Old 01-09-2017, 01:43 AM   #1
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
Help me decide on wheel spacer size!
Long story short, I'd like to keep my stock wheels on my 10 Series and space them out. I have literally seen almost every picture on the internet involving wheel spacers for this platform and can't decide. I'm down to 25 squared or 25F/30R. Which one is better? Is 30 too much in the rear? Is it necessary to stagger it? Would 25 handle better than a 30 in the rear?
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion
Nickel is offline   Reply With Quote
Old 01-09-2017, 09:35 AM   #2
richie incognito
Drives: BRZ- all the colours
I take it you are on stock suspension. I dont think you will get any benefit from going 30 in the back. They should be fairly flush with +25; at stock height you arent going to fill your arches anyway.
richie incognito is offline   Reply With Quote
Old 01-09-2017, 10:51 AM   #3
gramicci101
Off Topic
You can usually find sets of 20F/25R, where 25/25 or 25/30 will require you to buy individual pairs of spacers, which costs more. The only benefit to wider spacers on the rear is that the rear fenders are a touch wider than the front, so it'll look better (subjective). The handling difference between any of them and stock is minimal at best. People use spacers because they either like the look or they need to clear suspension or brake components, not to improve handling.
I have 20F/25R on my car. I could have gone 25F/30R with no issues other than cost.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
JD001 (01-09-2017), Tcoat (01-09-2017)
Old 01-09-2017, 06:20 PM   #4
Nickel
Nick
Oh, forgot to add that I am on TRD springs.
Old 01-09-2017, 06:22 PM   #5
Nickel
Nick
Cost isn't an issue, it's only $20 more. I think I'm going to do 25/30 to fill the wheel wells better.
Old 01-15-2017, 03:41 AM   #6
tyler_win_photo
tyler_win_photo's Avatar
I'd say 25/30. As for handling... you're probably not going to notice the difference between 5mm. I would recommend extended studs if you're going to run such thick spacers.
tyler_win_photo is offline   Reply With Quote
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 03:36 AM
Stoptech Front 328x28 - Minimum spacer size with OEM wheels ? asnatlas Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-13-2017 11:38 PM
Wheel Spacer Help. AndyNguyen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-27-2016 02:35 PM
size of spacer recommanded? benlaz88 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 12-10-2014 12:54 AM
Help me decide on tire/wheel size... wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-17-2013 03:45 PM
