86WORX
Old 06-10-2017, 07:10 PM   #645
Zer0
Drives: 2015 frs
@DustinS how much room do you have in front of the crank pulley? I'm going LSA just looking for a heads up on what I may have to do to clear the lower radiator and radiator support.
Zer0 is offline   Reply With Quote
Old 06-11-2017, 12:14 AM   #646
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
LSA crank pulley is HUGE. You're going to have to cut. LS3 pulley just barely fits on my setup, clearance is a few mm. Stock hood isn't going to fit either.
Don't give up though, I want to see it done.
wutsaiu is offline   Reply With Quote
The Following User Says Thank You to wutsaiu For This Useful Post:
Zer0 (06-11-2017)
Old 06-11-2017, 02:06 AM   #647
Zer0
Drives: 2015 frs
Yeah I planned on cutting up the hood for the supercharger
One other option for the front engine clearance would be to see if I could adapt a LS9 front supercharger snout onto the LSA supercharger along with LS9 accessory drive kit. Not sure that would help my front engine to radiator clearance enough.
Old 06-11-2017, 06:22 PM   #648
wooly35
Drives: 2014 Scion FR-S LS3
You will have about 2 1/2 inches between the crank and radiator...if you lay the radiator at an angle and cut out the middle brace...and use the mishimoto radiator. lol That's how much clearance I have... Dustin might have more or less since he used the stock radiator.
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
Zer0 (06-11-2017)
Old 06-12-2017, 11:32 AM   #649
wrxdriver2002
Drives: 2015 Subaru BRZ
From an overall length, the LSA pulley is no larger than the LS3 pulley, which is why you can run an LSA blower with the stock LS3 crank pulley and a longer 6 ribbed belt. GM, with the LSA inset the AC compressor and the accessory drive belt and put the blower drive where the accessory drive is on the LS3 pulley.
IF anyone wanted to gain a little bit of clearance, you can run LSA accessories with the ATI pulley (The supercharger portion unbolts for easy supercharger under drive or overdrive pulleys)
IF anyone wants to look through them, here are photos of my build. I've got an LSA drivetrain in my BRZ. Happy to answer any questions about the process, but please PM me as I don't want to hijack this thread.
https://1drv.ms/f/s!AphYz26xiEW0goUNll7hUYxJsasZuw
wrxdriver2002 is offline   Reply With Quote
The Following 4 Users Say Thank You to wrxdriver2002 For This Useful Post:
DustinS (06-12-2017), ILLSMOQ (06-12-2017), wooly35 (06-12-2017), Zer0 (06-12-2017)
Old 06-12-2017, 11:50 AM   #650
wutsaiu
wutsaiu's Avatar
Looks like a huge difference to me. Love your build btw, very complex.
Zer0 (06-12-2017)
Old 06-12-2017, 11:56 AM   #651
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Running Full Blown Radiator, Wouldn't trust a stock radiator with a high output V8 haha.
Tilting the radiator and getting rid of the factory latch or even modifying it like CX Racing does is a really good idea. It gives so Much more room.
Been playing with the car more. Spins 2nd, 3rd, and even 4th at times. Think I need to get some stickier and/or wider tires.
DustinS is offline   Reply With Quote
Old 06-12-2017, 11:59 AM   #652
DustinS
DustinS's Avatar
I don't mind that kind of discussion here. Love your build. I keep looking at superchargers, but I know they are can be a bit of a pain to keep cool when being pushed on a track. So if I do get a stupid idea to add more power it will probably be turbo.
The Following User Says Thank You to DustinS For This Useful Post:
Zer0 (06-12-2017)
Old 06-12-2017, 12:13 PM   #653
DustinS
DustinS's Avatar
@wrxdriver2002 Your exhaust is awesome. I Love it.
Edit: Also the brakes. Very Jealous.
Old 06-12-2017, 12:21 PM   #654
wrxdriver2002
Thanks I'm working through a few small issues (Got my car as a total. Started with the start button before swap, after swap it won't start with the button).
All of the LS3's that I've played with have had the pulley on the right in this picture from the factory (I've never gotten a crate motor, the motors were sourced from wrecked cars as complete drivetrains)
All of the LSA's have had the pulley in the middle. I don't know what the pulley on the right is from, but if I had to guess, I'd say some sort of corvette LS1/2.
The Following User Says Thank You to wrxdriver2002 For This Useful Post:
Zer0 (06-13-2017)
Old 06-12-2017, 12:29 PM   #655
wrxdriver2002
I wanted to go turbo as well. I will more than likely build another one that's L86 or LT4 based and go twin turbo with that one. i've never owned a supercharged vehicle before, so I figured why not.
As far as cooling goes, I'm actually using the AC compressor to cool the charge coming out of the supercharger. People around the world have had fantastic luck with it so I am hoping that it works great for my application as well. As soon as I work the starting issue out, I will tackle the AC system. For now, I've not driven the car more than 150 miles under it's own power since I got it running a year ago (may / june 2016) so I wasn't terribly worried about the blower's cooling system.
From a engine cooling standpoint, I've never had the cooling fans cycle on their own. I sat in stop and go traffic a month or so ago for about an hour and never had the temp gauge even move. The radiator is a much larger than stock one with an integrated engine oil cooler (I liked the fact that it helps warm the engine oil up faster and keep it cool when it reaches operating temp) As part of functional testing, the fans turn on and off when commanded by the GM Scan tool so I know they work. With the subaru drivetrain the fans would cycle on / off about every 2 minutes while sitting there idling, after the car had warmed up. All of my vehicle experience has come from the Subaru world so it's really neat to see differences between other manufacturers.
Old 06-12-2017, 12:38 PM   #656
wutsaiu
wutsaiu's Avatar
Looks like Left is LS3, Middle is LSA, and Right is truck LS.
My 6.2 was from a truck, I swapped out the long truck Pulley for a stock LS3 pulley.
Zer0 (06-13-2017)
Old 06-12-2017, 05:25 PM   #657
DustinS
DustinS's Avatar
Forgot to post up a picture of the steering rack.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
wutsaiu (06-12-2017), Zer0 (06-13-2017)
Old 06-12-2017, 09:53 PM   #658
wooly35
ha I completely forgot you used the FB radiator. lol
Search this Thread:
Advanced Search
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) -- General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) -- General Topics 8 06-12-2012 08:32 PM
