#29 |
Drives: 2013 Subaru BRZ
oh when does it come out and how much does it cost? im from PA, and have no idea what the laguna seca test, or "irvine" test are.
#30 | |
Irvine has draconian noise enforcement. If your car can drive in Irvine without getting pulled over, it means you won't be pissing your neighbors off. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | whataboutbob (11-02-2016) |
#31 |
oh, and when will it come out and how much does it cost
#32 |
Drives: Track preped NA FRS
That is the question that has been going on around the forums for close to a year now? I have no idea of how long it will take, but based on the amount of research I can tell you it wont be a cheap alternative thats for sure. Im waiting on it as well, since my longterms plans include a JRSC and it seems thats what this system is being tested on. We'll see when it comes out I guess.
#33 | |
is your car supercharged as well? is there any loss of power going with the dual muffler setup? will i lose any power going this route? i think im set on replacing my front pipe with the catted quite pipe from JDL, as well as doing this dual muffler setup, but i was wondering if theres any loss of power from that? would i also need to get my car retuned? |
#34 | |
My car is not supercharged. I felt no loss in power, Borla's muffler is a straight through design. I didn't get a retune, because that muffler in that spot is no different than a stock or aftermarket resonator, only difference is more canister volume. I would buy the muffler first and then see if you still need to change out the front pipe. IMO the resonators on all the aftermarket front pipes are so small, the they make very little difference sound wise. |
| The Following User Says Thank You to toeout For This Useful Post: | calic (11-05-2016) |
#35 | |
sounds good thx for the advice. think ill go with this setup. i asked my tuning shop about needing it retuned but they are away at SEMA. i guess it probably doesn't need it anyways. |
| The Following User Says Thank You to morswestford For This Useful Post: | calic (11-05-2016) |
#36 | |
Drives: Subaru Brz
#37 | |
It does not. It bolts up to the front pipe, but the connection to the axle back has to be welded together. Good spot for it is the straight section after the Borla muffler, you can see it on my picture. |
| The Following User Says Thank You to toeout For This Useful Post: | calic (11-02-2016) |
#38 | |
Drives: Subaru Brz
![]() I kind of followed your advice. I'm running the unresonated perrin 2.5, so I took our stock mid pipe resonator and cut it. And had my shop weld it to the perrin midpipe. Basically it's the same thing as the perrin mid pipe except they want 300 bucks for it. The car has no more rasp and sounds like it should of been loud, but not to loud. I feel like I can change the front pipe out without killing my ears now. Thanks again for the inspiration and a easy mod to do. As long as you didn't sell your stock parts.
| Tags |
| borla, cold engine start, invidia, jackson racing, perrin |
| Extremely Hot Weather - Engine Oil Viscosity | Guru86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 11-22-2017 11:07 AM |
| Halp! Supercharger extremely loud | autograph | Forced Induction | 15 | 09-24-2015 05:32 PM |
| Loud engine noise? | Rifle | Engine, Exhaust, Transmission | 9 | 08-16-2015 01:26 PM |
| FR-S Loud Engine Noise | White0utFrs | Issues | Warranty | Recalls / TSB | 15 | 09-20-2013 09:28 PM |
| Engine is quite noisy | Rob_g | Issues | Warranty | Recalls / TSB | 9 | 10-14-2012 09:41 AM |
