86WORX
go_a_way1, MisterSheep
Old 08-26-2018, 11:08 PM   #19545
notout86
Drives: GTS 86 auto
Originally Posted by RToyo86 View Post
I sanded the oil dip stick so I can get a more accurate reading.
Original oil change took 5.4 quarts as per the bottle reading.
The level was 3MM below the Full line, added 150ml as per the level on the asmoil bottle, then it read 3-4MM above. Sanded it and rechecked at the gas station and a separate parking lot. Still reading the same.
That is recommended as per manual, There must have been a tiny bit of oil that didn't come out during the drain process.
EDIT: got underneath this morning and corrected the levels, sitting perfectly now
Roughening the stick helps but the way that stupid stick bends as it angles into the oil makes it damn near impossible to tell where the level really is, It is different on each side. Not to mention the oil may expand/contract depending on temperature and then there's the level of the surface the car is on. Then again the stick may be splashing into the oil as the resistance to the o-ring on the handle is suddenly overcome. Sometimes oil sticking inside the tube from pulling the stick out gets on the stick. You can get your knickers in a knot over all this. The best you can do either measure what drains & put that volume of fresh back (allowing for filter) of use half a litre less of fresh then top up later.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
The Following User Says Thank You to notout86 For This Useful Post:
RToyo86 (08-27-2018)
Old 08-26-2018, 11:41 PM   #19546
dnieves
Drives: FR-S 10 Series
Polycarbonate doesn't like UV. If you're getting deterioration, buff it out and apply some kind of UV protectant to it. I looked into this a little bit ago. There doesn't seem to be any product on the market that will permanently protect them so you'll have to regularly apply it like sealant or wax
If you use regular clear coat it'll keep happening, if you use something like Meguair's you have to reapply every year. You could also use Aerospace 303 every time you wash the car (which you should be using for your interior anyway)..
dnieves is offline   Reply With Quote
Old 08-27-2018, 12:01 AM   #19547
Decep
Drives: 2013 FR-S Series 10
i have a bottle of that meguiars stuff, is it easy to overapply it? does it harm paint if you get any overspray on your paint?
Old 08-27-2018, 06:18 AM   #19548
dnieves
I masked like crazy so I don't know what it'll do to paint but the label says remove with rubbing alcohol in case you get some on.
Another option is to use Xpel Paint Protection Film -that has UV inhibitors. I have PPF on my front bumper and hood since 2013 and it's still clear.
Old 08-27-2018, 06:25 AM   #19549
dnieves
Just buy it online
O'Reilly's can't deliver it and Amazon has it for double the price. I'll pick it up in the next I head to CT (unless I find it elsewhere before that).
Old 08-27-2018, 08:17 AM   #19550
Ashikabi
Ashikabi's Avatar
I'd the PPF a spray or a skin?
Old 08-27-2018, 08:22 AM   #19551
1st86 Driver!
Originally Posted by notout86 View Post
Damn! Is there a UV clearcoat on the headlight covers? I used a non-abrasive polish (Turtle Wax Ice) on mine and the one that gets the most direct sun is deteriorating. Maybe I rubbed too enthusiastically to get the gloss but I thought not.
I doubt you caused it. Mine have had nothing specific on them and are just starting to show signs of fogging over along the top surfaces (2013 purchased 05/2012). It is garage kept but spends most of its days in a parking lot at work.
MJones_RB (08-28-2018)
Old 08-27-2018, 08:51 AM   #19552
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Took the car to its first Track session at calibogie.
Learned a lot about my driving and the car. It needs pads, fluid and tires ASAP!
Old 08-27-2018, 09:54 PM   #19553
new2subaru
Weight Weenie
Drives: 15 FR-S
Did an oil change.
Old 08-27-2018, 10:57 PM   #19554
dnieves
You have to keep in mind the sun beating on the plastic turns it yellow and when you're driving it's like getting sandblasted with all the stuff in the air, sand, bugs, rocks ant etc your clear headlights turn opaque.
Paint protectio0n film is the way to go BUT with the contours of the headlights it's a PITA to apply UNLESS you take out your headlights and have a friend hit it with a hair dryer/heat gun as you stretch it.
Old 08-28-2018, 07:54 PM   #19555
Legend
Drives: '20 GT86 Hakone
Yesterday, but got new wheels.
Legend is offline   Reply With Quote
The Following 3 Users Say Thank You to Legend For This Useful Post:
Lonewolf (09-05-2018), RallySport (09-01-2018), trvth (09-14-2018)
Old 08-30-2018, 06:20 AM   #19556
Roth
Roth's Avatar
Drives: 2013 Gt86
I've just ordered all the interior black trims (jdm) from japan.
And few days ago I got the alignment after the eibach pro kit. Beautiful to drive now
Roth is offline   Reply With Quote
The Following User Says Thank You to Roth For This Useful Post:
MJones_RB (08-31-2018)
Old 08-30-2018, 09:28 AM   #19557
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
Finally got my car inspected. Also got an oil change done while it was there, since I only got the car in June and I don't know when it was last changed.
qcbaker is offline   Reply With Quote
Old 08-30-2018, 05:25 PM   #19558
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
Coils on today.
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline   Reply With Quote
The Following 4 Users Say Thank You to PDM 2 For This Useful Post:
Dadhawk (08-30-2018), FRS13_ (09-01-2018), MJones_RB (08-31-2018), SuperTom (08-30-2018)
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 11:19 PM
