Old 01-18-2017, 11:59 AM   #29
Ashikabi
Ashikabi's Avatar
Originally Posted by NOHOME View Post
The only situation that this happens is if I have warmed the car up while I shovel the lane, then move the car back 20 feet to clear the top of the lane. It will not lock while warming up, only after I have moved the car back got out leaving the car running. Somewhere in the time it takes me to shovel the top half of the lane, the car locks itself.
The car does not lock if I just back out of the driveway and say, drive to work, this has to do with me exiting the car.
Maybe next thing to try is back up, turn the car off, restart and get out. See if it re-sets something by shutting it off and re-starting?
Or I can shut it off and leave it off with the key in the ignition to see what happens?
Or I can ignore the whole thing and not leave the key in the ignition ever.
I will see about a new battery for the key fob. Is it a common battery or is it a Scion specific cell?
When you initially start it, do you close the door?
Old 01-18-2017, 12:05 PM   #30
I tried last night. Car never locked no matter what combination of actions I did. The only result is that my neighbors are more convinced than ever that I have serious mental issues.
JD001 (01-18-2017), Overdrive (01-18-2017)
Old 01-19-2017, 11:37 PM   #31
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Yep. You have one minute after unlocking to open the door., If you don't it locks again. It should never lock it's self if running though.
I will give it a try when I get home and see if it does the same.
Originally Posted by PandaSPUR View Post
Interesting... I thought the only time the car locks itself is if you unlock with key fob and dont open the doors within a certain amount of seconds.
I wish mine would lock itself as I drove off like most modern cars do now :\
FYI that feature is defaulted to around 1 minute on our cars I believe. In carista and Tech-stream it's maximum set time is 5 minutes or completely off if I remember correctly. It's sort of a useful feature for us without smart key access, but also gets annoying if your loading and unloading things quickly from the car.
Old 01-19-2017, 11:43 PM   #32
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
If you open either of the doors it disables the timer for locking the car back up. If you're going for the trunk, you can open that with its button on the key (at least in the case of the FR-S since there's no external trunk release) and that doesn't affect the doors. What situation are you finding yourself loading/unloading and having the car lock on you?
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 01-20-2017, 01:16 AM   #33
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
^ This
I can only see it being an issue if you decide to unlock the doors from inside the house, leave the keys, then take more than a minute or so to get to your car lol.
PandaSPUR is offline   Reply With Quote
Old 01-22-2017, 08:09 PM   #34
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Carista shows options for relocking the doors in various conditions. Don't remember the specifics, though.
PetrolioBenzina is offline   Reply With Quote
Old 01-22-2017, 09:22 PM   #35
ogrowup
Drives: Asphalt build in progress
Same thing just happened to me. I always keep extra keys nearby. I also can use Drone Mobile which can unlock my car.
ogrowup is offline   Reply With Quote
Old 01-23-2017, 02:39 PM   #36
NOHOME
Drives: RAVEN
I moved on. Treat car as if it is going to lock me out if I leave it running when I am not inside and act accordingly. Just another quirk.
NOHOME is offline   Reply With Quote
Old 01-23-2017, 02:57 PM   #37
1st86 Driver!
[QUOTE=Overdrive;2835448]...at least in the case of the FR-S since there's no external trunk release..QUOTE]
Out of curiosity, Not sure what you mean by that, can you explain?
Old 01-23-2017, 03:06 PM   #38
Ashikabi
Ashikabi's Avatar
[quote=Dadhawk;2837411]
There isn't a button switch whatever to open the trunk on the outside of the car. You have to use the button on the dash or the fob
Old 01-23-2017, 03:27 PM   #39
1st86 Driver!
You can open it with the key next to the license plate. Little known secret because it's so well hidden as demonstrated by me in the "First 86 Stupid Things You've Done with your 86" thread.
Old 01-23-2017, 03:32 PM   #40
Overdrive
Sittin' Sideways
Overdrive's Avatar
Well, while someone already answered, I don't see what's unclear about my statement when you don't take it out of context by quoting a fraction of the whole sentence.
The FR-S, unlike the BRZ, has no external trunk release, so you have to either use the dash button, use the fob button, or use the key in the keyhole on the trunk lid. I don't know if the BRZ external trunk release button is tied at all to the door locks and their timer, because I have an FR-S.
My point was, in response to someone saying it's inconvenient that the car locks on you when you're quickly loading and unloading it, that it shouldn't. As soon as you open a door the lock timer disables and the car will stay unlocked until you physically lock it in some way. Opening the trunk doesn't affect the door locks (again, at least in an FR-S) so I can't see how the car can lock itself back up on you once you've started opening it up. If that person gave me some examples of the situation they're taking about, perhaps I'd have to retract my statement.
Don't read any tone into this, there is none. Just felt like writing a bunch.
-O/D
2016 FR-S, Hot Lava
Old 01-23-2017, 03:39 PM   #41
Ashikabi
Ashikabi's Avatar
Yes the key will do it if you have the master key. I'm probably the only guy in the world that doesn't. Still no button/switch though
Old 01-23-2017, 03:44 PM   #42
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The BRZ behaves in the same manner (key and or button functionally work the same).
The Following User Says Thank You to Andrew025 For This Useful Post:
Overdrive (01-23-2017)
OFT KC learned Nah Software Tuning 3 03-17-2016 01:52 AM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 03:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-16-2014 12:37 AM
New thing I learned about this car.. Lord-Hydro Engine, Exhaust, Transmission 33 07-22-2014 04:52 PM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 09:15 PM
