#15 | |||||
Drives: 2014 BRZ Limited
I think it's more of a solution looking for a problem. If you look closely at the marketing, they seem to be confused about what problem they're actually solving. That makes me suspicious of the product from the outset.
What you need instead is footage with an IR camera to see the entire engine bay with hot and cool spots. In the Jeep world we had some claims made about underhood heat that completely fell apart when someone did before and after IR videos with certain parts showing what was actually happening. People had taken measurements with IR thermometers to support their claims, but it turned out they were pointing them at hot spots that didn't capture where the cooling was actually happening. Most likely confirmation bias led them to hunt for those hot spots to give them the results they wanted, without even realizing they were doing it. The IR footage removed some of the ability to alter the results. Quote:
That doesn't stop anybody from misunderstanding the problem and saying, "Derp! I gots to get rid of all that heat under my hood because it caused a problem in my uncle's 1980 ricebox!" |
#16 |
I let it be the first time, but putting hot less dense air into the space under the car that has a vacuum helping to create down force is not going to help the handling. there is a reason the bottom of race cars are paneled.
| The Following User Says Thank You to ls1ac For This Useful Post: | venturaII (03-19-2020) |
#17 |
Only users lose drugs.
Drives: All the time
^^Exactly my thoughts. Are they trying to solve heat or add downforce? Dumping engine compartment air under the car (or anywhere, really) will help with heat. It'll make downforce worse, if dumped under the car..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#18 |
Love when an old thread get's resurrected and so many want to debate with people that have not been here in 3 or 4 years.
| The Following User Says Thank You to Tcoat For This Useful Post: | extrashaky (03-20-2020) |
#19 | |
#20 |
Cabin fever.
#21 |
I don't think ls1ac and certainly not myself are saying anything to correlate heat with downforce. Simply just that dumping more air under the car is NOT going to improve downforce, as the original diagram is trying to imply.
#22 | |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Certainly did not feel any handling benefit at highway speeds. Unlike when I put the front lip and sideskirts on, where I noticed an improvement on those crazy windy days. But those are mostly cosmetic as well under normal driving conditions. |
#23 | ||
#24 |
Yes, I read that, and I'm going on record as saying I assumed he chose his words poorly and really was meaning dumping ANY air (in this case, heated air, though it has zero effect on the situation...) under the car was not a good thing for downforce...
#25 |
Nah he was very specific about heat and density. It could probably be proven with math but the real world effects just would not be there.
#26 |
Hmmm...in that case then, hot air under the car would be better than cold, dense air. Less drag, right?
| The Following User Says Thank You to venturaII For This Useful Post: | Tcoat (03-19-2020) |
#27 | |
Did we just invent hover tech? I am calling the patent office.
#28 |
Thank you for the understanding, any added air under the car reduces the down force. (the whole purpose of the splitter under paneling side skirts and rear diffuser)
I will have to go back to the books to find definitive reasons why hot air reduces lift on a wing. Somehow just stuck in my mind. This is negative lift or down force. Last edited by ls1ac; 03-19-2020 at 05:15 PM. |
| Beatrush / Laile frame brace | autoCAR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 02-19-2016 03:08 PM |
| Dented rear wheel side panel/rocker panel. | Autocon | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 19 | 12-23-2014 12:18 AM |
| Anyone tried the Laile intake? | dave77 | Engine, Exhaust, Transmission | 43 | 06-26-2014 04:12 PM |
| A little bit of Beatrush history (Laile) | Kami Speed | Groupbuys | 1 | 01-13-2014 12:11 PM |
| Laile Intake Kit | JimmyMac | Engine, Exhaust, Transmission | 1 | 08-25-2013 07:49 AM |
