| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
Drives: '22 WRB
STI wheel option is same width/offset as the stock wheel and won't clear the brakes.
| The Following User Says Thank You to trippinbillies40 For This Useful Post: | funwheeldrive (02-16-2017) |
#44 |
Drives: 2019 MX-5 RF
#46 |
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
I believe the STi wheel option is also only a 7" rim. The PP wheel is a 17x7.5" (like the 04 STi wheels). You can easily put a 225 on there, which is ideal price and size for the street.
I would love to know the weight of those wheels as well. |
| The Following User Says Thank You to dowroa For This Useful Post: | Lateral G (02-24-2017) |
#47 | |
Drives: Neptune GR86
| The Following 2 Users Say Thank You to Andrew025 For This Useful Post: | dowroa (02-16-2017), funwheeldrive (02-16-2017) |
#48 | |
Old Guy
- brian |
#49 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Re: the brakes.
In the 350Z community "Soft pedal" was a common problem for people who converted from standard brakes to the brembo's without upgrading the master cylinder. I don't know if the PP uses the same master cylinder as the standard brakes, but that's the first thing that came to mind. It was not a safety issue, the brakes worked fine, but the pedal just wasn't as firm. Also, the brakes on my 16 FRS are about the same size as the brakes were on my much heavier 350Z. Better pads and high-temp brake fluid were all the Z needed to withstand extended abuse. I burned out the rubber dust boots on the single-piston calipers, but they still worked great. I have yet to make the brakes on the FRS do any serious work (autocrossing doesn't get much heat in them) but I will be surprised if they don't hold up as well or better than the Z's brakes when I finally get a chance to make them do some work. |
#50 |
Old Guy
While I don't disagree the brakes on the BRZ aren't adequate and have a large variety of cheaper pad options, the Brembo brakes with a larger heat sink should be very useful upgrade. Hammering the car at 20 mins sessions on some of the higher speed HPDEs in the US (ViR Full, Road Atlanta Full, etc), the brakes should prove their worth quickly without spreading.
The only real negative I see with the BRZ PP is the fact that STi pads are more expensive. However, it is a reused part, so blanks and pads are already available which is great. With an oil cooler, better pads, and DOT 5.1 fluid, the BRZ with the performance pack should be ready to go. Specifically to the whole package, I personally still believe that having a 17x7.5" rim cannot be overlooked. With a good summer tire size for the larger rim and some camber, the BRZ PP should be a really good track car almost right out of the box. |
| The Following 3 Users Say Thank You to dowroa For This Useful Post: |
#51 |
Drives: WRB 2017 BRZ Limited w/ PP
Hello Gents,
This is my first post but 4th Suby. I was an active member on NASIOC. I've owned 2006 WRX Limited, 2009 WRX, 2011 STI Limited and now the 2017 WRB BRZ Limited w/ PP. the BRZ is more fun than any of them with the except of off road where the STI is a blast and best at home. Now I'm probably a bit older than most of you guys, so outright speed and HP is waaay over rated when you use a car for daily driving in a city. What I have found is that it is way more important how it makes you feel at low speed, and this car has gobs of tactile feel and responsiveness. And its NOT slow, it's just not blistering fast. I get sick of the youngsters (probably not you guys since you own one or want to own one) saying its underpowered. When I hear that, I know I'm hearing from someone who is not very worldly in automotive terms. For God's sake that been the winning formula for Miatas for 20 years. I've owned plenty of cars (over 20 at least), and all of them except 2 have been performance cars to one degree or another. The BRZ is most similar to the RX8 I owned, but feels waaay faster due to the torque and gearing. But is also gratifying like my old '86 Porsche 911 and is a lot like my current '86 944 Turbo. The BRZ blows me away because its combines the best attributes of these cars in a simple well executed fashion. I test drove the 370z the same day I test drove and bought my BRZ. Yes the Z is faster - but that's it. It feels like a boat - HEAVY. At