#15 | |
FReSh Mobile
This is from talking with a manager at the dealer who has 5axis everything on his car and is in constant contact with them. |
#16 | |
Boosted
Drives: Sideways
#17 | |
Boosted
Drives: Sideways
#18 |
Drives: 2018 Golf R
Im running 225s on my 8.5" wide wheels. Its very slightly stretched, but theres tons of grip. I have no plans to run a wider tire at the current power levels.
Parting out HERE
#19 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
The FR-S/BRZ doesn't need wide tires for grip, stock size in sticky compound works fine for stock power. Kumho XS in 215/45-17 on 17x8" wheels perform better on my FR-S than 275/40-17 Nitto 555RII DOT-R tires on 17x9.5" Z06 wheels on my 'lightweight" 98 V6 Camaro (3200lbs.) The FR-S is quicker on all sections of track and ~3 seconds a lap faster for me stock on the 'skinny' street tires than a stripped out V6 Camaro with upgraded suspension (Koni dampers, tubular arms and spherical ball joints, massive hollow anti-roll bars F & R) and wide DOT-R tires was...
#20 | |
Boosted
Drives: Sideways
Sent from my Galaxy Nexus on Jelly Bean
#21 |
I just don't see the point in overly excessively wide tires when a 245/40-17 Kumho XS or Hankook RS-3 on 17x9's should be enough for an ~300 hp FR-S.
#22 |
Drives: 2021 Supra / 2022 Tundra
because a 245 is pretty small on a 2600lbs car when there is nothing limiting the tire size such as autox rules. I would run 275s if I could and it fit properly but maybe that's just me.
| The Following User Says Thank You to ABQautoxer For This Useful Post: | Synack (07-09-2012) |
#23 | |
Boosted
Drives: Sideways
#24 | |
Boosted
Drives: Sideways
#25 |
Drives: Legacy GT
Going wider than is necessary for the power and weight of a car will only make it slower and less responsive because it has more rubber to heat up. With 200hp and 2600lb I would expect 245-255 is about all the tire anyone would ever need. Plus think of how much more an 18x10 with a 275 weighs than a 225 on a 17x8.
Wider tires don't give you more grip, they give you more heat capacity. say you have a 225 slick vs a 275 slick on an FRS. The 275 might not ever get up to temp and won't grip as well as that 225 operating at the right temperature. As far as fitting tires on wheels, it is better to have the wheel a little wider than the tire. You get a little less flex and better response. I'm not talking hellaflush stretched, but it's better to put something like a 225-235 on an 8" rim vs a 245-255. |
| The Following User Says Thank You to jamal For This Useful Post: | ill86 (08-12-2012) |
#26 |
Yes I've had a car that needed 275mm+ width tires (because of it's weight...):
![]() Is this for street or track use? I think you should drive an FR-S to it's limits first before you go changing tire widths to such an extreme...because 215/45-17 Kumho XS on 17x8 wheels are too much tire for daily driver street use on this car in stock form - it actually changes the handling characteristics to more neutral/understeering while raising the grip threshold so much you can't break the tires loose with all traction and stability aids off, wet or dry, unless you are driving like an idiot who wants to immediately get license revoked and car impounded... But on track it suits the car 100%, with perfectly neutral handling and has the right balance of grip (so much lateral grip actually that the stock seats and seatbelts fail to keep you positioned properly and you have to use your legs for bracing to keep from being thrown side to side.) ...that's on a 215/45-17 street tire. I've also had a 2300lb '90 Integra RS on 15x8 wheels and 225/45-15 DOT-R tires that handled even better than the Camaro, and it's still doesn't compare to the FR-S on 215/45-17 street tires. ![]() Seriously, Toyota and Subaru knew what they were doing when they created this car... it doesn't need massive width tires for increasing its handling potential. Massive width tires and wheels will also degrade the suspension due to a very increased unsprung weight, so the grip increase will also be offset by an increased mass working against the suspension.... might as well go with a more conservative width and lighter weight setup that won't upset the chassis so much. Same basic net grip level, with better handling due to lighter unsprung weight, especially if lighter than stock... Just trying to help.
| The Following User Says Thank You to Vracer111 For This Useful Post: | ill86 (08-12-2012) |
#27 |
Boosted
Drives: Sideways
90% street and 10% drifting once a month or so. Its going to be a 250+whp daily driver and once a month weekend drifter. Same as my 370 was. I got what I needed out of this thread so thanks guys.
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| WTB: 1 OEM wheel with or without tire | #87 | Wheels and Tires | 11 | 01-31-2013 02:21 AM |
| Forum members wheel and tire experiences | RaceR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 07-26-2012 03:23 PM |
| Wheel/Tire Theft Notice | Lonewolf | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 06-29-2012 12:05 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 04:05 PM |
