...Just add nauseum
Drives: 2003 (AP1) S2000
MAPerformance dual VTA catch can
This dual VTA can mounts to the back of your intake manifold. It is sold with the MAPerformance turbo kit, or it's available custom ordered.
It installs clean and looks nice. Google it for installed photos. Unused. $100 shipped. Less than half price. Cheers. New Thread, New Sign. ![]() I've also got a non-intercooled Sprintex all boxed up... Thinking of unloading it. If I get serious I'll post pics. Otherwise it's going on the car.
There are many ways to displace.
-Spartarus |
Drives: 2014 BRZ
Hey man! Might be interested, are these baffled inside? Wondering how the oil does not flow back if the fittings are at the bottom...can you post a picture of what the inside looks like?
#3 | |
...Just add nauseum
The check valve needs to be removed from the PCV fitting on the block. I can link an install video. It's part of the MAPerformance turbo install series. The filters on top are crankcase breather filters. Put simply, this converts the recirculated PCV system into an open crankcase breather system. Any blowby, water vapor, fuel, nastiness evaporates and vents to the atmosphere, any vaporized oil coalesces and drains back to the engine where it belongs. But with no vaccuum forcing airflow through the crankcase, the amount of oil that makes it that far should be very small.
-Spartarus |
Drives: 2013 FRS
i got one of these from ian like 2 years ago. (I am mechanically inclined.) when it comes to this thing i just couldnt figure out how to install it, because each can doesnt have 2 nipples.
Drives: 2014 BRZ
I would imagine that you simply route your PCV valve hose to the left fitting and you route your front crankcase vent that is located behind the A/C Compressor to the right can fitting. You will have to cap off the plenum that sits on the left atop the intake manifold (deleting OEM PCV to manifold connection). This is a VTA option and only requires inlets.
Still for sale?
Drives: 2016 Scion FR-S
Interested if still selling. Also, do you have any install links?
| Radium dual oil catch can kit | Bluetail | Engine, Exhaust, Bolt-Ons | 0 | 07-11-2016 10:19 PM |
| FOUND: Radium Dual Oil Catch Can Kit | asnatlas | Want-To-Buy Requests | 1 | 05-20-2016 11:06 PM |
| RacerX Fabrication Dual Oil Catch Can | Speedtek | Engine, Exhaust, Bolt-Ons | 0 | 03-05-2016 07:07 PM |
| Radium Dual Catch Cans with AVO kit & RHD | Skorov | Forced Induction | 6 | 04-08-2015 11:22 PM |
| Dual Catch Can, hoses and fittings | Sportsguy83 | Engine, Exhaust, Transmission | 9 | 02-21-2013 01:13 AM |
