#309 |
fabulous
What do your wife and kids say?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | gravitylover (01-19-2017) |
#310 |
Still a 50% split (even though there are only 3 of them). Wife mostly thinks I am an asshole when I start laughing at 3am on a Saturday.
My cat agrees that you are a 100% asshole though. He hates you.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | nos145 (01-25-2017), Ultramaroon (01-19-2017) |
#311 |
fabulous
lol
#312 |
They know I'm an asshole
| The Following User Says Thank You to gravitylover For This Useful Post: | Ultramaroon (01-20-2017) |
#313 |
They won't fix mine, because the supercharger voids the warranty. I tried to explain that they obviously released the TSB because a lot of people were complaining supercharger or not. But they don't care of course, and offered to fix it for 3k. Doesn't bother me that much.
#314 |
Anti stance.
Supercharger doesn't void anything. Print out the Magnuson Moss act and slap someone with it.
#315 |
1st86 Driver!
Probably not in this case (fuel pump) but it can void the engine warranty if it can be shown to put the engine outside design specs. Ford did this successfully with a TSB on diesel trucks where they showed that a commonly used aftermarket tune/chip caused the engine to exceed the limits of the head gasket (I think it was 2005).
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#316 |
Anti stance.
That sounds all well and good. A warranty cannot be voided. Claims can be denied. There is a difference.
#317 |
in the recliner of rage
Drives: Asphalt FR-S
Just brought my 2016 home from the dealer with the new Denso second-gen HPFP. No crickets the whole way home, but there was a strong fuel smell outside the car when I got it in the garage. Took off the HPFP cover (surprised by the heavy gauge of steel they used for that part) and found a leak. Literally squirting fuel out of a connector. Upon closer inspection, it also appears that one of my direct injectors may be leaking at its head seal. Bummer.
#318 | |
Drives: 2019 BMW ///M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#319 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Yep. This is exactly the sort of thing you bring your car in for to be repaired under warranty.
-O/D
2016 FR-S, Hot Lava |
#320 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#321 |
Drives: 2015 Scion FRS
Got mine replaced few months back. Over 5K now with no crickets.
#322 | |
One thing that I find interesting with this second generation pump is the inclusion of a reduced fuel pump cam lift profile on the intake cam of the 2017 engines. Obviously, the 2017 ECM is designed with different fueling parameters to match the reduced fuel pump flow rate, but retrofitting the newer pump to the older engines means the new HPFP is operating with a more aggressive fuel pump cam profile, and consequently, at a higher output than the 2017 engines. This makes me wonder if the new pump design was optimized for use with the milder fuel pump cam profile, and using it with the 1st gen camshafts will result in lower pump life, or an eventual return of the crickets that would otherwise not appear in a 2017 engine. |
| The Following User Says Thank You to Resolute For This Useful Post: | funwheeldrive (02-12-2017) |
| DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump | ZeroTo86 | Engine, Exhaust, Bolt-Ons | 0 | 08-08-2016 07:39 AM |
| FS: Moto-East Flex Fuel Kit - OEM Fuel Pump | FR-Shred | Engine, Exhaust, Bolt-Ons | 1 | 05-16-2016 07:28 PM |
| Fuel system questions. Boost-A-pump/stock fuel lines for engine swap | Toxicmilk45 | Engine, Exhaust, Transmission | 4 | 12-14-2015 04:52 PM |
| Fuel pump | sw20kosh | Engine, Exhaust, Transmission | 1 | 12-10-2013 11:21 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 05:53 PM |
