Old 02-20-2017, 07:56 PM   #1
alt21
Drives: FR-s
Innovate SCG-1 Solenoid Boost Controller and Air/Fuel Ratio Gauge
Brand new in box. None of the packaging was ever opened. I also have a print out of installation from Innovate that will be included.
$300 shipped
-All-in-one, intelligent boost control and wideband air/fuel ratio gauge
Controller and display housed in 52mm (2 1/16”) diameter gauge body
Interchangeable faceplates & bezels: Black & silver bezel, black & white faceplates included
No PC required for configuration
OLED user configurable display
Boost, shift light, Air/Fuel ratio
AFR or Lambda, inHG, PSI, kPa, or BAR
Includes high resolution solenoid
4 BAR map sensor, pressure range -29 inHG to 43.5 PSI (-1 to 3 BAR)
User programmable boost cut safety using Air/Fuel and Pressure references
Programmable solenoid duty cycle with separate gain control function
Peak hold function
Patented DirectDigital™ wideband sensor control, 100% digital wideband air/fuel ratio technology!
Wideband O2 Compatible with several fuel types (Leaded, Unleaded, Diesel, E85 & more)
Ability to calibrate O2 sensor for maximum accuracy
Configurable linear 0-5v analog output for wideband O2 for use with piggy back or stand alone ECU’s as well as external data loggers
Innovate MTS serial in/out (for use with other Innovate & 3rd party MTS enabled devices to add additional logging channels)
4 channels of log-able data with powerful LogWorks PC Software (MAP, RPM, A/F, WG duty)
alt21 is offline   Reply With Quote
Old 03-07-2017, 07:01 PM   #2
alt21
Drives: FR-s
Bump.
NEW AEM Universal Failsafe Boost Air/Fuel Ratio Gauge AEM 30-4900 erbaker67 Audio/Visual, Electronics, Infotainment, NAV 0 07-11-2016 01:27 PM
Innovate boost gauge ?? Help kylem1853 Forced Induction 6 03-07-2016 01:06 AM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
SCG-1 Boost controller gauge with integrated AFR protection. Rleased! Innovate Motorsports Forced Induction 0 07-15-2014 11:40 AM
SOLD : AEM 30-4100 UEGO Wideband Controller Gauge - Air-Fuel Ratio KSpider Engine, Exhaust, Bolt-Ons 0 04-11-2014 12:13 PM
