Following User Says Thank You to Spawn_Of_Creation For This Useful Post: | mav1178 (05-16-2020) |
#60 | |
https://www.post.japanpost.jp/int/in...423_03_en.html Might want to figure out a better way to send it. DHL/FedEx/UPS is more expensive but at least you are not waiting months. |
#61 | |
![]() I opted for surface, which yeah might be 2 months, but usually in my experience is closer to 1 month or so. If the wait gets too unbearable I can still put the springs on the OEM parts and rotate things around when the rally kit shows up. |
#62 | |
if for some reason your order is cancelled let me know, I can get TRD Japan stuff as well via ocean, turnaround time is 45-60 days. |
| The Following User Says Thank You to mav1178 For This Useful Post: | WolfWings (05-17-2020) |
#63 | |
| The Following User Says Thank You to WolfWings For This Useful Post: | Capt Spaulding (08-10-2020) |
#64 |
Is there any interest in the TRD rally shocks? MS260-18004
I got some pricing back, realistically we are looking at around $650 USD plus shipping for each set. Price is higher than Japanese MSRP but this is a landed price, FOB Chino 91710. If you were to buy it on your own from Japan, freight will probably add on another $200 or more if it's even shippable... Edit: probably able to combine with Chuhatsu to do around $1000 each set of spring/shock. Not sure if there is a market for this in the US but at least the products are readily available. TRD springs look to be around $1100 as a package Last edited by mav1178; 05-22-2020 at 04:42 PM. |
#65 |
Drives: 2014 GT86
But what are springrates of chuhatsu vs original rally shock springs? Are they close enough for shocks valving to match rates of chuhatsu springs? Also is diameter of springs same so that rest, like spring perches, are compatible & springs interchangeable?
#66 |
The only question is regarding the spring rates of the TRD Springs. The shocks are sold separately and there is no indication that it needs to be paired up with a specific type of spring. Even the instruction manual in Japanese does not specify this information. Additionally, this spring and shock combo does not require you to purchase specific purchase or upper mounts to install, so OE equipment is reused.
#67 |
Drives: 2014 GT86
@mav1178: trd rally coilovers & springs from earlier threads about them:
OEM vs TRD Rally Front Compression ~560 540 Rebound ~1690 1250 Rear Compression ~735 400 Rebound ~1620 1120 Spring rates (kg/mm) OEM GT86(EU) vs TRD Rally Front 2,3 4,6 Rear 3,3 5,2 |
#68 | |
To put things in more readable perspective: Code:
FRS BRZ TRD Chuhatsu
131 153 257 129 Front Spring (lbs/in)
211 195 291 206 Rear Spring (lbs/in)
560 540 Front Compression
1690 1250 Front Rebound
735 400 Rear Compression
1620 1120 Rear Rebound
Honestly laying out all the numbers like this makes me more excited, this may well turn my BRZ into a true 'grand cruiser' with the spring rates closer to the FRS but avoiding the 'riding on the bump stops' problem the twins sometimes experience, and with softer absorbers this should be very comfy. This is coming from bicycles I admit, but less compression and rebound generally means a softer ride on harsh roads, both at the expense of some grip in various situations as the wheels don't hug as tightly. Since I'm running a wheel/tire combination 10 pounds/20% lighter than stock (205/55R16) I don't need the suspension to work as hard to hug the road. |
| The Following User Says Thank You to WolfWings For This Useful Post: | Clipdat (07-26-2020) |
#69 |
This is months late I realize, since yeah shipping was hellish getting the TRD absorber set from Japan over to the US. Ended up getting here via literal courier to Hong Kong, from there into China Post and from THERE finally to the US.
Just literally picked up my BRZ from the shop and put it through it's paces, the best way I can describe the combination of TRD Rally absorbers + Chihatsu springs is "buttery smooth" and makes the ride a bit quieter as well as a lot easier to get in/out of the car shockingly. I'll take some measurements later once it's settled out fully, but it's a well over an inch of additional height all around with that combo freshly installed. If anyone spots this and wants to take theirs to an even better daily-driver setup, especially if you got one used so it has worn-out suspension right now, this combination is really, Really, REALLY good IMHO. |
#70 |
So I've driven this for another couple hundred miles now, had a chance to try a few places I know well.
Biggest change? The additional suspension travel and body roll feels like it lets the car properly 'squat and scoot' so it's noticeably harder to get traction control pissed off at me. I can WOT while turning up onto highway onramps and get all the way through 1st and 2nd without the tires being exceeded, and I'm not running anything remotely sticky. Likewise while there's more 'body roll' it's way more controlled. If feels like there's time to actually 'catch' the roll and work with it, instead of getting tiny wiggles that suddenly upset things. Not sure if it's just the added split seconds of travel time, or the softer + progressive bumpstops from the Chihatsu springs doing it. I haven't had a chance to experiment on gravel/dirt yet, that's tomorrow, the above is all asphalt. And again I'm running a straight-up 'foul weather' touring tire (Vredestein Quatrac 5, 205/55R16's), so before I could spin rubber in 2nd if I turned off TC and tried. But I'll definitely say these springs and the added height make a huge difference on making the toyobaru more relaxed to drive. It's far less "over-caffeinated chihuahua of sports cars" now. |
| Where to Lift with Two Post Lift? | Don Ivey | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 08-18-2022 09:51 AM |
| Anyone in the DMV with a lift? | Rifle | Mid-Atlantic | 5 | 06-06-2016 04:35 PM |
| EZCarLift Easy car lift portable super easy car lift | bren5279 | Mechanical Maintenance and Tools | 16 | 09-11-2015 02:57 PM |
| don't lift | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 08-17-2012 12:51 PM |