slow speed it feels like my wife's old Infiniti G35 - sounds the same too, in other words boring. If I did a lot of highway driving I might pick on up. I drove the BRZ after the 370z and I knew in the first 20 feet it was the better car. As for the PP I think its worth every cent. The Brembo brakes do not feel mushy, they feel better than the Brembos I had in my STI. The wheels look decent to, and the crinkle coat intake is back!! Looks great. The stereo, while nothing great, is way better than in any other Subaru car I have owned. I hear the new ones are much better. the 4.30 rear end ratio fits this car perfectly and response at low speeds is instant. I can not speak to the older 4.10 ratio since I never drove it, but I'm sure its good too. The seats are awesome, and in some ways better than the Focus ST Recaro seats. BTW that's the car I traded in for the BRZ. On that car I had the Mountune MR300 suspension and tune kit. The throttle in that car sucked bad. It was like an on off switch, the BRZ, being NA is so much more fun and controllable. I don't regret ridding myself of the Focus ST either! Anyway just wanted to say hello! I'll try to post up pics later. |
| The Following 14 Users Say Thank You to Last Lemming Alive For This Useful Post: | chaoskaze (02-20-2017), daiheadjai (02-18-2017), darthpnoy1984 (02-19-2017), derekbrz24 (02-17-2017), dowroa (02-16-2017), Hoahao (02-16-2017), JonRZ (02-20-2017), KB_BRZ (02-17-2017), Lateral G (02-24-2017), Mr.Impreza (02-16-2017), new2subaru (02-16-2017), NLS8520 (02-16-2017), speed-wiz (02-16-2017), ~el~jefe~ (02-16-2017) |
#52 |
Old Guy
Thanks for the information.
I wish the NASIOC/i-Club community had more active BRZ members.... but it appears that is not the case. |
#53 |
| The Following 3 Users Say Thank You to Last Lemming Alive For This Useful Post: |
#54 | |
Drives: 2017 BRZ
The aftermarket kits also run a floating rotor (better tolerance for thermal stresses, better cooling, attract less heat into the wheel bearing) and use better iron. |
| The Following User Says Thank You to gtengr For This Useful Post: | dowroa (02-17-2017) |
#55 | |||
Old Guy
Link: https://www.essexparts.com/essex-des...0299brzfrsgt86 This kit does have great long-term advantages: great rotors, wide pad selection, better heat dissipation, lighter weight. Also, they are right down the road from me and I have always considered picking up a kit for any car I owned. When you brought up "~10 lbs of added brake weight" are you including the front or front and rears? So, when the AP Racing Sprint kit is applied, is that ~30 lbs in brake weight compared to Sprint Front + OEM rear VS Brembo Front + Brembo Rear? Still, I don't think the Brembos (or Performance Pack in totality) should be looked at as a totally negative option for the price. Or do you see it as such? i.e Stock + Pads or AP racing -- Brembo is the worst of all worlds? Thanks for your time and input. - brian Quote:
For a track rat (not just lightness for autoX, where I don't think I would change), I believe I would go with the endurance system for larger pad depth. At that point, the weight is less of a factor (5lbs v 10lbs). Source for AP Racing's Design Choice: http://www.ft86club.com/forums/showp...0&postcount=24 Quote:
| The Following User Says Thank You to dowroa For This Useful Post: | funwheeldrive (02-17-2017) |
#56 | |||
Drives: 2017 BRZ
It is for sure a personal decision. For me, ~30 lbs of brake weight (most of it in the front) is hard to ignore on this particular car. |
| The Following 2 Users Say Thank You to gtengr For This Useful Post: | dowroa (02-17-2017), new2subaru (02-17-2017) |
| Specs for BRZ Performance Package wheels? | ~el~jefe~ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 04-17-2020 07:31 PM |
| To get the Performance Package or Not? Thread | Zaku | BRZ First-Gen (2012+) -- General Topics | 141 | 12-06-2016 11:04 PM |
| Someone tested the Performance Package... small but SOME info at least | ~el~jefe~ | BRZ First-Gen (2012+) -- General Topics | 13 | 11-29-2016 05:21 PM |
| 2014 Subaru BRZ (Aozora Package Review) | sik20fan | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 14 | 07-29-2015 05:10 AM |
| Crawford Performance BRZ (450 HP) review by Matt Farah (Drive) | switchlanez | BRZ First-Gen (2012+) -- General Topics | 66 | 09-20-2014 02:31 PM |
