#29 | |
#30 |
Drives: 2017 TOYOTA 86
#31 | |
It was not the error codes, it was that the commanded values for intake cam position that would not clear/reset. Reflashing did nothing. Yes, it was likely a physical problem with ECU rather than a software issue. The owner of the vehicle had been driving it around with this issue for awhile. If it was addressed as soon as the problem started, a reflash may have solved the ECM issue, but it would not have solved the mechanical issue with the cam gear. That being said, I do not know if the ECM problem caused the mechanical issue or vice a versa. |
#32 | |
#33 | |
Drives: '15 Subaru BRZ
Nope. The mechanical pieces take a poop, after OCV and/or sprocket replacement the ECM cannot "learn" the values of the new parts. The first time Techline told us to replace an ECM we didn't believe them. They were right. Makes no sense but Subaru hasn't come up with any kind of software fix, they still tell us to replace the ECM. TSB 02-163-16R explains how to diagnose AVCS codes. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Ragin Gti For This Useful Post: | fika84 (03-10-2017) |
#34 | |
No, the new ECM would just get ruined due to the problem with the cam gear. Last edited by DirtySouth86; 03-10-2017 at 06:15 PM. |
| The Following User Says Thank You to DirtySouth86 For This Useful Post: | fika84 (03-10-2017) |
#35 |
Chapter One: The first chapter.
So I had P0018 pop up just after installing a header, had the battery disconnected during the several hour install. Reset the ecu several times which would fix it for 2 drive cycles then it would pop up again. Took it to the dealer who told me problem must be with the header. I pretty much said that was bull. After taking it in several times they finally agreed to run diagnostics on it and told me I would have to pay a fee if they couldn't find the issue. Feeling confident I knew what was going on I said ok. They came back and showed the the ECU VVT Learn values were out of range and could not be "unlearned". This fits with the cam phaser problem. They replaced the cam phaser and the ECU. Problem fixed. Chapter 2: What is causing this? Now do I think something happened from putting the header on that caused the failure? No. Plus I was not driving it hard on the way home because it was basically straight piped and WAAYYY TOO LOUD. When they told be what was wrong with the cam phaser they said a part came loose on the back and was rolling around in there. If you search the other threads there are pictures of this. From my research, which it is really hard to find actual answers or diagrams of this part, I think this is something related to a "detent valve". Our engines use a newish borgwarner cam phaser with mid position lock. Prior to this, cam phasers would have to figure out if they were going to advance or retard all the time, even at start up with no oil pressure. However, with mid position lock they can lock at 0 when not engaged, like at startup. I think there is a mechanical failure going on with this detent valve and not allowing mid position lock to engage. When I still had the code on I did a lot of data logging. Sometimes the affected came would swing to its full retarded position while the good cam would go to 0. Its not a big deal initially. However, if you reset your ECU, the ecu has to calibrate the VVT system which I believe it does with mid position lock engaged. Since one side cannot lock at 0 it gets out of wack and is broken forever. So I think the mechanical failure had already happened at some point before the code happened. But when the ecu was reset it could no longer calibrate the vvt system until the cam phaser and ecu had been replaced. Just my two cents on the issue. If anyone has any input or noticed something I said wrong, let me know. |
#36 | |
I think you are definitely on the right track. The one we just repaired had that problem with the cam gear / phaser. |
#37 |
Drives: '14 SWP BRZ
#38 |
Drives: '14 SWP BRZ
So, guys, here's my update.
Subaru of Concordville has been absolutely awesome. They're saying and have said since day one that the header is not going to void the warranty. First attempt was to clear the code and flush the oil + oil change in hopes of clearing any "blockage". This was unsuccessful. As per the Subaru Techline, they are now replacing the cam gear and timing chain and everything that involves, covered under not just the powertrain warranty, but the 3yr 50k mile emissions warranty. This, hopefully, will be the fix. However, after reading this thread I'm seeing that I will most likely need a new ECU? I, also, was not driving my car hard after the header install leading up to the engine light that came on the same day. I had freshly painted the headers in ceramic heat paint and was going through a cycle to cure the paint which required normal driving. I'll keep everyone updated |
| The Following User Says Thank You to giorgi0424 For This Useful Post: | sato (03-21-2017) |
#39 | |
#40 | |
Huge E85 fan!
Drives: 2016 Scion FRS
#41 |
Drives: '14 SWP BRZ
Should be getting my car back tomorrow. Stopped by the dealership today to check on the car, it was already reassembled (now just waiting on a drive cycle and windshield replacement) and the tech who worked on the car brought me into the shop - which was awesome of him to offer - and showed me the malfunctioned cam sprocket. He pointed out that the little metal plate which covers the spring in the cam sprocket had been detached (honestly have no clue what it does), and that was the cause of the problem. Apparently, it's that fault that causes this problem. I asked if Subaru has an updated cam sprocket which addresses that issue and he said they don't, so hopefully this isn't something that happens again.
#42 |
Drives: BRZ DGM Limited
I think someone on this forum posted a pic of that little plate on the spring on the cam would stick open causing some of these issues. I wonder why it happens?
| Tags |
| camshaft, crankshaft, header, p0018, warranty |
| Wheel Hub causing hum? Warranty covered? | HachiRo | Issues | Warranty | Recalls / TSB | 3 | 04-22-2016 12:43 AM |
| Experiences with Subaru Powertrain warranty? | armstrom | Issues | Warranty | Recalls / TSB | 17 | 04-03-2016 01:01 AM |
| Headers and Powertrain Warranty? | smg1138 | Engine, Exhaust, Transmission | 5 | 07-27-2015 02:27 PM |
| "This repair is not covered by Subaru's limited warranty" RE: 4th gear tranny grind | DoomsdayJesus | Issues | Warranty | Recalls / TSB | 108 | 04-29-2014 02:15 AM |
| Should this be covered by warranty and can Subaru repair this? | brzadmir | Issues | Warranty | Recalls / TSB | 16 | 08-01-2013 01:08 AM |
