#15 |
I have never had mine apart so will have to concede to you on this one. Mine makes no noise though so don't know what is different between them all.
#16 | |
fabulous
I'd buy your used car over mine in a heartbeat. Well, except mine hasn't ever seen road salt.
#17 | |
Actually I thought we established that it was my vastly superior shifting skills that has preserved mine!
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (11-24-2016) |
#18 | |
fabulous
#19 | |
"DGM BRZ"
Drives: 2016 BRZ Limited
I drive my car pretty hard, the way it was built to be driven in my opinion - so I wouldn't say I'm at all easy on my clutch but I certainly don't grind through gears or abuse it in any other way - I know how to drive and I certainly didn't learn on this car. I do however take advantage of freeway onramps, I race light to light frequently, I launch the car, I like to have a good time with it (haven't tracked it yet). However every other aspect of the car is still in great shape, the tires and brakes are no where near worn yet so I can't imagine the clutch should look any worse if the proper lubrication had been used from the start. |
| The Following User Says Thank You to treminaor For This Useful Post: | Tcoat (11-24-2016) |
#20 | |
![]() You went and used up all of the clutch fork grease and didn't give it a chance to grow some more ..... ![]() humfrz |
#21 | |
@Ultramaroon , I thought you had a method of sneaking past the rubber boot and lubricating whatever makes that squeak ..... ?? humfrz |
#22 |
"DGM BRZ"
That's how I drive my cars, never had a problem with grease turning to sludge before this. If I was going drive it like a grandma it the whole time I would have bought a manual Corolla and called it a day.
#23 | |
"DGM BRZ"
#24 | |
However, it's my understanding that the clutch fork is a piece of metal that is pushed on one end (that has sort of a socket) by a rod (that comes out of the slave cylinder), pivots in the center on a ball and socket thingy and has two forks on the other end that pushes against the TOB (release bearing). Now, where is it squeaking ....... I reckon at one or more of those contact points .... ?? So, if that is the case, and one could reach the squeaking joint from sneaking past the rod boot to get some grease in there ...... that would solve the problem ...... although it wouldn't be all clean and pretty and may require more grease from time to time. Now, it appears that we have four possible methods for dealing with the situation. * the @Tcoat method ..... which is to ignore that the problem exists, because his old worn out ears can't hear the squeak. * the @Ultramaroon method ...... which is to drop the transmission, clean it up and lubricate it with a HD lubricant. * the Bubba method ..... stick the plastic tube from a silicone spray can, past the rubber boot of the slave cylinder rod and pull the trigger until the fork stops squeaking. * the humfrz method ....... ignore it although it may wear out the parts after a few hundreds of thousands of miles 30 minutes to ....... turkey time !! ......... ![]() humfrz |
#25 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (11-24-2016) |
#26 | |
#27 | ||
fabulous
OP, if you just grab the end of the fork and pull it back to compress the slave piston, you can get a few good jiggles of the fork about the main pivot. That will quiet it down for a little while.
#28 |
fabulous
Tcoat & humfrz are good guys. We just cut up a LOT. No offense intended.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (11-24-2016) |
| Clutch Fork Squeaks | fantah | Hawaii | 28 | 11-07-2018 02:22 PM |
| Clutch squeaks | bhbnuckle | CANADA | 8 | 08-19-2016 11:56 PM |
| stiffer clutch= broken Clutch fork | KAR | Engine, Exhaust, Transmission | 1 | 04-25-2016 06:31 AM |
| Clutch Fork Broken | rick s | Issues | Warranty | Recalls / TSB | 8 | 08-27-2015 02:49 PM |
| HELP! Clutch fork retainer clips | teamKS | Engine, Exhaust, Transmission | 3 | 08-13-2015 01:46 AM |
