Old 11-16-2016, 05:19 PM   #15
JDubs
Drives: 2014 BRZ Limited; *SOLD*
Lots of good advice here, and definitely helps me out!
I know you never know who you are talking to on the internet... I'm 43 and have bought more tires in my life than I like to think of ($$$!). I've changed sizes, gone from summer to all season and back again, gotten all terrain and "low rolling resistance". I know about the compromises between contact patch and bigger sidewall, larger diameter etc. I asked here because I know you guys have had experience with these cars specifically and would know what works... you didn't disappoint.
I was leaning toward getting different wheels, but based on what you guys have said I can get a nice 225 summer tire and get what I need with the factory wheels. Yes, I don't track the car but that is not what is going through your mind when you attack a curve on a mountain road... you just want confidence. You can't drive it to the edge and slide through it.
JDubs is offline   Reply With Quote
The Following 2 Users Say Thank You to JDubs For This Useful Post:
Mim (11-17-2016), Toyarzee (11-16-2016)
Old 11-16-2016, 05:58 PM   #16
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
225 tires won't help you drive the car at the limit any greater than 215's would on a curvy road. Your contact patch will still be roughly the same with 215 or 225 tires on a 7" wheel.
In fact, 225's will make you lose tire feel in most cases if you will be running them on a 7" wheel.
Get 225 tires if you like the meaty look. But if you think that you'll be able to drive at the limit with more confidence with a 225 tire on a 7" wheel. You are mistaken.
Get proper summer tires and you will feel the confidence. The stock primacy tires are a joke. They were used for the purpose of marketing to showcase how drift friendly the car is and how good your MPG are. Those tires belong on a Economy car.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 11-16-2016, 06:24 PM   #17
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Well, @Mr.Impreza, you have already posted near identical opinions and responses on this same thread. Not sure why you have so much angst built up over this topic, but I'd dial back the hate for SLIGHTLY larger tires and oem primaries. I assure you they are not crap, as the price tag alone would suggest otherwise, plus there are others (myself included) who have hit up canyons and tracks with these tires and those options suggested above with great (albeit limiting over other more aggressive and serious options) success. One thing is absolutely certain, you will not lose feedback and steering response from a jump from 215 to 225 summer tires. Please stop ushering in misinformation like it's the gospel.
If nothing else, I respectfully agree to disagree, if for no other reasons than those based off the information the OP has provided and his given intended use of the car.
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
JDM4E (11-16-2016)
Old 11-16-2016, 06:31 PM   #18
JDubs
Please don't get it twisted... I was actually talking about NOT driving at the limit.
The Following User Says Thank You to JDubs For This Useful Post:
Old 11-16-2016, 08:43 PM   #19
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
If you were local I'd have you drive all my available wheel and tire combos back to back on my car. 215 primacies, 225 RE71R's, 215 Conti DW, 215 Conti extreme contact, and finally 225 S-04s.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 11-17-2016, 12:18 AM   #20
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Out of those, what's your favorite setup?
-Josh
Old 11-17-2016, 12:54 AM   #21
gramicci101
Off Topic
@JDubs, tires play a huge part of happy fun driving times, but you should also consider a performance alignment and negative camber. Camber bolts are a cheap addition and they allow you to get negative camber on the front. The rear is a little more expensive to adjust, so I wouldn't worry about that until you get around to lowering the car. But if you can get -1 to -1.5 in the front that will make your windy roads that much more fun.
http://www.ft86speedfactory.com/spc-...l#.WC02y3i9LCQ
Old 11-17-2016, 08:21 AM   #22
JDubs
Very generous, thank you. I think I'll just research the brands mentioned here and pick one. I don't think I can go wrong for my purposes.
Old 11-17-2016, 10:50 AM   #23
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
All 17s?
venturaII is offline   Reply With Quote
Old 11-17-2016, 10:59 AM   #24
JazzleSAURUS
-Josh
For daily driving and enjoying myself, the S-04's. The RE71R's are genuinely amazing, but live on the Forester XT. The Autox, genuinely fast car.
The S-04's are glorious tires.
Old 11-17-2016, 11:00 AM   #25
JazzleSAURUS
Originally Posted by venturaII View Post
All 17s?
Yes, I'm a sucker for function
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
venturaII (11-17-2016)
Old 11-17-2016, 11:01 AM   #26
venturaII
venturaII's Avatar
Function is exactly why I went with 16s...
Old 11-17-2016, 11:05 AM   #27
JazzleSAURUS
It's why I keep my rubber fat!
My FXT has 15" RCG4's to clear the 4/2 pots for winter mode. The BRZ wears 16" in winter.
The 17 with a slightly wider tire gave me enough compliance and comfort with a more aggressive tire that I had a lot of mechanical grip. I like it.
Old 11-17-2016, 11:16 AM   #28
venturaII
venturaII's Avatar
Basically the same attitude is why I went with 16s...they still clear brakes, including the Wilwood WRX fronts, and I get the extra sidewall I want. Works very well with a 225...makes the car very enjoyable. Our roads are a fucking abomination...
Factory Wheels and Primacy Tires Deep Six Wheels and Tires 3 10-17-2016 08:35 AM
FS: Factory Wheels And Tires (No TPMS) FR-S Matt Wheels and Tires 11 06-23-2013 10:50 PM
WTB: Factory OEM BRZ wheels and tires Meeners Wheels and Tires 1 10-20-2012 02:12 AM
Factory OEM FR-S wheels and tires for sale $650 FRES86 Wheels and Tires 0 09-06-2012 01:30 AM
WTB: factory set of FR-S/BRZ wheels and tires FRSowner Wheels and Tires 0 09-04-2012 05:54 PM
