Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 02-20-2017, 01:04 AM   #15
Ultramaroon
fabulous
Ultramaroon's Avatar
Yes.
Drambeenie (02-20-2017)
Old 02-20-2017, 01:36 AM   #16
BboyRuda
BboyRuda's Avatar
Drives: Series.Yellow BRZ
Originally Posted by Drambeenie View Post
Hey guys so I've been driving the car more and haven't had any issues with the gears stall or strange sounds. Do you think I should still take it to the dealership to be diagnosed?
Better to be safe than sorry bro.
BboyRuda is offline   Reply With Quote
The Following User Says Thank You to BboyRuda For This Useful Post:
Old 02-20-2017, 01:44 AM   #17
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
Definitely. I'd inspect your transmission oil, diff oil, and clutch for surprises.
C4RBON is offline   Reply With Quote
The Following User Says Thank You to C4RBON For This Useful Post:
Old 02-20-2017, 01:49 AM   #18
Ultramaroon
fabulous
I should explain a little more. It sounds like two gears were engaged at once. This causes the transmission to completely lock up. The only way that can happen is if some part of the gear selection mechanism is either loose, misaligned, or broken.
It's unlikely but possible for the transmission to lock up while in motion. That would be a very bad day.
Old 02-20-2017, 08:53 AM   #19
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
There's the problem. You granny shifted when you should have double clutched.
It smells to me like 1st gear broke and is missing some teeth. The metal bits ar floating around in the tranny and will do more damage the more you drive the car. I don't think that'll matter much because I think they'll replace rather than rebuild.
I feel bad for you- brand new car and you expect it to be trouble-free and then this happens. But brand new cars can do this. Sometimes you just get a dud off the assembly line. That said, get it fixed under warranty and forget about it, it's just a flukey thing and the car will be fine after.
The Following User Says Thank You to guybo For This Useful Post:
Old 02-20-2017, 10:48 AM   #20
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Originally Posted by ToySub1946 View Post
Are you aware that your car has 'hill start assist' ?
Others have stated the default setting, when car is new, it is set to OFF.
I'm aware that this exists but didn't activate it. I've never had hill start issues before. There is def something going on inside the tranny.
Drambeenie is offline   Reply With Quote
Old 02-20-2017, 11:46 AM   #21
wheelhaus
wheelhaus's Avatar
This would also explain the feeling of first gear "missing" and allowing the car rolling backwards. The "crunching" noise could have been the synchros skipping from non-engagement, and then the sudden engine stall caused by instantaneous synchro engagement.
wheelhaus is offline   Reply With Quote
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
Drambeenie (02-20-2017), Ultramaroon (02-20-2017)
Old 02-20-2017, 02:55 PM   #22
Ultramaroon
fabulous
Agreed. I don't think any gears actually failed because OP states he can drive the car normally now.
Still, unaddressed, this will happen again and be at best inconvenient, life threatening at worst.
/dramatic warning
Old 02-20-2017, 03:21 PM   #23
Drambeenie
Drambeenie's Avatar
And there she goes... thanks for the replies guys! I'll keep the thread updated as I learn more. Curious to see what'll be found in the transmission pan.
The Following User Says Thank You to Drambeenie For This Useful Post:
~el~jefe~ (02-21-2017)
Old 02-20-2017, 03:31 PM   #24
Ultramaroon
fabulous
Awww, poor baby. She'll be all better soon.
Old 02-20-2017, 08:42 PM   #25
BboyRuda
BboyRuda's Avatar
Double clutching is necessary in our cars? o.O
Old 02-20-2017, 09:06 PM   #26
Ultramaroon
fabulous
No but it actually helps, especially for second and first gear downshifts.
[ame="https://www.youtube.com/watch?v=pB-bN-RkJLM#t=47"]The Fast and the Furious (2/10) Movie CLIP - Winning's Winning (2001) HD - YouTube[/ame]
gramicci101 (02-20-2017)
Old 02-20-2017, 09:25 PM   #27
guybo
Huge E85 fan!
guybo's Avatar
Old 02-20-2017, 09:37 PM   #28
BboyRuda
BboyRuda's Avatar
How does it help? Why not just rev match (without double clutching) like the rest of the gears?
The Following 2 Users Say Thank You to BboyRuda For This Useful Post:
Drambeenie (02-20-2017), Psilox (03-09-2017)
Search this Thread:
Advanced Search
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 10:59 PM
Crunch noise? winsometang Issues | Warranty | Recalls / TSB 9 12-02-2014 02:38 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 04:41 PM
Second Gear Crunch? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 18 09-27-2012 03:52 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
