#29 |
Drives: '15 Scion Frs Steel
Hmm good point humfrz, the op said the clutch feels soft after install looking at it from a mechanical point something isnt put in right giving the pedal its stiffnes
Sent from my SGH-T999N using Tapatalk |
#30 |
#31 | |
Once the engine is running, the clutch situation would be easier to diagnose. Meanwhile, some questions have been asked that you haven't answered..... ![]() humfrz |
#32 |
#33 |
fabulous
Well, I've said my piece and none of my questions answered.
I think the encoder slipped off of the guide pin and the new flywheel was jammed over the top of it. @lizbrayan's right. Pull it all apart and do over. I don't know if it's possible to push that guide pin down into the crankshaft but if so, that thing's going to be a bitch to extract.
#34 | |
Drives: Blue
I supported the engine the whole time and everything went pretty smooth nothing went in forced |
#35 |
Drives: Blue
#36 |
Well, if the pedal is REALLY lose, it could be:
* that is not pumping any fluid to the slave cylinder because there is air in the line (bleed the line) or there is no fluid to pump (add fluid). * the slave cylinder is shot (unlikely) * the master cylinder is shot (unlikely)(can be checked when you try to bleed the system). * the clutch fork/ throw out bearing is not pushing on the pressure plate. * you forgot to install the pressure plate or the throw out bearing or the clutch fork (just kidding). * have you ever replaced a clutch before .. ?? I'm about to go along with @lizbrayan ...... you just might have to take it apart and put it back together. QUESTIONS for you: If the clutch was aftermarket, what clutch is it .. ?? Did it come as a set (flywheel, clutch disk & pressure plate) .. ?? Did you replace the throw out (release) bearing ..?? Come back .... ![]() Story on me. The first time I overhauled an engine, when I went to crank (literally) it over ..... it wouldn't budge. Why? Cause I didn't realize that the piston rod caps were shimmed and the new rod bearings were thicker than the old rod bearings....... ![]() (hey, cut me some slack, I was only 14 years old ) humfrz |
#37 |
I second humfrz check the obvious stuff that is easy to get to before you start taking stuff apart again. Im only 19 and just started my car repair/modifying career so i dont yet have the balls to take on a trans job like that alone. And @humfrz i am super jelous you got to work on cars so young.
#38 |
Op is in way over his head at this point. Car needs to go to somebody that can see it to troubleshoot.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Braces (09-13-2016), Ultramaroon (09-13-2016) |
#39 | |
I got my first road vehicle when I was 14 (my grandfather gave it to me). My very first vehicle was a 1937 Chevrolet pickup, which took the brunt of my learning curve...... ![]() I remember one fine day, while working the fields, that one could "wire the governor open" for a burst of power, to get through the wet spots in the field, by running a long piece of bailing wire from the governor arm up to the seat of the tractor. Yep, sort of like a shot of nitrous .......... ![]() However, I also learned NOT to let the wire get close to the magneto, that was sort of like pissing on a spark plug ...... humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (09-13-2016) |
#40 | |
humfrz |
#41 |
#42 |
Drives: '13 Whiteout FR-S M/T
Not saying I'm ever going to replace my own clutch but man, you guys are like a super hero group of car mechanics! Props to you all for trying to lend a hand without even putting eyes on OPs car. Just reading your responses is a learning experience.
Sent from my Nexus 6P using Tapatalk |
| The Following 2 Users Say Thank You to kthxbai For This Useful Post: | humfrz (09-13-2016), Ultramaroon (09-13-2016) |
| Tags |
| clutch, flywheel, won't go into gear, won't start |
| Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-05-2016 12:18 AM |
| New Clutch Job, New Problems... | RUEN_86 | Engine, Exhaust, Transmission | 4 | 12-28-2015 06:13 PM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 05:01 PM |
| Problems with FX400 full-disk clutch after shady install... ***Help?*** | Argento_FR-S | Engine, Exhaust, Transmission | 4 | 05-29-2013 03:29 AM |
