#99 | |
Drives: 2017 BRZ Limited
#100 | |
Drives: 16 BRZ Limited CWP 82 Alfa Romeo
| The Following User Says Thank You to SkyKing For This Useful Post: | tehShirt (03-03-2018) |
#101 |
Drives: 2014 Subaru Forester
#102 |
I agree... wasnt always there! Looks like the Crutchfield folks finally updated their system.
#103 |
Drives: '17 BRZ Series.Yellow
Any updates from anyone running the Sony XAV-AX100 in the 17MY? I have the one piece dash trim and looking to upgrade to this HU.
#104 |
Drives: 2017 Subaru BRZ PP WRB
What kind of update do you need? It's a standard double din unit that will work just fine in any year model of the twins, for a 17 you'll use the Scosche SU2032B dash kit.
| The Following User Says Thank You to NCtoBRZ For This Useful Post: | Tonezorz (04-13-2018) |
#105 | |
Do I still use that kit with the single piece dash from Canada? And should I just use any wiring harnesses that crutchfield says I need? |
#106 |
No, the Scosche kit is intended for the trapezoidal opening of the US dash, there is another kit that I’ve seen mentioned in other threads that just fills in the gap on the sides of the head unit if you’re using the Canadian dash with a rectangular opening. The particular harness that you’ll need just depends on what type of installation that you are doing, what Crutchfield recommends should be fine... but more complicated installs such as using a Maestro RR (which I’m not sure if it is compatible with the Sony head unit) require either hardwiring or using their T01 harness plus adding some pins (look up my recent thread regarding installing the Meastro RR with a Pioneer head unit).
| One piece dash and other 2017 parts | Summerwolf | Cosmetic Modification (Interior/Exterior/Lighting) | 340 | 05-05-2020 09:47 PM |
| Stock Stereo/Headunit Frequency Crossover? Replacement Door Woofers | PandaSPUR | Electronics | Audio | NAV | Infotainment | 3 | 01-12-2015 03:18 PM |
| 10-Series Electroluminescent Dash Panel Replacement | Raiin | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-18-2013 02:14 PM |
| Where to purchase replacement dash panels? | jimmyze013 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-19-2012 12:50 AM |
| FR-S headunit replacement | drei | CANADA | 7 | 07-11-2012 05:08 PM |
