#463 |
Drives: 2013 Ultramarine FR-S
2.5" back to 3" Greddy Exhaust. I may switch to 3" after it clear the subframe and everything in the future, but for right now I have the 2.5" on hand and the welding material for it.
| The Following User Says Thank You to DustinS For This Useful Post: | Sportsguy83 (04-26-2017) |
#464 |
And you're saying there is no room to put a 3" vband on the header itself? I might need to see a picture to see how close it is to the steering shaft like youre saying.
#465 |
I'll get the tape measure out and try and get better pictures if weather permits. If not, it may be tomorrow before I can get under the car.
edit: To clarify, Passenger side can fit whatever you want. TONS of room. The way the driver side header exits, it is extremely tight and not even enough space for a smooth 2.5" bend without a weird bend. I'll probably just get a video to try and show it better.
#466 |
I'm wondering if this is a better option
https://www.summitracing.com/parts/h...FUw2gQodjhkJ6w You can either have 1 7/8 and 2.5" collector or 1 3/4 and 3" collector with possibly no fitment issues as we all know corvettes have little to no room. |
| The Following User Says Thank You to all4spl For This Useful Post: | DustinS (04-26-2017) |
#467 |
and it looks like you wouldn't have any issues with plug wires on the C6 blackhearts.
#468 |
Yes I think those would be a good set to go with.
#469 |
a bit more expensive though haha I'm interested in seeing what you come up with.
#470 |
Storming so I only got a little bit done last night. Wrapped the passenger side manifold. That was a nightmare. Assembled the fuel rails, and the pressure regulator.
[/url] [/url] [/url]
#471 |
Well after drawing up a template for the Clutch Master adapter, I went ahead and ordered the Rywire one. Looked close enough to me and a few friends I trust. Guess we will find out here in a bit.
#472 |
Drives: 2015 frs
[QUOTE=DustinS;2900110]Well after drawing up a template for the Clutch Master adapter, I went ahead and ordered the Rywire one. Looked close enough to me and a few friends I trust. Guess we will find out here in a bit.
If it doesn't fit just right you can machine aluminum with a router. I made a adapter for a Wilwood master cylinder for my FRS to get rid of the power brakes. |
| The Following User Says Thank You to Zer0 For This Useful Post: | DustinS (04-27-2017) |
#473 |
That was the plan. Slot the holes a bit if it doesn't fit. If it isn't anywhere close, I will just have a friend machine one up. How does the car do without the booster?
#474 |
how does the brake booster delete work? Do you still have abs? I'm interested in doing this.
| The Following User Says Thank You to all4spl For This Useful Post: | Zer0 (04-28-2017) |
#476 |
I Love custom Turbo kits
Drives: Limited BRZ
@Amir Ghadiri's car was used to design the CX racing kit, perhaps he could clarify about the swaybar fitment?
This is the only picture I could find on his journal that shows the swaybar..
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 13 | 03-22-2016 04:07 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-22-2015 12:38 AM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 12:14 PM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 08:32 PM |
