Old 12-09-2019, 11:45 PM   #57
Steveiam
Drives: 86
Did it overheat even with a transmission cooler?
Steveiam is offline   Reply With Quote
Old 12-10-2019, 01:06 AM   #58
smoke86
Drives: smoke Toyota 86
Originally Posted by 86TOYO2k17 View Post
Im torn between doing clutch pack / valve body or attempting a swap to a different auto.
Wish someone made an easy solution to swap in a ZF 8HP. An 8 speed with 6 usable gears and holding 400+wtq with ease would be amazing. 3-4 is just too long we need an in-between gear and then 5th is not really usable.
Time for an os giken rear diff.
smoke86 is offline   Reply With Quote
Old 12-10-2019, 01:16 AM   #59
86TOYO2k17
Drives: 2017 toyota 86
That would be cool if/when i am making more power and have a solid transmission setup already.
I want to stay auto. And want a trans capable of 350+ wtq, and a nice bonus would be better gearing. The zf 8hp would be perfect. I just dont know whats all involved like the can bus / trans module, and bolting to engine and and drive shaft.
Old 12-10-2019, 07:42 AM   #60
North_GA_FRS
North_GA_FRS's Avatar
Drives: 2013 Toyota FRS
How long/many track days did the ssp clutch pack last? Do you think the heat was more responsible then the power for destroying the clutch packs?
The next big purchase for my build is building the trans. But I really want to swap in a ZF 8HP having 6 close ratio usable gears instead of the 4 capable of handling plenty of power and swapping to a 3.7 FD with 400whp+ would be amazing. Just don’t know what would all be necessary for the ZF swap.
I'm guessing, but I would say about 20 track days. The heat was definitely responsible for both sets of clutch packs failing. I've only overheated the trans twice (idiot light came on) and both times I've had to replace them. Just having 4 usable gears sucks, I've thought about going with 4.88 final drive but that shift from 4th to 5th is terrible. I've also looked into the 3.7 and may end up going this route; with the 3.7 I wouldn't have to shift to 5th on track anymore.
North_GA_FRS is offline   Reply With Quote
Old 12-10-2019, 09:57 AM   #61
86TOYO2k17
Ah ok that's a little more reassuring then.
I had a 4.5 FD on originally from my NA days but after boosting 4th just topped out way too low and 5th was still useless, you would need a 5.1FD to make 5th usable. A 3.7-3.9 could be another good option. but then 4th starts becoming really long. with a 3.73 3rd would get you to about 105mph and then 4th to about 145mph. If you got the power to keep pulling though or really need the longer gearing in the straights could be good.
now a zf hp8 with a 3.73 fd would be money.
with the zf 8hp 70 rated at 516 lb·ft, gearing with a 3.73 fd 7500rpm stock tire diam
1st Gear
31.34
2nd Gear
47.01
3rd Gear
69.94
4th Gear
88.29
5th Gear
114.56
6th Gear
147.15
Old 01-14-2020, 10:53 AM   #62
North_GA_FRS
The primary reason the trans temp was so high was due to coolant temp. On a 100 degree day, coolant temps were 220-240. Coolant temps addressed with Koyo radiator, slim shroud changes for greater air flow (primary reason coolant temps were so high), and ducting. For the trans, I have now bypassed the heat exchanger and installed a 180 degree thermostat, so coolant will no longer be part of the temp equation. Rather than purchasing a new set of SSP clutch packs, I'll be purchasing a used trans, having the valve body swapped over, and removing the SSP torque converter. This should be completed early next month in preparation for Auto-X and the cars first track day of the year in March. Car will be running Amsoil signature series synthetic trans fluid as well.
