86WORX
Old 02-13-2017, 05:53 PM   #57
Tokay444
Anti stance.
Tokay444's Avatar
Originally Posted by Icecreamtruk View Post
I will actually know how much 13 track days (some HPDE, some time attack, average track time is around 2h per track day) can do to the engine output. I will dyno it again at the same dyno it got tuned after getting headers, altho it had already seen a fair amount of track time by then (car had 3 years and over a dozen track days already when I got the headers+tune). I will try to report after I do it (if I dont forget). I still have the original dyno plots laying around (and can probably ask for an overlay of both of them).
Unless the temperature and barometric pressures are identical from your first dyno, and on the same dynamometer, the comparisons will be moot.
The Following User Says Thank You to Tokay444 For This Useful Post:
strat61caster (02-13-2017)
Old 02-14-2017, 11:06 AM   #58
Icecreamtruk
Drives: Track preped NA FRS
Yes, it will not be a scientific test at all, a few horses of differences doesnt say much, except that the engine hasnt changed much. But what if I see -15whp? No changes in weather should show something like that, altho it shouldnt be the case.
Old 02-14-2017, 03:27 PM   #59
Tokay444
Anti stance.
Tokay444's Avatar
Originally Posted by Decay107 View Post
Your tuners are mistaken.
Maybe you need clarification on what 10/10 means.
It means all. Not just mine.
2015firestormFRS (09-08-2017)
Old 02-14-2017, 04:00 PM   #60
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
There's a few dyno sheets around that show the Tomei UEL performing just as well or better than some EL.
http://www.ft86club.com/forums/showthread.php?t=92104
http://www.ft86club.com/forums/showthread.php?t=88696
http://blog.vittuned.com/just-a-coup...-vs-tomei-uel/
The Following 3 Users Say Thank You to Andrew025 For This Useful Post:
Jonsey (02-14-2017), why? (10-03-2019), wparsons (02-14-2017)
Old 02-14-2017, 04:23 PM   #61
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
keep on drinking that kool aid
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Old 02-14-2017, 04:25 PM   #62
Hyper4mance2k
Shadetree Project Ratchet
Hyper4mance2k's Avatar
Drives: series.Blue
Stop arguing about UEL vs. EL. You don't even know the science between the debate, or why one header works better than another. If you did, you'd present evidence based on port volume, velocity and flow at specified RPM, where you want to make peak torque, and how and why you want to collect the header runners.
Arguing about UEL vs. EL without knowing how each header flows and how it's scavenging exhaust pulses is the same as arguing over snow tires vs. R compounds and not considering where the car is being driven.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 12 Users Say Thank You to Hyper4mance2k For This Useful Post:
2015firestormFRS (09-08-2017), bfrank1972 (02-14-2017), BRZ FTW (02-16-2017), Carlos_M (02-16-2017), Decay107 (02-14-2017), jasonojordan (02-14-2017), RiskyTrousers (02-14-2017), Shark_Bait88 (02-14-2017), ThatAsianBradah (02-07-2018), Timmy_Jones (02-15-2017), Tokay444 (02-14-2017), wparsons (02-14-2017)
Old 10-02-2019, 04:25 PM   #63
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Do you have the original picture that went with this post? Interested to see the dyno results.
Thanks,
Alan
Originally Posted by RiskyTrousers View Post
Hello all,
I just switched from the Nameless header to the Ace and wanted to share my experience. This is on my STX prepped car, mods are identical between dynos other than the related front pipe/over pipe. Both tuned by Church via ecutek, same dynapack, runs are 2.5 years apart. CA 91 oct.
Mods:
TRD intake
Perrin 2.5" resonated CBE
Nameless setup:
Early release tri-y header w/3" outlet
Nameless 3" over/front pipe w/cat, resonator and helmholtz. Tapers to 2.5" at CBE.
Ace setup:
Type A 350 tri-y header and over pipe
JDL 2.5" front pipe w/cat and resonator (ultra quiet)
Green is Nameless, blue is Ace
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 10-03-2019, 12:44 AM   #64
MilkyWitness
Drives: 2019 Pure Red BRZ with PP
Hey whats the story on the trailer with your BRZ? I would love to get a trailer but I would be afraid of towing in this car...has anyone else done it? I know it isnt related to this post but I saw the guys sig..
MilkyWitness is offline   Reply With Quote
Old 10-03-2019, 04:46 AM   #65
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Why are you asking this of a person who hasn't posted on these forums since 06-01-2017?
why? (10-03-2019)
Old 10-03-2019, 11:09 AM   #66
Lantanafrs2
Drives: 2013 frs red
Usual progression here. Buy car, mod car, sell car, buy faster car. If I'm wrong, I apologize
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Goingnowherefast (10-03-2019)
Old 10-03-2019, 11:25 AM   #67
mrjj
Drives: GT86 2013
Thanks,
Alan
I see the dyno graph. I attached the picture (as a zip, since the forum limits the size of jpeg's).
mrjj is offline   Reply With Quote
Old 10-03-2019, 01:50 PM   #68
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Ah, yes this thread. I forgot there is a torque dip with the Nameless headers. I guess I don't feel it much when I'm driving.
MS, CSCS, TSAC-F, CPT
Old 10-03-2019, 02:08 PM   #69
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I notice it pretty much as it is shown on the dyno chart the OP posted. But I do not have a specific tune for this header.
Old 10-03-2019, 02:16 PM   #70
weederr33
weederr33's Avatar
I don't have much of a reference then. I do notice a nice zing in power past 4k rpm. So maybe I'm just accustomed to the torque dip? Either way, the dip has never really bothered me.
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 03:26 AM
Has there been a direct comparison of JDL UEL vs Nameless EL Headers? Kido1986 Engine, Exhaust, Transmission 9 02-13-2015 03:47 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Header comparison. NO E85 NickFRS Engine, Exhaust, Transmission 29 05-16-2013 05:01 PM
Header comparison itwillboost Engine, Exhaust, Transmission 1 03-19-2013 01:58 AM
