#29 | |
Turning is for Nerds
Drives: 35 characters is not enough
For some reason manufacturers are still feeding people this line about how ELs give more power and UELs give more low down torque. Most tuners who see a lot of these however, are getting same numbers up top with a good UEL as any given EL but with more torque. Bob (Driftoffice) and Vit (VitViper)both seem to get their best numbers consistently out of Tomei and its derivatives. For me, I had a Nameless and my Tomei eats it alive literally everywhere. (that's a lie, there is an area from 4100-4200 where Nameless has about +3 ft-lbs, but I'm +40 at 3500) Same dyno, same baseline, It did exactly the same as the Ace 350 on the same fuel with a little more torque. And for you to make a statement as broad as "el headers make power from 3500 to redline" makes me think you might not know what you are talking about. Every header performs differently and 3500 is smack in the middle of the torque deficit on most equal length headers. Give this a read http://blog.vittuned.com/just-a-coup...-vs-tomei-uel/
| The Following 3 Users Say Thank You to Decay107 For This Useful Post: |
#30 | |
Drives: Rb25 neo brz
From what i have seen, i can say this statement is fairly accurate. After having all kinds of headers on our dyno none stand out with +/- 3 HP or more. |
#31 | |
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
| The Following User Says Thank You to Jonsey For This Useful Post: | max20s14 (12-20-2016) |
#32 |
Drives: FR-S Whiteout
Like I was saying earlier, the biggest difference appears to be at the low mid range while peak numbers are very similar. If you look at Jonse's dyno you see the lowest point in the torque curve is after 3600 closer to 4000rpm. You'll tend to see this in most of the EL headers. On the UEL dynos you'll tend to see the lowest point before 3500,and the dip is typically less pronounced.
For me the dip in power at 4000rpm is very annoying, but it might not bother others. Driving around town, if I'm revving up to 4000rpm i'm probably trying to accelerate quickly only to be met with a drop in power. I think that should be your biggest consideration in terms of performance as that's were the largest difference is between the two types.
Intent > Content
cowardice is the mother of cruelty. |
#33 |
Very fair.
My car is 97% track car, so it is very annoying if I am ever below 4,000 rpm. Plus after tracking the car I don't care much about playing on the street and the power is still substantially better than stock everywhere.
#34 |
Drives: 2012 Toyota 86
#35 | |
Drives: 2016 ZC6
Are you talking about the HKS header + front pipe combo. There's no OP portion like the Apexi system. http://www.hks-power.co.jp/product/8...ust/index.html http://www.hks-power.co.jp/product/8..._manifold.html Because unless I'm reading the info wrong, there's no overpipe in there.
My build thread: Pointmutation's WRB BRZ build
#36 |
Drives: 14' Raven M/T - 02' is300
I thought I would add more related information:
http://blog.perrinperformance.com/br...n-and-proving/ |
#37 | |
Drives: 2013 BRZ Limited GB 6MT
Tomei vs HKS headers for gains?
I recently had my car tuned on Dyno Jet with FF kit at Moto-East. Setup is Tomei UEL, Crawford BPB, Namelesss Resonated and Catted OP+FP, Greddy Supreme SP CB. E62 at the time of tuning and max out at 198whp for DD tune. '13 BRZ with 60k miles. Previously tuned with OFT Stage 2. I noticed that your chart shows a torque dip between 3000-3500 rpm. I don't know much about tuning but it's pretty obvious that UEL seems to fix the torque dip issue. I might be wrong but the numbers are pretty obvious.
| The Following User Says Thank You to username404 For This Useful Post: | max20s14 (12-23-2016) |
#38 |
Drives: Subaru BRZ limited 2015
can you tell me in which thread are the dynos of each headers
| WTB Tomei UEL headers | pleasurevictim | Want-To-Buy Requests | 3 | 11-12-2016 04:51 PM |
| Tomei UEL vs JDL UEL headers | tdotBRZ | Engine, Exhaust, Transmission | 46 | 03-20-2016 11:25 AM |
| Tomei headers - why no cat? | gMit | Engine, Exhaust, Transmission | 8 | 01-06-2016 01:07 AM |
| WTB Tomei Type 80, Tomei UEL headers | Justin91M | Want-To-Buy Requests | 1 | 12-19-2014 12:42 PM |
| gains from catless headers? | Gilwith1l | Engine, Exhaust, Transmission | 12 | 04-03-2014 10:26 PM |
