Old 04-20-2017, 08:56 PM   #435
wooly35
Drives: 2014 Scion FR-S LS3
dang, looks like more spot welds to cut out for the transmission.
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
DustinS (04-21-2017)
Old 04-21-2017, 12:29 PM   #436
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
That was one of the worst parts of the swap.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Old 04-21-2017, 12:46 PM   #437
toast
Drives: 14 BSP Edelbrock BRZ
cutting them would suck. If you can clearly visualize them a spotweld cutter would be the way to go for $40.
http://www.eastwood.com/ew-skip-proo...ld-cutter.html
toast is offline   Reply With Quote
Old 04-21-2017, 12:48 PM   #438
DustinS
DustinS's Avatar
I used a spot weld cutter, still not fun, mostly because there isn't a lot of room in there.
Edit: Picture of the Stock pedal vs LS Pedal
Quite different. Going to have to come up with something fancy.
Old 04-22-2017, 11:21 PM   #439
wooly35
Good god! In... out... in... out.... beat the crap out of the transmission tunnel, cut out more for the shifter... in... out... in... out... not gonna finish tonight. lol
DustinS (04-22-2017)
Old 04-22-2017, 11:37 PM   #440
DustinS
DustinS's Avatar
Haha!! That's what my tomorrow looks like!
wooly35 (04-23-2017)
Old 04-23-2017, 02:34 AM   #441
Bullitt2496
Guest
Posts: n/a
That plug wire is going to melt, even if you wrap that header.
Old 04-23-2017, 02:35 AM   #442
Bullitt2496
Guest
Posts: n/a
WGP kit has a PNP bracket for the throttle pedal FYI. Also, there's no beating of the trans tunnel... it's easier to trim the exterior of the T56 case...
Old 04-23-2017, 02:38 AM   #443
Bullitt2496
Guest
Posts: n/a
Originally Posted by DustinS View Post
I thought they were talking about not needing to clearance it for the sway bar. What they mean is you don't need to notch it for the steering rack. The pan still hit sits on the sway bar. So no matter what exhaust you run - Vorshlag or not - you cannot run a sway bar with these mounts.
WGP mount kit clears the sway bar
Old 04-23-2017, 02:39 AM   #444
Bullitt2496
Guest
Posts: n/a
Originally Posted by all4spl View Post
There is also a sikky oil pan that could be a good option.
We don't advocate the sikky or CX pans because if you bottom out your car with an aluminum pan, it's going to crack and possibly bye bye motor. We switched to a steel pan for this reason.
Old 04-23-2017, 02:43 AM   #445
Bullitt2496
Guest
Posts: n/a
That is a giant offer. I would have politely declined, but that is nuts.
Any idea on when you start yours? Engine is still a couple weeks out if it was anything like mine.
Edit: Realized I never posted the pictures for the Clutch master cylinder (At least I couldn't find them)
Difference in length and thread pitch
FYI WGP kit has a PNP adapter for clutch master mounting and comes with oem compatible clevis at the correct length
Old 04-23-2017, 03:12 AM   #446
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If only WGP had better reviews and customer service than this...
http://www.ft86club.com/forums/showthread.php?t=80300
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Zer0 (04-23-2017)
Old 04-23-2017, 04:47 AM   #447
Zer0
Drives: 2015 frs
[QUOTE=DustinS;2896247]I used a spot weld cutter, still not fun, mostly because there isn't a lot of room in there.
A 90° drill works great with a spot weld cutter. I found it to be easy. I used a Milwaukee 90° drill the small one that uses m12 battery and a spot weld cutter from harbor freight. The cutters break easily I bought 3. They were $6 each I think.
Zer0 is offline   Reply With Quote
The Following 3 Users Say Thank You to Zer0 For This Useful Post:
DustinS (04-24-2017), Sportsguy83 (04-23-2017), wooly35 (04-23-2017)
Old 04-24-2017, 10:23 AM   #448
all4spl
But to my knowledge, the kit wont allow the factory heater hose hookups. Last time I asked you about that, you said that you had a kit for it and I asked for pictures with no response.
all4spl is offline   Reply With Quote
The Following 2 Users Say Thank You to all4spl For This Useful Post:
cf6mech (04-30-2017), DustinS (04-24-2017)
Search this Thread:
Advanced Search
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) -- General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) -- General Topics 8 06-12-2012 08:32 PM
