#309 |
Drives: 2013 Ultramarine FR-S
First of the three boxes showed up today.
Not happy about this. though damage isn't too bad. Summit could have done better on packaging. ![]() ![]() ![]()
#310 |
Guest
Posts: n/a
^Thats an LS3 style water pump. I think you'll find the LS2 fits better (better clearance for intake/upper rad hose, etc)
#311 |
Yes, LS3 Water Pump to go with my LS3 Accessories, and LS3 Crank Pulley. Same thing Vorshlag is running. (well same thing @cf6mech is running)
Edit: See the pump you are talking about. I'll deal with this one, not too big a difference.
#312 | |
Guest
Posts: n/a
The LS2 corvette pump has the same pulley FYI. Sent from my iPhone using Tapatalk |
#313 |
Guest
Posts: n/a
Is your engine an LS3 also? or an LS2? Take a pic of the backside of the pump.
#314 |
I will be running a LS3
#315 | |
I Love custom Turbo kits
Drives: Limited BRZ
I have everything needed from that kit except the alternator and belt so that's all I will need. http://www.jegs.com/i/Chevrolet-Perf...2/-1#reviewTab
#316 | |
Drives: 2014 Scion FR-S LS3
2014 scion FR-LS3 lol
#317 |
I'm not sure you will want to run the corvette alternator bracket. I think it is best to stick with the CTS-V LS6 accessory kit and just not use the steering pump
#318 | |
Drives: Limited BRZ
I have all LS2 accessories, just need the alternator itself and shorter belt. From pictures it seems it will fit and it's not taller than the intake. Would really suck to just throw all that away and buy $800 worth of CTS-V accessories. I'll at least try the setup and see if it fits before ordering anything else.
#319 | |
Drives: Limited BRZ
#320 |
Parts came in and got pictures of everything. Accessory drive stuff came in a giant box all by itself.
![]() ![]() ![]() This happened today: ![]() So Really interested in getting this swap done ASAP. Hoping to get everything squared away on the trans Monday. See if Vorshlag can Expedite mounts/driveshaft/TOB.
| The Following 2 Users Say Thank You to DustinS For This Useful Post: | ILLSMOQ (04-02-2017), Sportsguy83 (04-02-2017) |
#321 |
Drives: 2017 WR BLUE BRZ
Yeah buddy! Serious progress...almost ready to put it together!!
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | Sportsguy83 (04-02-2017) |
#322 |
don't use that pilot bearing in the picture by the serpentine belt!!! LOL
| The Following User Says Thank You to wooly35 For This Useful Post: | DustinS (04-03-2017) |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 13 | 03-22-2016 04:07 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-22-2015 12:38 AM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 12:14 PM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 08:32 PM |
