#15 | |
humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | nhuyvan1106 (10-09-2016), Ultramaroon (10-08-2016) |
#16 | |
fabulous
Now, here's my qualifying statement. I agree with the suspicion that Motul is able to achieve compatibility with typical synchronized transmissions through an additive that prevents reaction with the softer metals. Even if I am wrong, it costs me nothing to use a decent straight GL-4 MT fluid. I prefer Redline MT-90 for my trans and a proper "limited-slip" GL-5 for the diff. I also maintain that, for a non-tracked/flogged car, there's no reason to change out the stock fluid for the life of the car. I changed my fluid because I beat the piss out of it from time to time. I'm pretty sure it was unnecessary and the stock fluid does a good job of keeping it quiet.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | nhuyvan1106 (10-09-2016) |
#17 |
Drives: 2016 Cosworth 2.2 BRZ
Slightly OT but I didn't think this was needed for a Torsen LSD since it does not use clutches but gears. My understanding is that the limited slip additive is only needed for clutches, and with a Torsen you can use regular gear oil without the additive. I don't think the additive hurts though...
| The Following 2 Users Say Thank You to sly For This Useful Post: | nhuyvan1106 (10-09-2016), Ultramaroon (10-08-2016) |
#18 | |
fabulous
#19 | |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
• How To: Free Clutch Spring Removal in 15 Minutes - A must do for manual trans! |
| The Following 2 Users Say Thank You to Fenix For This Useful Post: | nhuyvan1106 (10-09-2016), ryoma (10-09-2016) |
#20 | |
fabulous
https://torsen.com/faq/
#21 |
Java Programmer
Drives: 2016 FRS Red
So I had to drive my car tonight, and I followed Sly's advice to let the clutch move into and out of gears on its own by giving it a little push, man, my gear shifts actually felt so smooth, I did not have to use alot of energy to shift, I was really excited and happy
![]() My car is a daily drive car, and I drive at 75 or 80 on the high every day to get to work. So I don't think I need to change the transmission fluid that often right? |
| The Following User Says Thank You to nhuyvan1106 For This Useful Post: | sly (10-09-2016) |
#22 |
Java Programmer
| The Following User Says Thank You to nhuyvan1106 For This Useful Post: | Ultramaroon (10-09-2016) |
#23 |
fabulous
You don't have to change it ever.
#24 |
Java Programmer
#25 |
fabulous
The Dry Shitties? Come down and join us for a meet sometime.
#26 | |
#27 | |
fabulous
#28 |
Java Programmer
| Tags |
| clutch, clutch noise, gearbox, shift gear, shifting |
| Anyone feel like they have a clunky gear change? | Haseebali31 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 34 | 04-16-2022 03:52 PM |
| MT tight, hard shifts. Opinions? | boead | Issues | Warranty | Recalls / TSB | 19 | 09-30-2014 04:59 PM |
| 3 min fix for 2nd gear hard shifting | Black Tire | Engine, Exhaust, Transmission | 22 | 03-23-2014 01:13 PM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) -- General Topics | 35 | 06-24-2012 03:22 PM |
| A/C Shifts off when accelerating hard? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 06-19-2012 01:24 AM |
