#29 | |
Drives: '14 FRS
| The Following User Says Thank You to ISZach For This Useful Post: | ncted (11-20-2017) |
#30 |
Drives: 2014 Subaru Forester
#31 | |
Drives: 2015 Subaru BRZ Series.Blue
#32 |
Drives: 2017 Subaru BRZ Limited
https://rover.ebay.com/rover/0/0/0?m...2F382192043374
I am not interested in changing the dash on my 2017 Limited BRZ, so I’ve been searching for a way to get an aftermarket DD Head Unit. The above link is to an item on eBay that turns the factory opening to a standard double din opening. It ships from the UK so I will have to wait till the end of the month to see if it’s any good. This is a gamble for sure but if it fits and shows good it could be a good solution to those of us affected by the Subaru knuckleheads. Sent from my iPhone using Tapatalk |
| The Following 3 Users Say Thank You to Flash02 For This Useful Post: |
#33 | |
Drives: 2017 Subaru BRZ Limited PP
I had the MY16 replacement dash in-hand as well as the Metra clips and it just didn't look right, personally. I went ahead and ordered the item from the UK that you linked a couple of days ago and it should be here next week. Did you, by chance, receive your kit yet? Thanks again. |
| The Following 2 Users Say Thank You to Nickolas For This Useful Post: | MidEastBeast (11-24-2017), ncted (11-19-2017) |
#34 | |
Sooo... anyone care to recap for a slow guy like myself? What I understood from this thread is that I go buy the dashboard pn 66077CA200 that fits perfectly on the 2017 Subaru BRZ and that includes the same kind of leather and red stitching that;s throught the 2017 BRZ cabin. And then I can buy the Kenwood DDX916WS, Kenwood DDX917WS, or the Pioneer NEX 4200, and all of them will fit flush and perfectly fill up the space on the pn 66077CA200.. am I right? Also, reverse camera, Android Auto, and steering controls, should all work perfectly, correct? Are there any altenrtaive sound systems to those I've listed as well? the Kenwoods are actually pricey at over 700 US$. |
#35 | |
Drives: 2017 BRZ Limited
Getting the steering controls, USB, camera, etc. should all be doable with some work. It will be easier once the iDatalink Maestro RR support arrives. If you want the HU to fill the space, the Kenwoods or some of the Android HUs are the only 200mm options I know of. |
| The Following User Says Thank You to ncted For This Useful Post: | rennlistuser3 (11-21-2017) |
#36 | |
Also, I guess I'll put this thread here for those interested in following, it's a thread on the Kenwood DDX917WS: http://www.ft86club.com/forums/showthread.php?t=119040 I'll dig up more and maybe post my findings Thanks |
#37 | |
Drives: 2017 Subaru BRZ Series. Yellow
#38 | |
Well the new bezel arrived today form merry ole England, looks good, just as shinny as the Factory bezel. ![]() ![]() Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Flash02 For This Useful Post: | tehShirt (11-27-2017) |
#39 |
Here are some more shots, this set up can be either Double Din or Single Din. As a single DIN a small compartment is attached to the bezel.
![]() [IMG]https://uploads.tapatalk-cdn.com/20171127/ade92522b6d3d3122e89fa1abf206***.jpg[/IMG] Sent from my iPhone using Tapatalk |
#40 |
@Flash02 That looks pretty good, thanks for the pics! Excited to see how it looks installed in the car.
| The Following User Says Thank You to tehShirt For This Useful Post: | Flash02 (11-28-2017) |
#41 |
Drives: Neptune GR86
Almost makes me want to go to a single DIN unit... But it'll probably look awkward since everything is designed around a big screen in everything...
#42 | |
I may do the install before Christmas, just depends how aggravated I get with the Slow silly STARLINK Head Unit. Sent from my iPhone using Tapatalk |
| One piece dash and other 2017 parts | Summerwolf | Cosmetic Modification (Interior/Exterior/Lighting) | 340 | 05-05-2020 09:47 PM |
| Stock Stereo/Headunit Frequency Crossover? Replacement Door Woofers | PandaSPUR | Electronics | Audio | NAV | Infotainment | 3 | 01-12-2015 03:18 PM |
| 10-Series Electroluminescent Dash Panel Replacement | Raiin | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-18-2013 02:14 PM |
| Where to purchase replacement dash panels? | jimmyze013 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-19-2012 12:50 AM |
| FR-S headunit replacement | drei | CANADA | 7 | 07-11-2012 05:08 PM |
