#43 | |
"DGM BRZ"
Drives: 2016 BRZ Limited
#44 | |
fabulous
#45 |
fabulous
Yes.
#46 |
"DGM BRZ"
What's your opinion these days on the spring situation? I know you kept going back and forth over the years in that slave thread.I used to drive a Porsche Boxster S so I know what's it's like to have a stiff clutch, and I don't exactly want to go back to that but I would like it to feel a bit more responsive and traditional. It was kind of hilarious going from that car to this, I felt like I was pushing my foot into thin air and I hated it at first. I've gotten used to getting smoother shifts in this car but I have to think about it to make it happen, if I'm driving alone and stop giving a f*ck the shifts are a little rocky, not that I mind much anymore. |
#47 | |
fabulous
Just don't toss the parts.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | treminaor (11-26-2016) |
#48 | |
"DGM BRZ"
Do I need anyone to help me bleed the clutch if I leave that spring alone? If I understood correctly the pedal stays pushed into the floor. |
#49 | |
fabulous
I just did 2 more swaps for friends a couple weeks ago. I don't even go through a measurable amount of fluid anymore, or those gaskets. ~~~~~~~~~~~~~~~~~~~~~~ I start by breaking loose the banjo fitting and retighten just a little snug. Unbolt the slave cylinder. Have the new one at the ready with the rubber stopper removed. Squeeze the fluid out of the old one by compressing the piston. While holding the piston and lifting the banjo fitting above the level of the fluid in the reservoir, detach the banjo fitting. Mind that gasket that goes against the cylinder. Let go of the piston only after the line is detached. It's tricky but doable. Practice the moves first. With the piston in the new one compressed, attach the hydraulic line and tighten a little. Release the piston. It will suck in the fluid. Mount the new slave. Wait a few minutes for the bubbles inside the cavity to coalesce and rise to the top. Crack open the bleed valve with a towel underneath. Give it a few seconds. The air will simply work itself out. Close the bleed valve. Done. ~~~~~~~~~~~~~~~~~~~~~~ I've done the last five like this. Even taking my time it's like 20 minutes.
#50 |
"DGM BRZ"
@Ultramaroon Is it normal that I don't hear the squeak when I manipulate the fork myself?
Edit: the answer is yes apparently. Just finished putting the slave back and no more squeak after adding a blob of grease Thanks!!
| The Following User Says Thank You to treminaor For This Useful Post: | Ultramaroon (12-02-2016) |
#51 | ||
Drives: 2016 Oceanic, "base" model
jumping into this discussion:
I don't think usage is the real issue. Mine has been squeaking for the past 10k miles or so (I have 34k on my 2016) and I drive something like 90% freeway, opposite of you. Quote:
Which is what I've been doing, so far. I figured some day when I have free time I would grease up whatever was easily accessible to be greased. |
| The Following 2 Users Say Thank You to MrDinkleman For This Useful Post: | Tcoat (12-02-2016), Ultramaroon (12-02-2016) |
#52 | |
"DGM BRZ"
#53 |
fabulous
Love your sig image.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | treminaor (12-02-2016) |
#54 | |
fabulous
Maybe the OEM grease is just shit. I'll follow with pics this summer when I drop the trans again. I plan on staying ahead of this.
#55 | |
"DGM BRZ"
![]() Thanks! I could make one of your car if you send me a pic, least I could do for your help.
| Clutch Fork Squeaks | fantah | Hawaii | 28 | 11-07-2018 02:22 PM |
| Clutch squeaks | bhbnuckle | CANADA | 8 | 08-19-2016 11:56 PM |
| stiffer clutch= broken Clutch fork | KAR | Engine, Exhaust, Transmission | 1 | 04-25-2016 06:31 AM |
| Clutch Fork Broken | rick s | Issues | Warranty | Recalls / TSB | 8 | 08-27-2015 02:49 PM |
| HELP! Clutch fork retainer clips | teamKS | Engine, Exhaust, Transmission | 3 | 08-13-2015 01:46 AM |
