Old 01-20-2017, 11:22 AM   #15
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
Originally Posted by Lantana frs View Post
That supercharger had a conservative tune
Originally Posted by Calum View Post
Everything has a conservative tune, until it blows up. Then it's was too aggressive.
They only mentioned briefly the SC car still has full stock exhaust system.
and they are also couple thousand ft above sea level.
ottoyu34 is offline   Reply With Quote
The Following User Says Thank You to ottoyu34 For This Useful Post:
tCsonfrs (01-21-2017)
Old 01-20-2017, 12:52 PM   #16
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Anyone maybe consider that the SC owner isn't shooting for the moon on power, and just wants more than stock without reaching the point of overpowering the chassis? It has enough grunt to keep you happy, but the car is still balanced and fun to drive in everything but a straight line, even on the stock wheels and tires. That's the car's purpose, not to have 500hp and win drag races.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 2 Users Say Thank You to Overdrive For This Useful Post:
new2subaru (01-20-2017), vintagemxer (01-21-2017)
Old 01-20-2017, 12:56 PM   #17
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
I agree with Overdrive, the point of the video was to show the dollars vs HP/TQ gains and when it's worth it or not, in my opinion.
I like that Todd's car was lightly mod'd and could feel the results as well as see the gains.
But as Engineering Explained video shows in the past the most beneficial mod is tires first, Driver improvement and FD.
BWilky is offline   Reply With Quote
Old 01-20-2017, 01:04 PM   #18
Overdrive
Sittin' Sideways
Overdrive's Avatar
Engineering Explained does some great stuff, truly, but the guy's voice grates on my nerves so bad. It's an exercise for me getting through one of his videos.
-O/D
2016 FR-S, Hot Lava
Old 01-21-2017, 12:26 PM   #19
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
IIRC, the power that the SC guy is making is about right for the jackson racing SC carb tune after you factor in drivetrain loss and variance between dyno readings.
Sevs753 is offline   Reply With Quote
Old 01-21-2017, 12:48 PM   #20
Overdrive
Sittin' Sideways
Overdrive's Avatar
Doesn't sound unreasonable to me. I think it's a great power bump without being excessive. I just don't know if the cost is justifiable to me. It may very well be to someone else, and clearly is to at least one guy named Igor with a white FR-S somewhere on the west coast, lol.
I'm a sucker for superchargers (er, no pun intended, honest) but I'd personally want to stick with NA mods on this car similar to how the Everyday guys have.
-O/D
2016 FR-S, Hot Lava
Old 01-22-2017, 10:58 PM   #21
Qadthane
Qadthane's Avatar
Drives: 2013 FR-S in Asphalt
@shiv Can you tell us more about the tune? Was it an e-tune you did for them? One of your off the shelf tunes? Inquiring minds...
Qadthane is offline   Reply With Quote
Old 01-22-2017, 11:45 PM   #22
Teseo
Drives: frs
Was custom e-tune. Look at the tablet and it says "Todd's"
Old 01-23-2017, 02:06 AM   #23
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
It wasn't a custom tune. I built a tune file for his car based upon a similarly modified local car (with the same FT86 Speedfactory catted header) I tuned a few weeks before. In our next OTS map release (v3.0), this particular tune file will be named Stage 2. Whereas tune files for our OpenFlash cat-less header will be named Stage 2+. There will no longer be a designated UEL and EL tune files. I was happy to see Todd realize similar gains on his car at 8000' above sea level, hundreds of miles away. To Todd's credit, I suggested the idea of flying out to tune the car personally but he thought it would be better to not get any special treatment and to see what an OTS tune would provide since that is what 99% of our customers use
The Following 7 Users Say Thank You to Shiv@Openflash For This Useful Post:
BWilky (01-23-2017), guybo (01-23-2017), Mr.Impreza (01-23-2017), PerCompLLC (07-22-2021), Qadthane (02-02-2017), tato.valverde (01-26-2017), Teseo (01-23-2017)
Old 01-23-2017, 06:46 AM   #24
Teseo
Drives: frs
What a spoiler! Now the question is, when the v3 will be launched?
The Following User Says Thank You to Teseo For This Useful Post:
guybo (01-23-2017)
Old 01-23-2017, 08:27 AM   #25
bfrank1972
Drives: 2013 FR-S Argento
Interesting - so from what I remember, the EL and UEL stage 2 tunes used to be fairly difference (i.e. big overlap in mid range for the EL tune that the UEL didn't have). If I read that right - now there's one tune for both EL and UEL catted, and one tune for both EL and UEL un-catted? Is it just optimized for the UEL and EL guys should get a custom tune, or did you figure out some magic way to optimize for both designs? thanks!
bfrank1972 is offline   Reply With Quote
Old 01-23-2017, 02:01 PM   #26
Shiv@Openflash
Drives: 2013 FRS
The reality is that all headers of different design will require unique VVT mapping to optimized engine torque. The difference between two visibly different UEL headers will be just as significant as the difference between any UEL and EL header. So I've found that have a generic tune for EL and UEL does no one any favors unless they use the same exact headers we did during OTS map development. There are also many other improvements to the tune other than VVT mapping so I except both UEL and EL header uses to be pleasantly surprised with the changes. We will also be releasing tunes for 91 and 93oct as before.
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
bfrank1972 (01-23-2017), Mr.Impreza (01-23-2017), tato.valverde (01-26-2017)
Old 01-23-2017, 02:17 PM   #27
jvincent
jvincent's Avatar
Cool. Will there still be an OFH specific tune?
Old 01-23-2017, 02:23 PM   #28
Teseo
Drives: frs
Hope more for petrol users...
Search this Thread:
Advanced Search
Everyday Driver - ND Miata vs. FR-S vs. BRZ DarkSunrise FR-S / BRZ vs.... 109 01-01-2016 07:12 PM
BRZ and the WRX everyday driver video mokinbird87 FR-S / BRZ vs.... 51 07-09-2014 11:56 AM
Everyday Driver: BRZ vs WRX l0aded FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-04-2014 06:03 AM
FRS VS BRZ - EVERYDAY DRIVER Motopythons BRZ Photos, Videos, Wallpapers, Gallery Forum 19 07-03-2012 05:59 PM
Everyday Driver Track Review of FRS vs BRZ jenzan BRZ Photos, Videos, Wallpapers, Gallery Forum 1 07-03-2012 05:47 PM
