#57 | |
Drives: '15 BRZ RA
#58 |
Try to avoid yes, but there are always times when you gotta just slam on the brakes (e.g. avoiding a dog running into the road, or someone runs a red light in front of you, etc.).
| The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (10-05-2016) |
#59 | |
Drives: '13 BRZ Limited
Side note - do the twins actually produce downforce at speed in stock config? I thought velox had found it created lift. (edit - found the quote) "The coefficient of lift is .179, meaning the car does generate lift in its stock form." http://www.velox-motorsports.com/sin...itial-CFD-Case |
#60 | |
http://media.caranddriver.com/files/...lete-specs.pdf
2022 BRZ Build 2013 FR-S Build |
#61 | |
Drives: 2016 FR-S Oceanic AT
#62 | |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | CSG Mike (10-05-2016) |
#63 |
Drives: Brz LS3/tr6060 Whipple 2.9L
Decided the wilwood 6 piston/4 piston kit werent worth the $. The sti brembo swap like many do arent good because of the trailing/leading staggered pistin design. Designed to be only on rear of knuckle
Went with some top of the line Alcon 6 piston fronts, 4 piston rears. Huge 2 piece rotors to stop my Ls3 whipple boosted 700whp brz Last edited by Bripper; 08-04-2019 at 04:29 PM. |
#64 | |
Drives: 2017 Subaru BRZ Limited
1) You necroed a thread that was more than 3 years old to post some irrelevant whining. 2) If you LS swap the car, your situation is different. The vast majority of people who own this platform, /including/ those who track it, do not need upgraded brakes. One of the key things you should be doing to increase performance on this platform is to cut weight and to run on better tires, both will greatly improve braking performance without the need to upgrade your calipers. 3) Nobody is saying they don't like upgrades, but there's a fuck-ton of ricers in this community who will buy very stupid mods for their car without any reasonable purpose. It is the intention of experts in the community to help spend their money intelligently if they're going to do it. Before buying a BBK for this car, every single person who owns it should start with better wheels and tires, cutting weight, and getting performance driving instruction. Obviously increasing power output significantly, such as via an engine swap, may require upgrades to support that in other areas of the vehicle as well, including braking. But the factory brakes are more than adequate even with full bolt-ons. If you haven't learned what I said above in all your reading (including old threads from 3 years ago) to understand why people give this advice, I'd say your anger is misplaced and should be focused on yourself for your own failure of reading comprehension. |
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 06:53 PM |
| Looking for some upgrades | Rinzler_ft86 | Want-To-Buy Requests | 0 | 06-14-2015 02:31 AM |
| upgrades to my frs | marine12 | Engine, Exhaust, Transmission | 9 | 04-10-2014 08:06 AM |
| All Possible Car Upgrades? | pwnisher | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-23-2013 01:27 PM |
| GPS Map Upgrades? | Enemies | Electronics | Audio | NAV | Infotainment | 0 | 04-20-2013 05:18 PM |
