#127 |
Drives: brz 2017 hksv2
It does go landscape, you just have to set up a new dash from scratch
It works pretty everywhere, it s just a tad annoying to set up |
#128 |
Drives: '14
#129 | |
Drives: 14 BSP Edelbrock BRZ
#130 | |
Drives: GT86
#131 |
After updating to 3.9.3 version everything still behaves the same? The ECUTek guys are in Europe, maybe there is something different about the ECMs and how they talk to the bluetooth module.
#132 | |
Drives: GT86
They just updated to 3.9.4.1 |
#133 |
Yeah, I saw the update this morning. Haven't been back in the car yet to try it out.
#134 |
That update got is working again, but it wiped out all of my dashboard setups. Argh!
#135 |
Drives: BRZ Turbo
Anyone have trouble with the dongle disconnecting? Mine doesn't maintain a constant connection anymore
#137 |
Drives: BRZ Turbo
#138 |
Drives: 2017 toyota 86
bbfly-B4 OBD II OBD2 16 Pin Splitter Extension 1 x Male and 2 x Female Extension Cable Adapter (1FT/30CM) https://www.amazon.com/dp/B071HP9JFJ..._k41uEbGKA83BD
I have one going to my scangauge connected just under the normal OBD port only a little lower so much easier to get to but still out of the way. And i have the other one running to the right side tucked behind the side panel plastic trim piece close to my knee with just the connection sticking out super easy to get to, and still out of the way though. i use that one for ecutek or any time i need to connect something to OBD. Connections are really easy to plug into but also very sturdy strong connection. Much better then oem connector in every way. |
#139 |
#140 |
Drives: 2017 Toyota 86 860 W
So is there a head unit that can run EcuConnect app or not? I’ve seen a lot about jail breaking and Bluetooth naming convention issues. I’d really like to throw an android head unit in download the app on it and be able to do everything without my phone.
| Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM | DeliciousTuning | Software Tuning | 329 | 12-31-2023 04:47 AM |
| My Bluetooth in my 2014 FRS so stay connect | Case1010 | Electronics | Audio | NAV | Infotainment | 3 | 02-24-2016 07:57 PM |
| Header/overpipe interface | misooscar | Engine, Exhaust, Transmission | 4 | 11-23-2014 12:21 AM |
| Garmin GPS Bluetooth Won't Connect | frssfo | Electronics | Audio | NAV | Infotainment | 0 | 08-20-2014 11:55 PM |
| Bluetooth connect mutes android NAV | Rob_g | Electronics | Audio | NAV | Infotainment | 6 | 07-04-2012 05:38 PM |
