#29 |
Drives: hyper blue
sure...it should actually make more noise in a corner and a light application of the brakes will center the axle and change/lessen the tone.
looking at the parts diagrams, the 16-17 models have a newer part number for the bearing which may relate to 17" rims. just need to type in your vin. stateside 120 or 140 usd but from the price you posted on your toe arm there may be vat penalty. if the belts are separated in the tire, you will feel it at very low speeds ie less than 4-5mph if it where my car, I would just swap out that bearing, use that rim as a spare and get it aligned. your car being new, the bearing assembly should come out relatively easily. 5 bar rear set ups have a gimbal (pillow ball in Fuji speak) type bushing where the lower control arm meets the knuckle. I am not sure if they are liquid filled on this model but look to see if anything is leaking. (my old Tribeca has the same type linkage) I had a car shipped 800 miles a few years ago. the front tapered bearing races got puckered because they where not spinning while being impact loaded from the bumpy ride and the double row on rears started making noise within a 1000 miles from the same shock loads. |
| The Following 2 Users Say Thank You to thomasmryan For This Useful Post: | allowe (02-24-2017), Ultramaroon (02-24-2017) |
#30 | |
Wow thanks for that useful reply!!! That's actually exactly what I'm planning to do. My concern now is the knuckle if it's bent or not. I'm Hoping I can get a hub and bearing assembly together. I just cancelled the order for both, Guna look for them together. Also, I'm changing the rotor to be safe. Hey, is it safe to change just 1 rotor? I don't mind doing the other but it's an extra hour or two and I got a super busy schedule Sent from my iPhone using Tapatalk |
#31 | |
Drives: Track preped NA FRS
I found a shop that prepares cars for mostly race and rally, their rates are less than dealerships, they get things done fast and the job is well done. Never ever going back to a dealership after experiencing that level of service and quality job. |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | allowe (02-24-2017) |
#32 | |
Toe arm bolt
Exactly! I went to Toyota because I was paranoid and wanted a full diagnostic of the rear passenger side. All I got was "maybes". I wish I lived close to the place you're talking about man. I'm dying to find an honest shop. I spend lots of money on my cars because it's my passion. Oh and don't get me started on the mechanics. Like 6 of them around my car, touching it and playing with things that weren't a part of the damage. I have my taillights red painted and they were rubbing it like they were tits or something... oh and some guy was sitting in the car while they had it up on a hoist. The idiot put his body weight on the door and the roof of the car to jump down. I don't know how strong our hinges are but I wanted to walk in there and stab him.... Sent from my iPhone using Tapatalk |
#33 |
Toe arm bolt
I finally got my hands on a wheel hub and bearing assembly... is there a special tool to pull the hub off of the axle ?
Also... can it be the axle making that noise ? It's just a noise of something catching sometimes. This is a crappy video of the sound [ame="https://www.youtube.com/watch?v=lPot18Dy-pE&feature=share"]Whoop sound - YouTube[/ame] I'm so sorry about that crackling!! Listen to the last 10 seconds and the first bit, they have that whomping sound. Any ideas on what that whomp sound is? I'm running on a steelie for now Sent from my iPhone using Tapatalk |
#34 |
I know it's a rough sound clip but any thoughts?
#35 |
fabulous
I wonder if it isn't just scrub from being out of alignment. Replace the bearing. Forget about the rotor. I think that's BS. Get it aligned and then listen.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | allowe (02-25-2017) |
#36 | |
Thanks for your reply. Yea I'm Guna just replace it and get it aligned and call it a day I guess leave the rotor for now Sent from my iPhone using Tapatalk |
#37 | |
fabulous
Let us know how it goes.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | allowe (02-26-2017) |
#38 |
The only hard part about pulling the hub off is the large axle nut, check out the diy threads for changing the wheel studs and they should have all the instructions.
| The Following User Says Thank You to strat61caster For This Useful Post: | allowe (02-26-2017) |
#39 | |
I've got an awesome impact wrench . I'm just scared to break the axle while trying to hammer it out of the hub :S Sent from my iPhone using Tapatalk |
#40 | |
Pull the wheel speed sensor out, that's the only thing I think may be at risk if you have to get ugly with it. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | allowe (02-26-2017), Ultramaroon (02-26-2017) |
#41 |
fabulous
Damn, strat, pro tip.
@allowe, this is a must. Frequent rookie oversight. Fellow member's friend hosts this important page. I don't know how long they'll stay up so read while you can.
#42 | |
Do you actually have to take off the lca, trailing arm and toe arm in order to take the hub off? Thanks for your reply! Sent from my iPhone using Tapatalk |
| How do I remove this bolt o.o? | Mikeez | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 06-22-2016 09:38 AM |
| Camber bolt + suspension bolt torque settings | LostSalad | DIY (Do-It-Yourself) Guides | 3 | 05-09-2016 10:29 AM |
| Missing bolt.... | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 12-03-2014 08:00 PM |
| Bolt Ons Available for your 86! | AutoRnD | Engine, Exhaust, Bolt-Ons | 1 | 07-09-2014 12:27 AM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 01:19 PM |
