#491 | |
Drives: 2013 Ultramarine FR-S
Edit: Seems that it can be optional. Plug is there, but sensor is not. I will go ahead and get one and install it, but should be fine without it. I may just install my aftermarket gauge into the port. Also got to thinking about alternator wiring. Do I need to tie in the alternator wiring into the factory harness? or is that something that shouldn't really matter.
#492 |
When you mean wiring, which wiring are you referring to?
#493 |
Plug coming off the Alternator into the GM harness. Is that something that needs to be tied into the factory alternator plug somehow, or doesn't really matter. May be controlled by can bus module. Asking before I try and tackle getting everything set-up.
#494 |
That should go to gm ecu
#495 | |
Drives: FRS Silver LS1 swapped.
| The Following User Says Thank You to cf6mech For This Useful Post: | wooly35 (04-30-2017) |
#496 |
It seems your missing a lot of information on their build thread, like what needs to come out of the trans tunnel , the reason for the notches and other things......read it carefully......and frequently.
#497 |
#498 |
Drives: 2015 frs
#499 |
Kind of an inside Joke between Collin and I,... I got a unique situation that him and I still need to fix, ....yes sorry Dustin for the thread jack.
| The Following User Says Thank You to cf6mech For This Useful Post: | Zer0 (04-30-2017) |
#500 |
I have read it quite a few times. Not to mention looked through their entire photo album for the swap. A lot of what is required hasn't been posted. I mis-understood the notching the pan thing as I though they notched it for sway bar fitment. When I went back through, I noticed it was for steering rack.
#501 | |
Drives: 2001 Impreza 2.5 RS
Colin Beck
#502 |
Drives: 2015 frs
Nice hopefully I can get my set-up hooked up by you to run the power steering.
#503 |
Terrible Rain and storms this weekend. A lot of flooding. So not much progress, and by that I mean I put the wiring harness through a hole in the firewall. Weather looks really good this week. So hopefully everything progresses nicely. I will also have an update on the rywire master cylinder adapter.
| The Following 2 Users Say Thank You to DustinS For This Useful Post: | M1K3 (05-01-2017), Sportsguy83 (05-01-2017) |
#504 | |
| The Following User Says Thank You to all4spl For This Useful Post: | cf6mech (07-04-2017) |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 13 | 03-22-2016 04:07 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-22-2015 12:38 AM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 12:14 PM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 08:32 PM |
