#43 |
Drives: BR86
True & that's fair enough.
#44 |
86DESU
Drives: 86 GTS, S13, CB9
I'm putting the door stabilisers in because I've owned plenty of cars with frameless windowed doors (Toyota TA46 Celica, RA40 Celica, RA60 Celica, Nissan Silvia S13) and a few with framed windowed doors (Nissan Gazelle S12, Accord, few others) and dealt with a few more (AE86s for instance) and frankly, frameless windowed doors sag. They sag like a bitch. The hinges wear out-- Then the catches misalign and it's an arse bastard to close the doors... Anything that will help stop them twisting against the hinges? I'm all over that.
#45 |
Drives: GTS 86
How much are they?
#46 |
Akina Speed Stars
#47 |
Drives: 86 GTS White
I got these door stabilisers in the mail earlier this week. Before I go on, I would to strongly suggest that:
No one try to install these themselves unless you have the proper tools and experience. This is definitely not a DIY job as I quickly found out. First off, I was this close to fucking up so bad to warrant a $500 repair job. I used an electronic impact driver as suggested to loosen the very tight screws. This did not work. What happened instead, was the bracket that's welded on behind the panel bent backwards! =S I noticed this and thought, "Ok enough, I'm going to the shop." Tried to screw the bottom screw back in but it wouldn't catch on to the bent bracket. Tried to close the door and the door wouldn't close. I was sweating buckets by this point. I managed to bend the bracket back in to place enough so I could just barely get the screw in. The door closed (just...) and I drove to my local panel beater. After leaving the car there for a few hours, he calls me back and tells me just how close I was to not being able to drive it all weekend. =( They managed to repair the bracket and install my new TRD stabilisers. He didn't even charge me! I bought him a 6-pack on the way back there. If anyone's looking for a Smash Repairer around the North Shore area, I recommend AutoTech Artarmon. Good bloke there. With regards to the actual effects of these things, the door does feel more solid. The door closes very firmly without shaking as it hits the body. How much has the handling improved? Very slightly if anything. But this could just be my wishful thinking. Bottom line: My suggestion would be to avoid this whole mess. For the same price, go and buy yourself a strut brace. |
#48 |
Drives: BR86
Geee, they must tighten the fuk out of things @ the factory, it shouldn't be that hard !
#49 |
Drives: Toyota 86 GT Thunder Silver MT
It's hard.. even removing the stock exhaust was a bit*h for them due to how tight it was bolted.. but it does show the cars sturdy..
Toyota 86 GT Thunder Silver MT - 22.06.12 ♥
#50 | |
A six pack? gee i thought i was going alright when i bought them a slab haha
2012 Toyota 86 GT Thunder Silver
#51 | |
Drives: 86 GTS
Personally I think it's a good little mod, in conjunction with some other stiffening - engine bay bracing and underbody. |
#52 |
Guest
Posts: n/a
I installed a set of these last night. Not too difficult with the right tools and I am no mechanic. I found the screws came out fine with a phillips head bit used in a socket wrench. Much more gentle than an impact driver too so less chance of screwing things up. Can't imagine doing it with just screw drivers though.
#53 |
The panel beater i went to tried an impact driver and had no success, he was banging it really hard too, in the end he had to use a ratchet with a long arm for more torque, surprised he didn't strip the bolt this way though.
#54 |
Drives: 86 GTS
Impact driver to loosen them (2 hits each bolt) then driver bit in a socket with a longish handle. I agree you can bugger them up - but impact driver is only to get them started turning not to get them all the way off.
It's understanding how an impact driver is supposed to be used. |
#55 | |
86DESU
#56 | |
Seņor Member
![]() You owned a TA64? With a 4T-GTE? That's a rare car! Back on topic now.
1974 TA22 Celica
2013 86 GT |
| Reviews on the TRD Door Latches/Stabilizer | RYU | Cosmetic Modification (Interior/Exterior/Lighting) | 84 | 04-08-2022 06:41 PM |
| Anyone else thinking about the door stabilizer? | russv | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 04-10-2013 01:09 PM |
| Door Assembly | Lefty | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-22-2012 01:58 PM |
| out the door pricing | wallace03 | BRZ First-Gen (2012+) -- General Topics | 6 | 06-12-2012 02:30 PM |
