#15 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
Only reason i'm asking is i'm switching to a different kit in the summer and i was wanting to do a local custom tune but didnt want to pay for the license again.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
#16 |
Ohne Titel
Drives: 2017 BRZ PP ISM
The license is on a per car basis. You pay the $300 once for your specific car.
My tuner provided the cable and dongle. Thanks @Neal. I paid $300 for the license, and another $285 for the flash and go tune (Delicious Flash and Go tune sale price). |
#17 | |
Lowly Cartuber
#18 |
Ohne Titel
Nope. NA, but tuned for a catted header, catback, intake.
#19 | |
Drives: UK GT86
"License": Flashed to the ECU as part of the 1st tune flash, this then allows the ECU to be flashed by ECUtek software. Dongle: This is the PC/laptop software ID to allow you to run ProECU. Cable: Dumb equipment but required to flash with ECUtek. There is no correlation between the 3. Tuners usually code (lock) tuned ROMs to dongle IDs so you need that to be able to flash and datalog. If a ROM is unlocked then any dongle or cable can flash to any licensed ECU. The license will be remotely added to the dongle ID that you plan to do the 1st flash with, this is obtained by doing an ProECU update. This is the only tie in between a license and dongle, so it's only relevant on the first flash of that ECU. For example a tuner may buy 10 licenses for their dongle ID. These get used up on every 1st flash of an ECU but you can flash any licensed ECU in between and they are not used up, it also doesn't matter if they were the original flashing device.
.: Stealth 86 :.
| The Following 2 Users Say Thank You to Kodename47 For This Useful Post: | jasonojordan (03-02-2017), TofuJoe (03-02-2017) |
#20 |
Ok
You need an Ecutek Cable\dongle kit to flash an Ecutek tune You also nedd on ecuteck licience for each ecu you want to flash, this is a one off cost and licience stayes with ecu, and you can flash as many times as you like to the ecu once it has licience installed. You can use same ecutek cable kit to flash multiple cars as long as eac ecu in car has licience. The dongle allows you to run the ecutek software on the computer, it can be instalked on multiple computeres but it will only run if the dongle is plugged in. Ecutek tunes you buy from tuner will be licienced to your dongle id , so they can only be flashed by your dongle, you cannot use the tune with a different dongle id, unless its re licienced to that dongle or an open tune . you cannot read out ecutek tunes with an ecutek cable kit with standard software. It will only read out roms in special fornat that you send to ecutek like for a new rom calibration id. |
#21 | |
Drives: UK GT86
.: Stealth 86 :.
#22 |
Drives: Late 2014 Subaru BRZ
Also noted if you only care about logs and not making chnages yourself, you can always get the new ECUTEK Bluetooth dongle.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| Tags |
| cable, ecutek, license |
| AVO Basemap | handsomegirl | Forced Induction | 3 | 07-20-2016 09:23 AM |
| Ecutek Turbo basemap | handsomegirl | Software Tuning | 13 | 07-15-2016 02:38 PM |
| Question for the the 2014 Brz Nav Owners (BT Question) | jbsali | Electronics | Audio | NAV | Infotainment | 3 | 07-16-2014 12:41 PM |
| Switched to ekutek forgot to divorce my openflash tablet. | Rocket.BRZ | Software Tuning | 2 | 07-08-2014 06:17 PM |
| BEspoke question and rattle question | bdanisi | Electronics | Audio | NAV | Infotainment | 2 | 01-30-2013 03:11 PM |
