#43 |
Off Topic
That's not the radiator fill port?
I may need to go change my oil again. And flush the radiator. |
| The Following 5 Users Say Thank You to gramicci101 For This Useful Post: | Dadhawk (02-03-2017), finch1750 (02-03-2017), Tcoat (02-03-2017), Ultramaroon (02-07-2017), why? (02-12-2017) |
#44 |
1st86 Driver!
Well, it fit there, can't say for sure that's really where it was supposed to go.....
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | gramicci101 (02-03-2017), Tcoat (02-03-2017) |
#45 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Have you not learned anything here? Changing your fluids is a miracke fix. Just leave it. It's fine. The motor knows which goes where and will correct it. Highly educated engineers designed this after all
| The Following 2 Users Say Thank You to finch1750 For This Useful Post: | gramicci101 (02-03-2017), why? (02-12-2017) |
#46 |
I learned it best to double check. They usually dont think like that surprise
#47 |
#48 |
Drives: 2015 FRS
theres gonna be a recall soon? the chirp caused the fire!
#49 |
Dismember
Drives: 2013 Red Scion FR-S
Were you in Bowling Green at the time? That would explain everything.
#50 |
Drives: 17 86
Things built by humans sometimes fail. Regardless of what else happens, I'd make sure Toyota knows about that.
| The Following 3 Users Say Thank You to PetrolioBenzina For This Useful Post: |
#51 |
Drives: ‘16 4Runner, ‘19 Corolla HB
Just curious what would possess you to put $8k down on a lease? Everything I've read is that you should put the minimum amount down on a lease so that this sort of thing doesn't bite you.
That said, the car didn't depreciate $8000 + however much you made in payments since you signed the dotted line, so you should be able to argue that Toyota is only owed the total cost of the car ($27k... $8k of which you've paid) rather than your down payment plus the insurance payout. If the insurance pays out $24k for the car, Toyota should get $19k and you should get the delta of $5k. |
#52 | |
Drives: Neptune GR86
| The Following User Says Thank You to Andrew025 For This Useful Post: | why? (02-12-2017) |
#53 |
Drives: BRZ DGM Limited
No matter what the cause, clearly a safety issue. Consider reporting it:
https://www-odi.nhtsa.dot.gov/VehicleComplaint/ |
| The Following 2 Users Say Thank You to BRZnut For This Useful Post: | MileMonger (02-06-2017), why? (02-12-2017) |
#54 | |
| The Following User Says Thank You to Apex-Apex For This Useful Post: | why? (02-12-2017) |
#55 |
Drives: 2015 Limited
Did you smell anything before this happened (e.g. that burnt electrical smell)? TCOAT probably nailed it, but I had an issue awhile back where I had a USB adapter plugged into the Cigarette lighter (behind the glove box) and we started smelling burnt electrical. Pulled it out and it was still smoking .....
#56 |
Drives: 2017 BRZ Limited
Sorry for your lost..
Did you purchase a "new car replacement" option in your insurance by chance? |
| Burnt Valve? | sybrite | Issues | Warranty | Recalls / TSB | 8 | 03-04-2018 11:18 AM |
| can you refinish a burnt tip? | jaime3 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 04-05-2016 04:09 AM |
| DIY burnt tip help | xcooperx | Southern California | 8 | 10-04-2015 07:08 PM |
| Juvi's clean & crisp 86 GTS | Juvenile | Member's Car Journals | 8 | 06-16-2014 04:59 AM |