The Following User Says Thank You to North_GA_FRS For This Useful Post:
86TOYO2k17 (02-04-2020)
Old 01-14-2020, 11:26 AM   #63
North_GA_FRS
Yes. As I broke this down though, it really goes back to the installation of a slim shroud fan setup. It was installed to gain space between the turbo/exhaust/fan shroud. The goal of increased space was accomplished however, the smooth transitions of the factory shroud were replaced with a squared off shroud, creating a lot of turbulence and decreasing flow through the radiator. The auto has a heat exchanger which uses coolant to quickly increase trans temp; works great when the car is run under normal operating conditions but turbo and 100 degree ambient track temps certainly aren't normal, and reduced airflow through the radiator just exacerbated the problem. Coolant temps on this particular track day were 220-240 and even though the trans cooler was oversized, it was sandwiched between the AC condenser and intercooler.
There have been many changes since that track day..... radiator changed to Koyo, fan shroud modified for better flow, AC removed (not a daily driver), fabricated ducting, bypassed the heat exchanger and installed a thermostat, changed to 19 row stacked plate cooler, and changed from WS to Amsoil signature series synthetic. I don't expect to have any trans cooling problems going forward but we shall see.
Steveiam (01-20-2020)
Old 01-31-2020, 07:24 PM   #64
86TOYO2k17
@North_GA_FRS
When you did valve body, did you have to do anything with the tcu for relearning or anything? Notice any weird issues with the valve body? saw another user having issues with it not be consistent when shifting.
Old 02-05-2020, 02:08 AM   #65
86TOYO2k17
Anyone looked into a A760E swap. Slightly better gearing holds way more power.
“ the electronic controls between the A760E and A960E are the same. (Same number of solenoids, same part numbers for the solenoids, same revolution sensors, same wiring.) They are both controlled in the same way, the difference is mechanical for the most part.”
Wonder how hard this would be to swap.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
Mr_Eyo (02-06-2020), Steveiam (02-08-2020)
Old 02-08-2020, 01:00 AM   #66
Steveiam
Drives: 86
Are they both the same size pretty much?
Old 02-08-2020, 09:51 AM   #67
86TOYO2k17
Not 100% sure. I think its slightly bigger. Im sure it could fit pretty easy. You would need an FA20 adapter and driveshaft. Not sure if it being so similar if the stock TCU could control it or if you need some sort of can bus adapter.
Seeing what vehicles use this transmission it would be a perfect solution for people wanting big power.
Old 02-16-2020, 11:55 PM   #68
North_GA_FRS
@North_GA_FRS
Nothing was done to the TCU/ECU and I never had any issues at all. Prior to valve body install I would have to shift 1500 rpm prior to red line because there was a delay in shifting. That delay was resolved up to 4th gear but shift to 5th is still very slow and unless I lift, the car throws a slip code. If you decide to purchase a valve body, stick with the stage 1; the stage 2 made no difference at all for 5th/6th gear changes.
Old 05-31-2021, 03:21 AM   #69
csol
Anyone had issues boosted with E85.
Mine is throwing code 2757 now again even after replacing the Torque Converter Clutch Pressure Control Solenoid.
csol is offline   Reply With Quote
Old 06-10-2022, 10:28 AM   #70
OfficeLinebacker
Drives: 2019 Toyota 86 Base AT
Originally Posted by Lunatic View Post
I am at 323 with edelbrock and e-85. Automatic tranny, lots of track days, and no problems at all. I always heard the automatic was actually stronger then the manual. I also run a tranny cooler and normally see 230 to 240 tranny temp on track.
How do you monitor your AT temps?
OfficeLinebacker is offline   Reply With Quote
Search this Thread:
Advanced Search
Boosted owners in NY - how are you passing state inspections? Foobar NY / NJ / CT / PA 12 10-15-2015 03:02 PM
Auto Trans issue Triumphrider Issues | Warranty | Recalls / TSB 9 11-04-2014 08:34 PM
Is there an Auto Trans only dyno thread? Pure Automotive Engine, Exhaust, Transmission 17 07-17-2014 01:35 AM
Auto Trans Feels like it is slipping... Fett4Real Issues | Warranty | Recalls / TSB 19 01-16-2014 11:02 PM
What is the best way to Launch the Auto Trans DeOppressorLiber Tracking / Autocross / HPDE / Drifting 27 10-23-2013 12:24 AM
