#19825 |
Country Boy 4 Life
Just shaved my rear endlinks. They were 54.98 mm wide. My new LCA have an opening of 54.80mm. They did not fit, so I shaved off a quarter mm and now they do!
Also, ordered a roller bearing kit. And a Fortune Auto hoodie. ![]()
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | MJones_RB (10-24-2018) |
#19826 |
| The Following User Says Thank You to humfrz For This Useful Post: | Leonardo (10-23-2018) |
#19827 | |
Country Boy 4 Life
Well it was going to be later this week when my front sway bar arrives. But, since I just ordered the roller bearing upgrade for my coils, I will wait to put those in the mix... Trust me, I am EXCITED FOR THE INSTALL! EDIT: My Front Perrin Sway bar just arrived! Now, just waiting on the roller bearings. NEW PIC - With all my parts - Minus roller bearing upgrade for coils. Going to gold paint and clear coat the : sways, trailing arms, toe arms, and ties. They should match the LCA nicely! Ugly carpet in my office...
I LIKE TIRES! Last edited by Leonardo; 10-24-2018 at 03:30 PM. |
#19828 |
Drives: 2015 Scion FR-S
After 4 hours of wet sanding, polishing, and waxing I got my tail lights looking the best that I could. Some of the scratches/scuffs from wet sanding are still visible, so they aren't 100% perfect
Tomorrow I'll install them on the car along with a few other things that should be coming in the mail. ![]()
#19829 | |
![]() humfrz |
#19830 | |
![]() humfrz |
#19831 |
I'm considering it. My goal was to get them 100% perfect and I just can't unsee those sanding marks... They aren't visible from a few feet away, but up close they're pretty obvious. The orange peel texture in the paint was pretty bad and the only sandpaper I have is 2000 grit, so each light required about an hour of sanding to get rid of it. No amount of rubbing compound, scratch remover, or polishing seems to do the trick on the sanding marks. I'm doing this by hand. Maybe it'd work better with an electric buffer.
| The Following User Says Thank You to Face_Plant For This Useful Post: | humfrz (10-25-2018) |
#19832 | |
Drives: 2015 FR-S
#19833 | |
However, if they really bug you, I'd suggest you give up on that clear coat and spray them again. And leave the 2000 grit sandpaper on the shelf - ![]() Yep, a store bought buffer and some polishing compound should finish them off nicely. humfrz |
#19834 |
Shitpost Generator v8.6
Today, in my never ending quest to silence the door rattles, I slid a quarter in between the armrest on the door and the door panel itself. It hasnt 100% eliminated the rattling inside the door, but it has reduced its volume/intensity significantly. Not planning on that being a permanent fix but, at least until I get around to actually taking the door panel off, it'll do.
#19835 | |
![]() Back-in-the-day, they used to sell these little rubber wedges that were rippled. I'd keep a supply in the glove box to jam into places that rattled - ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Leonardo (10-25-2018) |
#19836 | |
I'd love to buy a pack of something like that, but I wouldn't even know what to search on amazon. "Rubber wedge" just gets you doorstops lol. |
#19837 |
Today I bought a buffer wheel for my drill and polished my lights some more, then installed them on the car. I'm very pleased with the results
| The Following User Says Thank You to Face_Plant For This Useful Post: | Leonardo (10-25-2018) |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 05:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 07:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 11:19 PM |
