86WORX
Old 01-10-2017, 10:44 PM   #15
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Installed a Manzo Racing Diffuser diffuser today and re-lubricated the clutch fork again. Pictures of the diffuser will come once it stops raining like crazy outside lol. Huge storm in the Bay Area this week...
treminaor is offline   Reply With Quote
Old 01-10-2017, 11:38 PM   #16
Ultramaroon
fabulous
Ultramaroon's Avatar
Let me know when you're ready to drop the transmission. :/
Old 01-11-2017, 12:31 AM   #17
treminaor
"DGM BRZ"
treminaor's Avatar
I think the first time I did it this I was a little light on the greasing, so I used a little more this time. Still probably didn't hit it perfectly, its a shitty angle to work with and you can't see exactly where it's going.
I know dropping the trans is inevitable but I wanna put it off as long as I can without it becoming a bigger problem. Right now it's just a nuisance that takes 10 minutes to fix.
The Following User Says Thank You to treminaor For This Useful Post:
Ultramaroon (01-11-2017)
Old 01-11-2017, 12:35 AM   #18
Ultramaroon
fabulous
It'll be time when, even after you've lubed the fork pivot, you can feel the TOB binding on the snout. Be super careful because that's the real reason the forks are letting go.
treminaor (01-11-2017)
Old 01-11-2017, 12:37 AM   #19
treminaor
"DGM BRZ"
treminaor's Avatar
Shouldn't that be covered by my dealer warranty? If it's something they can feel and recognize is wrong with the pedal feel, they should fix it.
They blew me off the first time because according to them it was just a noise.
Old 01-11-2017, 12:39 AM   #20
Ultramaroon
fabulous
Oh, definitely. My bad. I keep forgetting about warranties. Not kidding.
Old 01-11-2017, 12:44 AM   #21
treminaor
"DGM BRZ"
treminaor's Avatar
So to clarify, you're saying that binding/grinding feeling at the bottom of the pedal travel is just going to keep getting worse? And the solution they should arrive at is to replace the TOB and refresh the lubricant?
Old 01-11-2017, 12:56 AM   #22
Ultramaroon
fabulous
Yes. They should also replace the snout (front cover.) The old one will be chafed and will just accelerate the wear of the new TOB.
Old 01-11-2017, 12:58 AM   #23
treminaor
"DGM BRZ"
treminaor's Avatar
Any way to guess how much longer the current TOB will last?
Old 01-11-2017, 01:13 AM   #24
Ultramaroon
fabulous
There's nothing actually wrong with the "bearing" part of the TOB. It's just that the lubricant on that sliding joint has failed. What's left is a sticky mess mixed with clutch dust.
If it starts to really hang up you risk breaking the clutch fork.
Old 01-11-2017, 08:47 AM   #25
CFC BRZ
Drives: 2015 BRZ Limited
Care to share how you installed the hella horns? Did you drill holes into the metal bar and mount the horns that way? I'm planning to add mine in the spring and am trying to find the best way to do it.
CFC BRZ is offline   Reply With Quote
Old 01-11-2017, 06:02 PM   #26
treminaor
"DGM BRZ"
treminaor's Avatar
I followed a short and sweet imgur DIY that someone with a white BRZ posted a long time ago... lets see if I can find it again.
Basically yes I drilled mount holes into the front metal crash bar and used a combination of bolts and nuts to secure and space the horn brackets properly.
Yep this is it http://imgur.com/a/may4m
CFC BRZ (01-14-2017)
Old 01-26-2017, 08:54 PM   #27
treminaor
"DGM BRZ"
treminaor's Avatar
Since we're finally having a week-long break in the storms here in CA I figured I would take the opportunity to get the multiple layers of dirt off.
carsebuco (04-25-2017)
Old 04-25-2017, 06:23 PM   #28
treminaor
"DGM BRZ"
treminaor's Avatar
Washed again today, worst thing about hand washes is noticing all the new rock chips and parking dents. What's the best way to clean the grime off of exhaust tips?
Search this Thread:
Advanced Search
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 11:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) -- General Topics 48 08-09-2013 07:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
