Southern California SoCal
Old 09-23-2016, 02:26 PM   #15
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by RedNWhite View Post
Yeah, you're right, I don't trust dealerships that much either. One time a dealership left the oil cap off after an oil change. Ended up breaking down with a broken belt. How much does your place charge?
Sent from my SM-G900T using Tapatalk
give us a call 714-582-3330 or pm me your email and i'll have someone contact you.
The Following User Says Thank You to continuecrushing For This Useful Post:
RedNWhite (09-24-2016)
Old 09-03-2017, 11:00 PM   #16
LALFAN
Drives: FR-S RS 1.0
Originally Posted by Gabzor View Post
They actually have a tester for brake fluid, track guys use it alot.. Come through, I'll hook you up
Can anyone recommend a decent one? I see a few on Amazon with mixed ratings. I need to have my 30K service too and I'm trying to cut some costs. If I can test my fluid and see that it's fine, I can cut that out.
https://www.amazon.com/Automotive-Di...d+tester+dot+3
LALFAN is offline   Reply With Quote
Old 09-04-2017, 11:46 AM   #17
cjny
Drives: 2016 BRZ
Originally Posted by retoocs View Post
It's a Subaru thing, brake fluid at 30k.
My MINI Cooper (which is a BMW product) called for new fluid every year. Yes, you can get away without doing it, just like you can postpone most maintenance. But why would you? To save money?
If you want to save money, learn to do it yourself. It's easy with the right tools and at the rates quoted above you'll come out ahead on $ even the first time.
cjny is offline   Reply With Quote
Old 09-07-2017, 12:18 AM   #18
e_lunatic
Drives: 2015 Scion FR-S
if you have the money to take it to the dealer or the time to do it yourself and dont mind spend money to throw away perfectly good fluid...
i have not had a good reason to ever change fluid that early. I plan on running higher quality fluid that I will swap out when I upgrade rotors and lines next year but no need to change that fluid out unless you really abuse the car.
e_lunatic is offline   Reply With Quote
30k service
Search this Thread:
Advanced Search
30k mile service - over limit? kgc Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-08-2015 03:27 PM
30k mile service Mossyjaw Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-04-2015 02:28 AM
15,000 mile service cost at Subaru? paiceyfan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 01-29-2015 04:42 PM
30,000 mile service goke186 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 10-11-2014 10:52 PM
1000 mile break in service for BRZ? Tonym427 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 08-27-2012 04:00 PM
