#29 |
Brett
Drives: ‘94 Supra
Just to clarify. The clunking when initially putting the car into gear wasn't what I was trying to convey. I don't want to cause any confusion. We're all here to help one another...
The clunk/ clank I am hearing is from 1-2 and 2-3 once gas is applied. What I've gathered from this thread is that there is slack between components and the clunking/ clanking together of those components is to be expected with a MT RWD FRS/BRZ. |
#30 |
Drives: 2016 Subaru BRZ
Might be the LSD/SC? Are you turning when it does it?
Lay off the throttle, hot rod! |
#31 |
fabulous
That ain't right. Get it checked.
#32 |
Brett
Drives: ‘94 Supra
Haha. It's random at times. On the straights, or a turn. It's not a very loud sound. I hear it mostly when the windows are up, and both A/C and radio are off. At that point you can hear pretty much everything going on with the car. When it happens, it's under a light load. I don't drive my BRZ very aggressively, especially on my daily commute.
#33 |
Brett
Drives: ‘94 Supra
#34 | |||
This^ It is just the LSD doing it's limited slip job. Again nothing to worry about.
#35 |
fabulous
Haha... ok. Going back and rereading your OP I didn't want to be the guy that dismisses an odd sound.
#36 |
Brett
Drives: ‘94 Supra
| The Following User Says Thank You to DaBoBo21 For This Useful Post: | Ultramaroon (02-28-2017) |
#37 |
Drives: 2015 Lightning Red BRZ
The driveline slack on my last car scared the crap out of me at first, but it was my first manual RWD. I still think it was more than normal, but never had any issues because of it. The brz is nothing in comparison. You get used to it and will probably start driving better to minimize it. :-) The clunk from neutral to first and first to second still happens no matter how hard I try.
Sent from my SM-J700T using Tapatalk |
#38 |
Brett
Drives: ‘94 Supra
Metal On Metal While In Gear
Hey guys.. Me being in the military, no question is a stupid question. Over the last 3K miles or so, I've noticed that when I'm next to a large surface (like a wall or median), I can hear what sounds like metal on metal rotating against each other. It does not happen all the time, but recently it has become more noticeable. I hear it a lower speeds (15-30 MPH), and it's pretty loud. It's made me a bit worried that it could be my flywheel/ pressure plate or something inside the clutch assembly. Like I have said before, I do not drive this car hard, and I've only put 5400 miles on her over the past sevenish months.
![]() Could this be something with the clutch/flywheel/pressure plate? Maybe something unevenly worn? Or not adjusted correctly? Where are you Humfrz? lol |
#39 | |
Brett
Drives: ‘94 Supra
Just to add, the car is driving great. Shifts are good, engagments are smooth, so no issues there. Just want to pin point what this noise is. I know the TOB is an issue with these things, so maybe that could be a possibility? |
#40 | |
Should you start to have more symptoms of an issue than just a noise then start to look for issues but every single noise does not mean their is a problem. These are one of the noisiest cars I have ever driven but it is just weird sounds not signs of impending doom.
| The Following User Says Thank You to Tcoat For This Useful Post: | DaBoBo21 (03-07-2017) |
#41 | |
Brett
Drives: ‘94 Supra
| The Following User Says Thank You to DaBoBo21 For This Useful Post: | Tcoat (03-07-2017) |
#42 |
They sound like old Russian farm tractors. I just turn the radio up and ignore the weird sounds and haven't broken a thing yet.
| Automatic Transmission: Loud Clank | Moshpit37 | Engine, Exhaust, Transmission | 5 | 05-23-2015 08:21 PM |
| Clank from suspension/give in steering wheel over bump | Shady195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 09-09-2014 09:15 AM |
| Rear driver side clank and click | spyingwind | Issues | Warranty | Recalls / TSB | 11 | 04-05-2014 12:26 AM |
| Engagement Ring | Hix | Miscellaneous | 7 | 03-07-2013 03:28 PM |
| Engagement... so expensive. | merlin2111 | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 08-02-2012 10:55 PM |
