86WORX
Old 02-19-2017, 08:46 PM   #15
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I have the EXACT same squeak. I've assumed it is just the fork needing lubed. Interested in results. Thanks!
ajcarson11 is offline   Reply With Quote
Old 02-19-2017, 10:09 PM   #16
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by canyons View Post
Update 19 Feb: After re-lubricating the clutch fork pivot thoroughly ( a plastic spoon works well for this BTW) the noise still persisted, but only with a cold engine. Zero noise when warm ( including off but warm.) Zero noise when moving clutch fork / Clutch slave cylinder by hand.
I suspected the the return spring in the clutch master cylinder. We depressed the clutch and sprayed the internals of CMC piston assembly (located above the gas pedal) with TriFlow, and that has eliminated the clutch squeak completely in the short term. We'll see how long that lasts, may switch to other grease product if needed, or replace CMC, or both. IIRC, some dealers had suggested this as a possible cause of squeaks; In my case that was it. Can't hurt to have lubricated the clutch fork pivot too. Both these procedures are easy maintenance items.
I am puzzled. The only metal to metal contact should be between the piston and the pushrod. Is the foot in that pushrod able to float off center? I'm checking that for myself. :/
Were you able to confirm the squeak when operated by hand?
Old 02-20-2017, 11:28 PM   #17
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
Yes on the squeaking when operating the clutch itself by hand. No when operating the clutch fork by hand, even with CSS installed. I believe that a liberal application of Triflow lubricated the sides of the "master cylinder piston sub-assembly" in the diagram above. I compressed the clutch fully before spraying it good, then released the clutch, then repeated the process. Noise still gone!
canyons is offline   Reply With Quote
Old 02-21-2017, 12:15 AM   #18
Ultramaroon
fabulous
Noise still gone!
I am honestly baffled. Thrilled for you but confused almost to the point of wanting to disassemble mine. I thought both ends of that piston rode on seals.
Old 02-21-2017, 12:25 PM   #19
canyons
canyons's Avatar
I Believe that's correct. Could be the passenger-facing seal had begun to dry out? It's 4+ years old, living in dry & warm SoCal...i can believe pulling a dry seal through the bore would cause a squeak.
The Following User Says Thank You to canyons For This Useful Post:
Ultramaroon (02-21-2017)
Old 02-21-2017, 01:57 PM   #20
Ultramaroon
fabulous
Ok, yeah. I can see that. Cool!
Old 02-27-2018, 11:37 AM   #21
canyons
canyons's Avatar
Update: one year later, noise still gone!
Ultramaroon (02-27-2018)
Old 03-26-2018, 11:25 AM   #22
Zoid
Zoid's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWP
I'm having trouble figuring out what you did, did you do the same thing this guy did in this video?
I have the same exact noise as him at the beginning of his video. Identical. He left a comment 3 months later on his video reporting not hearing any noises since.
Zoid is offline   Reply With Quote
Old 03-31-2018, 12:46 AM   #23
86league
Drives: '13 BRZ Limited
3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip.
Any issue with moving the clutch fork forward to help with access?
I did take one on this tonight, but couldn't really get to the pivot easily and was afraid to move the fork too far...
My squeak is still there, but I don't really think I got any grease to the needed location... Figure I'll go after it again tomorrow...
Thanks for the help!
86league is offline   Reply With Quote
Old 03-31-2018, 12:59 AM   #24
Ultramaroon
fabulous
Nope. Jam that slave piston all the way in. Pump the clutch pedal a couple times when you're finished. If you still have your assist spring installed, the pedal may sink to the floor and stay there for the first pump.
Old 03-31-2018, 11:13 PM   #25
86league
Moving the fork forward helped... Squeak seems to be gone. Clutch action seems a little smoother as well - felt very slightly gravely before.
I say "seems to be" about the squeak because it didn't always squeak, but it's been squeak free all day and I think it would have reoccured by now.
Thanks for the quick and dirty procedure, diagram, and the advice - made this fix easy.
Old 04-01-2018, 12:03 AM   #26
Ultramaroon
fabulous
You'll know in a couple days if you got it worked into the pivot.
Search this Thread:
Advanced Search
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 12:42 PM
Worried about my clutch? Bushhy Issues | Warranty | Recalls / TSB 11 07-01-2016 10:20 AM
noise when releasing clutch andrew5826 Issues | Warranty | Recalls / TSB 5 02-17-2014 07:41 PM
Winding Noise From Clutch Bach415 Northern California 0 06-24-2013 08:19 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) -- General Topics 49 07-02-2012 04:45 PM
