Old 02-03-2017, 10:40 PM   #1
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
Sapphireho build thread
Hello all,
I'm an older guy, we didn't call things "mods" or "builds" in my day, you just worked or "sooped" up our cars. I bought my car 2 years ago, so late at this, but better late than ever, right?
Her are my "mods" as of today:
Interior
Shrader Performance Rear Seat Delete kit
Subaru Trunk Lid Trim Panel Liner
TRD Sport Guages
Exterior
Perrin Plate Relocate kit
Rebadged Toyota GT86
TRD Fog Lights
Suspension
TRD lowering springs
TRD sway bars
Yoshihara D5C 18x8 +40 rims w/Michelin Pilot Super Sport tires
Engine & Drivetrain
Jackson Racing Supercharger
Jackson Racing Oil Cooler
Jackson Racing Aluminum Neck Filler/Radiator Cap
DW 700CC injectors
DW 300c Fuel Pump
Delicious Tuning Flex Fuel MK1+ Kit
Custom Tune by William Knose of Delicious Tuning
TRD exhaust
ACT Xtreme Clutch Kit with Flywheel
TRD Japan short shifter
DSS Carbon Fiber Driveshaft
Brakes
DBA 4000 drilled and slotted rotors
DS2500 Ferodo brake pads
Perrin master cylinder brace
Mann Engineering Stainless Steel Brake Lines
Fluids
Torco SR-5R 5w30 Engine oil
Torco SGO 75w90 Transmission and Differential Gear Oil
Torco RT700 Brake Fluid
I just realized I have no good pictures in this iPad. I will get some ASAP. Also I need to scan my Dyno sheets, 240hp gas, 310hp e-85.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
craigpitts7 (02-07-2017), ichitaka05 (01-25-2018), ILLSMOQ (02-08-2017), mrg666 (06-15-2018)
Old 02-07-2017, 10:56 PM   #2
Sapphireho
Connection issues
Sapphireho's Avatar
Getting the full bushing treatment now:
Anti-Lift/Caster Bushing Kit
Front Control Arm Rear Bushings
Heavy Duty Steering Rack Bushings
STI Upgraded Steering Rack Bolts
Rear Subframe Insert bushings
Rear Differential Inserts
Transmission Bushing Insert
Rear Trailing Arm Bushings, Front
Toe Arm Bushings
Inner Lower Rear Control Arm Bushings
roll center adjuster set
Old 02-08-2017, 12:09 AM   #3
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Nice mods, interested to know how the bushings change the feel of the car.
ILLSMOQ is offline   Reply With Quote
Old 02-10-2017, 12:05 AM   #4
Sapphireho
Connection issues
Sapphireho's Avatar
Can't tell yet about the bushings. It is raining cats and dogs here in San Jose. As soon as I can get some miles on them to settle in, and the mountain roads can be driven on, I will post.
The shop also did my Japan TRD shifter, and it feels really nice.
Old 07-25-2017, 04:43 PM   #5
Sapphireho
Connection issues
Sapphireho's Avatar
Haven't been back here for a while. All the bushings made a big difference. Car is much more stuck to the road. I can go faster than I should in the hills and never have the nannys come on, yet no noticeable difference in ride quality. Very happy with the results.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
86 South Africa (09-30-2017), ILLSMOQ (07-27-2017), new2subaru (07-25-2017)
Old 05-16-2018, 01:36 PM   #6
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Toe Arm Bushings
Revive!
What brand were the bushings? Was it a single kit, or did you have to buy a whole bunch? I know whiteline has a kit, but I don't know if it has all of those or only some.
Nevermore is offline   Reply With Quote
Old 05-17-2018, 03:03 PM   #7
Sapphireho
Connection issues
Sapphireho's Avatar
Originally Posted by Nevermore View Post
Revive!
Yea, I have to update this.
It was a whole bunch. Most were Whiteline, and some of the inserts were another brand, I forget the name. I'll have to dig out the receipt.
They made a big difference.
Old 05-17-2018, 04:33 PM   #8
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I know I hate driving over rougher roads because it always makes the acceleration feel wonky. What's it called? Wheel hop? I think that's the main issue. If changing out the bushings helps with that I might want to do it.
Old 06-14-2018, 08:02 PM   #9
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
What shop did the work if you don't mind me asking?
I've been working on dialing in my suspension and wouldn't mind getting a few bushings replaced on my car.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 06-14-2018, 08:56 PM   #10
valtore101
Drives: 2016 FR-S
Looks great! How's the JRSC holding up? Any issues? Do you happen to have a dyno chart or are you running a canned tune?
valtore101 is offline   Reply With Quote
Old 06-15-2018, 10:58 AM   #11
Sapphireho
Connection issues
Sapphireho's Avatar
Mann engineering in Santa clara.
JeremyR (06-15-2018)
Old 06-15-2018, 11:07 AM   #12
Sapphireho
Connection issues
Sapphireho's Avatar
SC had bearing failure and was replaced under warranty. No canned tune. The car was dyno tuned by Bill Knose of Delicious Tuning.
Both my 91 and e85 dyno charts are here somewhere, I think under the 8/6 day dyno results thread in the norcal section.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
SWP's 13' BRZ Build Thread SWP BRZ Member's Car Journals 2 01-16-2015 02:23 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
