Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 01-31-2017, 10:48 AM   #43
Originally Posted by jvincent View Post
I tried the penetrating oil, but clearly my patience wasn't enough. Mine had been through two winters or salt and grime as well so my odds were pretty low.
In cases like that Dremel is your friend. Be 5 minutes a side to have it off.
Old 01-31-2017, 11:50 AM   #44
jvincent
jvincent's Avatar
It was too far to walk to get the dremel. The claw hammer also allowed me to get some frustration out.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
Dadhawk (01-31-2017), Tcoat (01-31-2017)
Old 01-31-2017, 02:22 PM   #45
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
1. Torque dip (better than previous MY's, but still there) Does it interfere with your 0 to 60 land speed record? Need that 1,000th of a second on your light to light travels? If for track/race use then there are things that can be done
2. Steering wheel (not the wheel buttons, but just how thin it is) I thought the 17s were thicker than the prior ones? I found it way thicker than I liked when I checked one out.
3. Stock pedal spacing (wish they were closer together, hard to heal/toe downshift for me) It is still made as a street car first and needs to accommodate all sizes of feet and shoes. Practice.
4. G-meter (very limited practicality, could be replaced with something more useful). Limited is better than nothing.
5. Exhaust tips (sunken in on my car, turns out these can be adjusted!!) Resolved.
100% agree...the torque dip is a really silly (and hella old now) complaint..under 4 K it is acceptable for stop & go situations & city commuting while above 5 K it is perfect for spirited driving..if you are dipping below 5 K while driving hard then you aren't downshifting soon enough...and the stock pedal placement is still rather very good. I don't have large feet and it is very comfortable for me...hilariously it is easier than performing heel & toe on the logitech g27 pedals
HKz is offline   Reply With Quote
Old 01-31-2017, 02:30 PM   #46
kch
Senior Misanthrope
kch's Avatar
Originally Posted by Anthony View Post
Also, there's the Grimm Speed pedal relocator.
GSpeed. Different group.
Old 01-31-2017, 02:37 PM   #47
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Oh, right. Good catch.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 01-31-2017, 02:45 PM   #48
johan
Drives: '14 981CS, '99 NB1
Originally Posted by justinco View Post
Apparently there is a bolt on the underside of the tip. You can loosen said bolt, and slide the tip back and forth for desired tip effect. I am going to be testing it out this week!
(really I'm just going for more tip lines from jefe )
It doesn't move much.
The real fix is to swap to the JDM exhaust tips. They are much longer (at least an inch) than the USDM exhaust tips. I actually swapped my stock tips with someone else for their JDM tips. The '15-'17 USDM tips look better on the '13-'14 exhaust than the JDM tips do. Subaru changed the pipe length between the 13-14 and 15-17 mufflers where the tips attach.
I guess there is a US regulation about how far the tips can stick out from the bumper on newer cars that dictated how deep the tips are sunk in stock form.
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
justinco (01-31-2017), Tcoat (01-31-2017)
Old 01-31-2017, 03:00 PM   #49
johan
USDM:
JDM:
The Following User Says Thank You to johan For This Useful Post:
Old 01-31-2017, 03:12 PM   #50
There are dollar limits in how much damage can be done at a low speed collision which would probably account for the tips being set back. Exhaust being pushed forward can mess up a pile of costly stuff.
There is also a requirement that anything hot be protected against direct contact with body parts . This could apply to tips sticking way out but nobody should be walking that close to hot back bumpers in the first place.
Old 01-31-2017, 03:54 PM   #51
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by HKz View Post
100% agree...the torque dip is a really silly (and hella old now) complaint..under 4 K it is acceptable for stop & go situations & city commuting while above 5 K it is perfect for spirit driving..if you are dipping below 5 K while driving hard then you aren't downshifting soon enough...and the stock pedal placement is still rather very good. I don't have large feet and it is very comfortable for me...hilariously it is easier than performing heel & toe on the logitech g27 pedals
The torque dip is an opinion, not an argument. Lots of people are not bothered by it, lots are, that's fine.
I actually find it easier to heel/toe my G27 pedals, they are totally adjustable
Although, someone made a comment on my video that the BRZ gas pedal is adjustable too? So, I need to check into that...even though I have the Cucso pedal cover.
I'm not even going to comment on the tips anymore, you guys are killing me (thanks johan for the info though!).
justinco is offline   Reply With Quote
Old 01-31-2017, 04:02 PM   #52
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Oh nononono I Looove my JDM tips on my 13!
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
johan (01-31-2017)
Old 01-31-2017, 04:17 PM   #53
johan
obviously it's subjective. The 15-17 tips sit flush with the bumper on 13-14 mufflers. Some people prefer that, other people are ricers.
j/k
Old 01-31-2017, 04:26 PM   #54
~el~jefe~
Drives: 2019 MX-5 RF
Can the exhaust on stock 2017's eventually melt or warp all that plastic stuff? They seem so set in. I would adjust them out a bit, they seem super stuck inside. 150k miles of that has to do something to plastic I would guess? My mini has pipes sticking slightly outside of bumper clearance. The chrome on them has heated up and tarnished some. I clean them off all the time when I detail the car. I spend a while sudsing and stroking them vigorously to make them appealing.
~el~jefe~ is offline   Reply With Quote
Old 01-31-2017, 04:56 PM   #55
Even though set in the hot gases are forced out and away from the plastic so ya you may have some soot but the worst of the heat isn't doing anything. When moving of course you are also blowing the heat away. I suppose if you left it sitting there idling for hours then there may be a build up. I was worried about heat with my TRD tips since they pretty much fill the hole but both the valance and my cheap ass ABS diffusor have shown zero signs of heat effect after almost 100K miles. Don't think you need to worry.
justinco (02-01-2017), ~el~jefe~ (02-01-2017)
Old 01-31-2017, 06:37 PM   #56
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
Must...not...make...tip...joke...
Prmspen is offline   Reply With Quote
The Following 4 Users Say Thank You to Prmspen For This Useful Post:
Andrew025 (01-31-2017), johan (01-31-2017), Ultramaroon (02-10-2017), ~el~jefe~ (02-01-2017)
Search this Thread:
Advanced Search
2017 BRZ things I hate. 1+CAN+1 CANADA 32 05-23-2017 10:50 AM
dislike your plain Toyota key? check my custom flip tibsy92 AUSTRALIA 38 02-22-2014 10:24 PM
3 likes, 1 dislike RaceR Scion FR-S / Toyota 86 GT86 General Forum 36 12-18-2012 06:11 PM
dislike about the FR-S xc Scion FR-S / Toyota 86 GT86 General Forum 83 11-28-2011 11:56 PM
