Old 01-23-2017, 08:01 PM   #57
Originally Posted by FR-Sky View Post
It is either ghost or the car hate u.
Are you pumping 87?? the car wants 93 +
P.S Dont worry,,u still have the physical key.
Ummm his key would be in the ignition. It is a FRS.
FR-Sky (01-23-2017)
Old 01-23-2017, 08:20 PM   #58
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Oh ic...cus my FRS have push button and keyless entries...
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
Tcoat (01-23-2017)
Old 01-23-2017, 08:28 PM   #59
Suppose his could be a Monogram Raven.
Old 01-24-2017, 02:32 AM   #60
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by Overdrive View Post
So it's not just another dumb button like the dash button, only mounted outside?
I'd imagine not. That dash button probably relies on your key being in the ignition.
BRZ has multiple sensors in the inside and outside of the car to detect your key and behave differently depending on where your key is. Like if I'm standing on the drivers side with the door open, my passenger still cant pop open the trunk using the button on the trunk itself.
PandaSPUR is offline   Reply With Quote
Old 01-24-2017, 08:57 AM   #61
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
The dash button does not need key-in on the FR-S, it is constantly powered unless you hit the disable switch in the trunk. Same with the key button. Only thing is, unlike some cars, the trunk button on the key only opens the trunk. But from your explanation of the BRZ it sounds like you can't use the outside trunk button unless you're near it with the key on you (and thanks for clearing that up). Since the FR-S doesn't have any sort of alarm execpt the special models that are basically BRZs in Scion skin, I guess they don't have to keep the trunk locked along with the doors.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
OFT KC learned Nah Software Tuning 3 03-17-2016 01:52 AM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 03:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-16-2014 12:37 AM
New thing I learned about this car.. Lord-Hydro Engine, Exhaust, Transmission 33 07-22-2014 04:52 PM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 09:15 PM
